FYI: Costco is now stocking the 'good' Techron
by mbz321. 03/20/19 12:32 PM
Auto maintenance advice from a locksmith?
by Variant_S. 03/20/19 12:18 PM
Purolator 12 Pack L25608 $21
by hatt. 03/20/19 12:04 PM
Dealer service and franchise laws.
by BMWTurboDzl. 03/20/19 11:46 AM
Tie rod tapers
by LeakySeals. 03/20/19 11:26 AM
Quality Lug Nuts
by jcartwright99. 03/20/19 10:56 AM
More than one Reality
by beanoil. 03/20/19 10:50 AM
Reusable Oil Storage Container
by BamaE92. 03/20/19 10:37 AM
Bank 1 on an Equinox
by Washoe_Mark. 03/20/19 08:47 AM
How do you pronounce the word Vehicle?
by ZZman. 03/20/19 08:21 AM
Inline Fuel Filter
by CCI. 03/20/19 08:08 AM
Are All Douglas Tires USA Made?
by Miller88. 03/20/19 07:30 AM
Turn signal bulbs for '15 BMW?
by Benzadmiral. 03/20/19 07:02 AM
Drain/refill vs diy flush?
by Back40. 03/20/19 05:59 AM
Valvoline 5w30 Synpower HSTS?
by avi1777. 03/20/19 05:05 AM
Castrol Edge 5W50 "Supercar Titanium FST"
by Berto. 03/20/19 02:43 AM
The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
Saxman657, Maxxforce, Washoe_Mark, CG_BrianM, TBF
67565 Registered Users
113 registered members (avi1777, anndel, Bailes1992, ArrestMeRedZ, Arminius, 2012AccentSE, 11 invisible), 2,058 guests, and 54 spiders.
Topics286,150
Posts4,903,041
Members67,565
Most Online2,967
Mar 10th, 2019
Oil rec water pump Honda GX390 Penrite 30 vs 15w50 #4647608
01/27/18 05:52 AM
01/27/18 05:52 AM
Australia
Dewy Offline OP
Dewy  Offline OP
Australia
Which oil Penrite SAE 30 or Penrite 15w50 for Honda GX390 in ?
Penrite SAE30
Penrite 15W50
I have been using Penrite SAE30 (mineral) in all of my stationary motors, but on the last oil change of the water pump (Honda GX390) i noted some flecks of brass/copper. Looking at Honda's manual there oil chart only covers a0w30 and straight SAE30 up to 40'C (104'F). I regularly have to run this pump at the limit of this oil chart and beyond; 35-44'C, but some days is only ~25'C (77'F). This pump runs for a minimum of 3 hours per run and during emergencies (Bushfires/wild fires) has cope with multiple runs per day. Is the 15W50 to 'thick' for the cooler days?
I'm looking at running the Penrite 10 TENTHS RACING 15W-50 (PAO ESTER) as i have ~4 liters leftover from a motorcycle which is now sold... (Prob overkill as 2200+ ZDDP package in a full synthetic)
Should i continue running the Penrite SAE30 (Mineral) or give the Penrite 15W50 full synthetic a go?
I know there are a lot of threads re running the 15W50 in these 'types' of engines (air-cooled) during hot condition and the fact B&S are now using this weight oil in commercial applications would add to the confidence of giving the Penrite 15W50 a go...
BUT, my concern is the Honda might have tighter tolerances and not like the heavier weight oil on the cooler days / start-up...
Regards,
Dewy.
Re: Oil rec water pump Honda GX390 Penrite 30 vs 15w50 [Re: Dewy] #4647616
01/27/18 06:23 AM
01/27/18 06:23 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I run a plain jane 15W-40 HDEO (diesel engine truck oil) in my GX390 generator.
I think it is either Supertech or TSC Traveler, 15W-40 (it's been in to long to remember)
Synthetic is overkill, but then again when fighting fires - who cares about the oil cost?
Re: Oil rec water pump Honda GX390 Penrite 30 vs 15w50 [Re: Dewy] #4647627
01/27/18 06:53 AM
01/27/18 06:53 AM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
I would use 15w50 given the conditions. 25*C isn't cold either. You'll be fine. smile
The key is to make certain they are:
1. Topped off at all times.
2. Sitting on level ground.
3. Changed at the correct intervals.
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 186k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 153k Synpower 5w30 Supertech ST3980 (Ecore)
Re: Oil rec water pump Honda GX390 Penrite 30 vs 15w50 [Re: Dewy] #4647641
01/27/18 07:37 AM
01/27/18 07:37 AM
Down Under
SR5 Offline
SR5  Offline
Down Under
I've not got a Honda stationary engine, but I use to run Castrol Edge 10W60 in my Honda motorcycles (CBR) and it worked well.
I think the Penrite 15W50 full synthetic should work fine in an air cooled engine. I've also used GTX 20W50 in my B&S mower without problem, it specc'd SAE 30 but I didn't have any on hand.
Castrol GTX Ultraclean 15W40 A3/B3 + Wesfil-Cooper Z154
Re: Oil rec water pump Honda GX390 Penrite 30 vs 15w50 [Re: Dewy] #4647881
01/27/18 11:23 AM
01/27/18 11:23 AM
Pa, USA
NH73 Offline
NH73  Offline
Pa, USA
My vote is for Penrite 15w50. Thinner at starting than 30, thicker at operating temp than 30. The 15w50 is made to withstand harsher conditions than the 30. Anymore, most small gas engine manufacturers are recommending a 15w50 or 20w50 for hotter environments like yours.
2017 Toyota RAV4 Hybrid
2004 Ford Explorer Sport Trac
2012 Gravely ZT XL 48 w/ Kawasaki FR730
Re: Oil rec water pump Honda GX390 Penrite 30 vs 15w50 [Re: Dewy] #4648623
01/28/18 06:33 AM
01/28/18 06:33 AM
Australia
Dewy Offline OP
Dewy  Offline OP
Australia
Thanks for the advice... I think Ill run the 15w50 just to see if the oil has less contamination than the straight 30...
Always run the pump at 3000rpm so will be interesting if needs more throttle for the same load.
Re: Oil rec water pump Honda GX390 Penrite 30 vs 15w50 [Re: Dewy] #4648949
01/28/18 12:26 PM
01/28/18 12:26 PM
Pa, USA
NH73 Offline
NH73  Offline
Pa, USA
Like to hear how it turns out. I doubt you will need more throttle. It will not be as thick at start up, so it will never see thickness as it did with 30 weight. When its at operating temps., the oil is almost runs like water, the 50 will be a little thicker, but still tons thinner than even when you were at start up.
Re: Oil rec water pump Honda GX390 Penrite 30 vs 15w50 [Re: Dewy] #4649727
01/29/18 04:31 AM
01/29/18 04:31 AM
Australia
Dewy Offline OP
Dewy  Offline OP
Australia
Just for info the 15w50 has a Viscosity, Kinematic, cSt at 40C of 114, where as the SAE30 has Viscosity, Kinematic, cSt at 40C of 90; so the 15w50 will be thicker throughout the temp range... Its this start up thickness i was worried about. Once the air-cooled engine is up to temp the Viscosity, Kinematic, cSt at 100C 17.5 and 10 for the SAE30, but expect oil temp will go higher in the hot weather in Australia..
Re: Oil rec water pump Honda GX390 Penrite 30 vs 15w50 [Re: Dewy] #4650536
01/29/18 07:41 PM
01/29/18 07:41 PM
Pa, USA
NH73 Offline
NH73  Offline
Pa, USA
If I were to start my mower with PYB 10w30 on a 70 degree day in my area, the oil would be a whooping 180, and it still holding together. So I wouldn't worry about your 114.
