Toyota 2TR-FE 2.7 questions
by Doublehaul. 12/12/18 12:32 AM
Anybody used Eurolub?
by FordCapriDriver. 12/12/18 12:18 AM
Micro-Green Cut Open
by David1. 12/11/18 11:45 PM
Witch way does this valve work?
by Dylan1303. 12/11/18 11:42 PM
Santa came early..
by leoblack9. 12/11/18 11:22 PM
dropped a zip tie in my prius trans
by eljefino. 12/11/18 09:54 PM
2 Cello's - Some talented fellows right here.
by StevieC. 12/11/18 09:49 PM
Something different for sure - Punjabi Celtic
by StevieC. 12/11/18 09:40 PM
Honda eu200i hiccuping @ low idle - fixed
by Jmoney7269. 12/11/18 09:34 PM
Your dealer is here - Humor
by StevieC. 12/11/18 08:46 PM
1994 Honda Civic LX Main Relay-solder
by Gito. 12/11/18 08:43 PM
Winter/Summer Fuel Economy
by RayCJ. 12/11/18 08:33 PM
0w20 oils - NOACK
by superangrypenguin. 12/11/18 08:19 PM
Liqui Moly Special Tec AA 5w20 API SN
by Johnny248. 12/11/18 08:15 PM
Buy a brand new 1966-1977 Ford Bronco
by StevieC. 12/11/18 07:50 PM
2012 Accord,QSUD 5W20,WIX 57356 filter,3K miles
by aquariuscsm. 12/11/18 07:05 PM
Check out this awsome work!
by Chris142. 12/11/18 06:47 PM
200,000 miles
by Marco620. 12/11/18 06:29 PM
tcoffin014, Schm1d, EagleC, Dinka, MechanicGuy
66654 Registered Users
18 registered members (ctechbob, billt460, CleverUserName, BigShug681, David1, 2 invisible), 809 guests, and 37 spiders.
Topics294,961
Posts4,924,862
Members66,654
Most Online2,553
Oct 27th, 2018
Can you ID the manufacturer of this battery? #4647368
01/26/18 07:17 PM
01/26/18 07:17 PM
Boston, MA
spavel6 Offline OP
spavel6  Offline OP
Boston, MA
I recently bought a used H6 battery with an interesting top. I'm used to the Johnson Controls (Everstart, Duralast, etc) batteries, or the Interstate style, but this is interestingly different. Can you ID the brand or manufacturer? Has anyone come across caps like this? How do you open them to check water levels?
2005 MB E320 4-M 125k M1 0W40
2003 VW Jetta Wagon TDI 192k M1 5W40 TDT
2001 VW Jetta Wagon VR6 226k PP 5w30
1999 VW Jetta TDI 426k M1 5W40 TDT
Re: Can you ID the manufacturer of this battery? [Re: spavel6] #4647373
01/26/18 07:24 PM
01/26/18 07:24 PM
Atlanta
DuckRyder Offline
DuckRyder  Offline
Atlanta
The date sticker looks like Johnson Controls.
Isnít it a maintenance free battery (meaning you donít take the caps off to check the water).
Is it for a VW?
Robert
  • 2007 Toyota Prius Touring
  • 2005 Honda Civic Sedan
  • 1972 Ford F100
Re: Can you ID the manufacturer of this battery? [Re: spavel6] #4647387
01/26/18 07:36 PM
01/26/18 07:36 PM
Boston, MA
spavel6 Offline OP
spavel6  Offline OP
Boston, MA
After doing some Google Image searching, I believe this is a H6-AGM, potentially BMW brand. If you look at this image from a DIY battery replacement, the OEM BMW battery that is being removed has the same caps. Good news is, I won't have to worry about the water level, and definitely scored a better battery than anticipated!
Re: Can you ID the manufacturer of this battery? [Re: spavel6] #4647407
01/26/18 08:00 PM
01/26/18 08:00 PM
CA
CharlieBauer Offline
CA
The sticker is the Interstate type which is then reused across various brands that Interstate supplies.
Don't know if you can say for sure it's an AGM battery though.
It ain't what you don't know that gets you into trouble. It's what you know for sure that ain't so.
- mistakenly attributed to Mark Twain
Re: Can you ID the manufacturer of this battery? [Re: spavel6] #4647592
01/27/18 01:59 AM
01/27/18 01:59 AM
Where the wind comes sweepin'
Reddy45 Offline
Reddy45  Offline
Doesn't JC still use the angled corner caps that cover 3 cells each? I worked at a Interstate battery store while in college (some 10+ years ago anyway) and pretty much all of the JCI batteries we sold looked identical physically, but were different colors depending on the tier. Anything we sold that looked different was a different brand (Optimas, and then Odyssey powersport batteries).
Re: Can you ID the manufacturer of this battery? [Re: Reddy45] #4647658
01/27/18 07:16 AM
01/27/18 07:16 AM
Champlain/Hudson Valley
Kira Offline
Kira  Offline
Do those "caps" turn, or are they plugs?
Turn the battery on its side. Chop it apart with a fire axe and look at the top from beneath.
Re: Can you ID the manufacturer of this battery? [Re: Kira] #4647665
01/27/18 07:21 AM
01/27/18 07:21 AM
Boston, MA
spavel6 Offline OP
spavel6  Offline OP
Boston, MA
They are one-way security tops, so no real way of unscrewing them. Can't tell if they are supposed to turn or not..
Re: Can you ID the manufacturer of this battery? [Re: spavel6] #4647684
01/27/18 07:53 AM
01/27/18 07:53 AM
Lyndhurst NJ
Audios Offline
Audios  Offline
Lyndhurst NJ
Looks exactly like an Interstate that I stock, especially the sticker. Most times though, its only the sticker that changes, it could be an Exide/Interstate/Johnson. All good names.
2002 VW Golf TDI-Mobil 1 5/40 TDT
2007 Mercedes GL320 CDI Fuchs 5/40 GT Pro XTL
2005 BMW M3 BMW Twin Power 10/60
2003 BMW M5-Fuchs 5/40
1998 BMW M3/4/5 Fuchs 5/40
Re: Can you ID the manufacturer of this battery? [Re: spavel6] #4647762
01/27/18 08:51 AM
01/27/18 08:51 AM
Charlotte, NC
Oldmoparguy1 Offline
Charlotte, NC
I've seen one like that some years ago, pretty sure it was at a local Sams Club.
A Randomly Selected Thought For The Day:
If Noah had used Zip, he could have used a smaller boat.
Re: Can you ID the manufacturer of this battery? [Re: Reddy45] #4647794
01/27/18 09:23 AM
01/27/18 09:23 AM
MI
HorseThief Offline
HorseThief  Offline
MI
Not if the battery group size calls for a sealed construction. Newer style batteries like group 48 are built to be able to be mounted in the vehicle cabin or trunk. They have sealed fill holes and a side vent that can be attached to a vent tube that goes outside the cabin or trunk.
It's a JCI product going by the date code sticker style.
Have you had the battery load tested? In my experience the only reason a used battery seller will remove the label is because the battery does not meet the label CCA.
I saw a brown dog
Re: Can you ID the manufacturer of this battery? [Re: HorseThief] #4648110
01/27/18 03:24 PM
01/27/18 03:24 PM
Boston, MA
spavel6 Offline OP
spavel6  Offline OP
Boston, MA
I hooked it up to my AutoMeter SB-300 and it's showing good with somewhere around 650 CCAs.
Re: Can you ID the manufacturer of this battery? [Re: spavel6] #4648228
01/27/18 05:56 PM
01/27/18 05:56 PM
New Zealand
Silk Offline
Silk  Offline
New Zealand
That's what we call a DIN battery, with the posts set down level with the top face, usually found in European vehicles.
1987 BMW R65 - Aegis SAE30
2005 Nissan Expert - Gulf Western 10W-40
1996 Volvo T5 - Penrite HPR15 - 15W-60. Ryco syntec filter.
