Anti-Counterfeiting packaging
by sloinker. 01/17/19 09:13 PM
Heavy Snow Predicted for Northeast Sat/Sun
by Donald. 01/17/19 08:34 PM
Pennzoil Ultra Plat 5w30 1.4L T Chevy Cruze 10k
by SubieBlue. 01/17/19 08:03 PM
Coated rotors
by supton. 01/17/19 07:51 PM
Good samaritan
by JLTD. 01/17/19 07:15 PM
Doing suspension work. Need alignment?
by HawkeyeScott. 01/17/19 05:45 PM
100mg CBD Cannabis Gel
by Al. 01/17/19 05:36 PM
Electric Car "Green Test"
by redbone3. 01/17/19 05:06 PM
Want to try a uoa
by Dylan1303. 01/17/19 04:56 PM
Happy Birthday, Betty White!
by eljefino. 01/17/19 04:20 PM
Fram Ultra for Ecoboost 2.7
by Purpfox. 01/17/19 04:10 PM
Idle Speed / 1998 Olds 88
by Mark72. 01/17/19 03:28 PM
Heat blanket for your oil filter!
by MrWideTires. 01/17/19 03:24 PM
Proper oil viscosities.
by Bullwinkle007. 01/17/19 03:20 PM
44$ for 5 gals of home heating oil treatment!
by Audios. 01/17/19 03:05 PM
Good job Hyundai!!!
by Andy636. 01/17/19 02:43 PM
PP 0W-20 vs PP HM 0W-20 - Difference in VI
by The Critic. 01/17/19 02:34 PM
Dickerson888, Frisky, polarisman340, jfradella, Bigyetti83
66964 Registered Users
121 registered members (209paulc, 2015_PSD, 40w8, 4WD, 2009Edge, 11 invisible), 1,575 guests, and 36 spiders.
Topics296,753
Posts4,958,245
Members66,964
Most Online2,577
Jan 14th, 2019
2003 Civic Burning Oil - Dirty Piston rings? #4647200
01/26/18 04:20 PM
01/26/18 04:20 PM
MURICA
maverickfhs Offline OP
MURICA
Alright so I posted this thread https://bobistheoilguy.com/forums/ubbthreads.php/topics/4647014#Post4647014 and was suggested to try HM oil and all.
I saw post by Trav : https://bobistheoilguy.com/forums/ubbthreads.php/topics/3990078/1 and another one where few ideas are suggested : https://bobistheoilguy.com/forums/ubbthreads.php/topics/3990497/2 for cleaning piston rings/valves
My question is, can it be same problem on my Civic? If so, can I use MMO/B12 Chemtool which are easily available on Walmart to try the cleaning? Thanks for all the help thumbsup
2006 Civic EX 205K/AT
2006 Acura TSX 187K/AT
Re: 2003 Civic Burning Oil - Dirty Piston rings? [Re: maverickfhs] #4647221
01/26/18 04:46 PM
01/26/18 04:46 PM
Illinois
tig1 Offline
tig1  Offline
Illinois
If the rings are actually coked(sealed shut by hard carbon)that is a hard nut to crack. Ring coking is caused by too long of OCIs typically with dino. Myself, I have never had that issue.
2007 Ford Fusion 236,000 miles
M1 0-20 EP
2017 Ford Fusion 62K
M1 0-20 EP
M1 ATF and Valvoline LV
M1 10-30 in all OPE
MC filters
Re: 2003 Civic Burning Oil - Dirty Piston rings? [Re: tig1] #4647241
01/26/18 05:09 PM
01/26/18 05:09 PM
wv
krismoriah72 Offline
wv
First you need to determine if you are burning oil (we assume you are).
The easiest way- bundle up some clean toilet paper or paper towels and put near the exhaust tip while someone gives it fuel after its warmed up- you should see some oil splatter and darkening of the toilet paper after a minute or so.
The next is to read your plugs- you will see clearly whats going on inside of your combustion chamber.
Do you have coked rings? or do you have leaking valve seals?
Valve seals- blue smoke will be obvious on startup and deceleration- you may have to switch to conventional oil to see it clearly.
To attack your coked rings you will have to pull your plugs anyways so plan on doing that soon regardless.
Let us know how your plugs look along with the toilet paper test and the startup/deceleration tests...to help you attack whats wrong.
Re: 2003 Civic Burning Oil - Dirty Piston rings? [Re: tig1] #4647243
01/26/18 05:10 PM
01/26/18 05:10 PM
MURICA
MURICA
Please forgive my ignorance, but we have been very religious about oil changes. Usually after every 3K-5K with an oil filter.
This problem started after we had to put a re-manufactured head, are rings coking happening in the head or bottom area?
Re: 2003 Civic Burning Oil - Dirty Piston rings? [Re: krismoriah72] #4647244
01/26/18 05:11 PM
01/26/18 05:11 PM
MURICA
MURICA
Thanks for your helpful and sound advice. I'll take pictures of plugs tomorrow.
There's no visible smoke in terms of burning or anything and no dripping of oil either? frown
Re: 2003 Civic Burning Oil - Dirty Piston rings? [Re: maverickfhs] #4647332
01/26/18 06:48 PM
01/26/18 06:48 PM
Texas
FZ1 Offline
FZ1  Offline
Texas
O.K. So,then,the problem is with the reman head/installation. Beyond my pay grade. Sorry.
Re: 2003 Civic Burning Oil - Dirty Piston rings? [Re: maverickfhs] #4647416
01/26/18 08:16 PM
01/26/18 08:16 PM
Illinois
tig1 Offline
tig1  Offline
Illinois
Ah! New info brought to the table.
M1 0-20 EP
M1 0-20 EP
M1 10-30 in all OPE
MC filters
Re: 2003 Civic Burning Oil - Dirty Piston rings? [Re: maverickfhs] #4647422
01/26/18 08:22 PM
01/26/18 08:22 PM
British Columbia, Canada
ecotourist Offline
ecotourist  Offline
That used to happen "all the time". People would need to rebuild a head, typically because of a burned valve, and when they put it back together the engine would burn oil.
That happened to me when I rebuilt the heads on a Ford 289 V8. It went from using a little oil to being a smoker overnight.
Nowadays it doesn't see to be as much of a problem. Don't know why. Closer tolerances for the original rings? Less wear of the rings due to better oils? Closer tolerances for the cylinders? Less cylinder wear due to better oils?
2000 BMW 528i 5MT
2007 Honda Accord EX-L 4Door V6 6MT
Re: 2003 Civic Burning Oil - Dirty Piston rings? [Re: maverickfhs] #4647478
01/26/18 09:25 PM
01/26/18 09:25 PM
South Carolina
eyeofthetiger Offline
South Carolina
Losing a quart every 500 miles seems like too much to not have any smoke or drips. It's going somewhere. Need more info. confused
2017 Ford Fiesta 1.0T - Valvoline SynPower 5W-20, Motorcraft FL910S
1988 GMC K1500 4.3/700R4 - Supertech 15W-40, Fram TG3980
1986 Ford Ranger 2.0 - uhh
Re: 2003 Civic Burning Oil - Dirty Piston rings? [Re: eyeofthetiger] #4647481
01/26/18 09:28 PM
01/26/18 09:28 PM
MURICA
MURICA
I am going to pull spark plugs tomorrow and will share pictures. I am stumped too frown
Re: 2003 Civic Burning Oil - Dirty Piston rings? [Re: maverickfhs] #4647661
01/27/18 07:16 AM
01/27/18 07:16 AM
Western NY state
Truckedup Offline
Truckedup  Offline
Western NY state
No smoke from the exhaust on newer vehicles using a quart every 500 miles being lost through the rings and or valve quides is not unusual..
World's second fastest vintage Triumph 650, 133 MPH
Re: 2003 Civic Burning Oil - Dirty Piston rings? [Re: maverickfhs] #4648524
01/27/18 11:11 PM
01/27/18 11:11 PM
Indy
69Torino Online sleepy
69Torino  Online Sleepy
Indy
Possibly the valve guides are worn, or were knurled in the reman process. Knurling is an old practice and not the best way to repair valve guides because it can create an oil burner. Replacing the guides is the correct practice. Unfortunately there is no way to know which repair was done (if any at all) without a tear down.
1969 Ford Torino GT 390 Auto
2003 Mercury Marauder
1992 Mercury Capri Convertible
2005 Ford Freestyle
2008 Hyundai Santa Fe
2015 Kia Optima
1947 Ford 2N
1978 Honda XL75
Plus Other Stuff...
Re: 2003 Civic Burning Oil - Dirty Piston rings? [Re: maverickfhs] #4652026
01/31/18 12:08 PM
01/31/18 12:08 PM
ottawa
nicholas Offline
nicholas  Offline
ottawa
Try BG EPR - This stuff was the bees knees for our oil burning crummy ringed audi.
