Originally Posted By: MetalSlug
But thing that make me hate fram one and for all is those fram rep that push user to use their filter .
I think you need to post up such links to prove that. I see nobody "pushing" anyone to use any certain filter. People talk about the good and the bad of oil filters in their opinion, and the filters they like for the reasons they like them. The people who are believable have facts and data to back-up what they say. People read what people say and then make up their own minds on what to use. You must have a different way of interpreting what people are saying, but again I challenge you to show where someone has "pushed" anyone to use a certain filter here.
I’m not going to search for it . But here is few example that I seen . One guy cut open a filter with UOA . It’s came back good and Blackstone actually told them that they can go longer xxxx amount of miles . Ok that good right . Then few came and suggest using this fram because it’s cheaper and better micron rating or better efficiency or what ever . Then more peoples came pretent to agree with it . If the owner happy with old set up and the test came back perfect . Why would you suggest your product for ?
I seen peoples nip pick about little residua inside the filter . Or some spot on filter is having more glue . Or filter having little wayvy after 5000 miles . Then turn around suggest fram TG
. That sad . When I saw that and for being here for so long and know and seen true about the fram. It’s just sad
Go YouTube . Go other car performing site . Yellowbullet . Ls1 tech . Svtperformance . TOYOTA Supra forum and try suggest fram . It’s won’t work there . Even YouTube . Go on there and suggest fram is best filter in the world on one of those cut open comparing oil filter video . It won’t work there either . Fram is having very bad rep since 06-08 . It won’t change peoples mind now . Even ultra still won’t save them bad rep
I knew countless peoples that want fram TG to use metal end cap for years . But fram won’t listen . They don’t care . “ if you want metal end cap pay more and buy my ultra “
What you are describing above is not "pushing" in my book ... it's exactly what I've described - information is being given and its up to the reader to decide what's good or not and go from there. That's how this world operates in almost everything you do. You or anyone else here makes up their own mind on what they want to use based on how they interpret the information being laid out by members here. Nobody is forcing or pushing anyone else to use a certain filter. If someone thinks that then they can't think for themselves it seems.
And the uninformed people on YouTube or where ever don't even know a great filter half the time, and probably most of them are super biased because of the name on the can. It's guys like that that can't be trusted to give any kind of accurate opinion on stuff because they are blinded by brand hate. Many here see that the EG and TG are not bad filters ... they are a lot better than a lot of stuff because they don't fail and they have good efficiency. The EG is just as efficient or better than most filters on the market. Yeah, I shouldn't say anymore because someone might think I'm a "bully" Fram "rep" that's "pushing" to make someone use those filters. If anyone is that easily swayed then I have some beach front property at the north pole to sell you.
If every member here was labeled a "Fram Rep" because they said something good about a Fram, then half the chat board would be "working for Fram".
