Bank 1 on an Equinox
by Washoe_Mark. 03/20/19 08:47 AM
How do you pronounce the word Vehicle?
by ZZman. 03/20/19 08:21 AM
Inline Fuel Filter
by CCI. 03/20/19 08:08 AM
Are All Douglas Tires USA Made?
by Miller88. 03/20/19 07:30 AM
Turn signal bulbs for '15 BMW?
by Benzadmiral. 03/20/19 07:02 AM
Drain/refill vs diy flush?
by Back40. 03/20/19 05:59 AM
Valvoline 5w30 Synpower HSTS?
by avi1777. 03/20/19 05:05 AM
Castrol Edge 5W50 "Supercar Titanium FST"
by Berto. 03/20/19 02:43 AM
The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Ford 2019 F350 oil
by arowbat. 03/19/19 11:04 PM
Royal purple discontinuing 30-1218 ?
by jmj540. 03/19/19 10:02 PM
Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Saxman657, Maxxforce, Washoe_Mark, CG_BrianM, TBF
67565 Registered Users
113 registered members (2015_PSD, 69Torino, 2012AccentSE, addyguy, 2010Civic, 69GTX, 13 invisible), 1,783 guests, and 52 spiders.
Topics286,112
Posts4,902,857
Members67,565
Most Online2,967
Mar 10th, 2019
VW 502.00/505.00 vs. 502.00/505.00/505.01 #4646962
01/26/18 01:45 PM
01/26/18 01:45 PM
Calgary, Canada
nielkfj Offline OP
nielkfj  Offline OP
Calgary, Canada
I have a 2013 VW GTI with the 2.0T engine (gasoline engine). I'm looking for a VW 502.00 approved oil for my next oil change.
Most (if not all) brands on the market that are 502.00 approved are also 505.00 approved. However, there are also brands that include the 505.01 approval for VW's "Pumpe-Düse" diesel engines. According to the web page linked below, 505.01 is a higher specification than 502.00 - better wear performance in particular.
https://www.oilspecifications.org/articles/vw_motor_oil_specifications_explained.php
So, I'm thinking that a 502.00/505.00/505.01 approved oil would protect my car engine better than a 502.00/505.00 approved oil. However, the 502.00/505.00/505.01 oils are typically marketed for diesels, so I'm not sure if my reasoning is correct.
Any opinions about this would be appreciated.
Re: VW 502.00/505.00 vs. 502.00/505.00/505.01 [Re: nielkfj] #4646972
01/26/18 01:53 PM
01/26/18 01:53 PM
Huntington WV
dbias Offline
dbias  Offline
Huntington WV
Go with something that is 502 and Porsche 40.
2011 VW JETTA Castrol Edge 0W-40
2012 FORD TRANSIT CONNECT Castrol Edge 5W-20
2016 HONDA CIVIC COUPE Frankenbrew 0W-20 to 5w-40
2017 AUDI A4 Mobil1 0W-40
Re: VW 502.00/505.00 vs. 502.00/505.00/505.01 [Re: dbias] #4646976
01/26/18 01:57 PM
01/26/18 01:57 PM
North Carolina
rooflessVW Online content
rooflessVW  Online Content
North Carolina
And M229.5 with a little LL01 sprinkled on top.
"Zed's dead baby, Zed's dead."
Re: VW 502.00/505.00 vs. 502.00/505.00/505.01 [Re: nielkfj] #4646989
01/26/18 02:08 PM
01/26/18 02:08 PM
Colorado Springs
edyvw Offline
edyvw  Offline
Colorado Springs
This topic is dissected numerous times.
Get Castrol 0W40 in Wal Mart. If not make sure oil has MB229.5 spec. next to VW502.00.
15' Toyota Sienna AWD (Mobil1 5W30 EP+OEM filter).
11' VW Tiguan 2.0T (Castrol 0W40+MANN filter)
Re: VW 502.00/505.00 vs. 502.00/505.00/505.01 [Re: nielkfj] #4647069
01/26/18 03:10 PM
01/26/18 03:10 PM
Parts Unknown
UG_Passat Offline
UG_Passat  Offline
Parts Unknown
VW505.01 is made to shear down early, then the viscosity builds up with soot loading. This was back in the pre-ULSD days, when the Pumpe-Duse (BEW) engine was introduced in 2004. With 5,000 mile changes, that is typically done on 2.0T's (FSI and TSI), it's actually worse than a regular 505.00 oil.
In fact, cam shaft wear was still a problem using 505.01 oils on the PD engines.
2016 VW Tiguan|APR Stage 1|Neuspeed P-Flo|Osram CBI|Redline 5w30
Re: VW 502.00/505.00 vs. 502.00/505.00/505.01 [Re: nielkfj] #4647141
01/26/18 04:25 PM
01/26/18 04:25 PM
Down Under
SR5 Offline
SR5  Offline
Down Under
Castrol Edge 0W40 - SN, A3/B4, VW502.00 / 505.00, MB 229.5, BMW LL-01, Porsche A40.
Castrol GTX Ultraclean 15W40 A3/B3 + Wesfil-Cooper Z154
Re: VW 502.00/505.00 vs. 502.00/505.00/505.01 [Re: nielkfj] #4647300
01/26/18 07:24 PM
01/26/18 07:24 PM
Calgary, Canada
nielkfj Offline OP
nielkfj  Offline OP
Calgary, Canada
Thanks for the recommendations. I'm going through some other threads on the subject now.
The Castrol Edge 0W-40 looks good - I didn't realize that it had Group IV base oil, and NOACK less than 10%.
One follow-up question I have at the moment is: Using the Castrol (Canada) oil selection tool, there is the regular Castrol Edge 0W-40 and there is a Castrol Edge "Professional" 0W-40 which apparently is only sold at dealerships. From the data sheets it looks like there are some slight differences between them. Does anyone have an opinion about which is better?
Re: VW 502.00/505.00 vs. 502.00/505.00/505.01 [Re: SR5] #4647947
01/27/18 12:41 PM
01/27/18 12:41 PM
Calgary, Canada
nielkfj Offline OP
nielkfj  Offline OP
Calgary, Canada
SR5:
Are you able to confirm that Castrol Edge 0W-40 uses a Group IV base stock?
A user made that claim in another tread:
https://bobistheoilguy.com/forums/ubbthreads.php/topics/4299455/Re:_Liqui_Moly_Comparison#Post4299455
I have tried to verify it by searching on the internet, but haven't found anything.
Re: VW 502.00/505.00 vs. 502.00/505.00/505.01 [Re: nielkfj] #4648581
01/28/18 03:20 AM
01/28/18 03:20 AM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
Assuming the specs are equal (or close enough), then the one that you can get more readily and more cheaply (i.e. regular Castrol Edge 0w-40) will be "better." I can't see any trip to a dealer for oil in this country being cost effective.
Plain, simple Garak.
Re: VW 502.00/505.00 vs. 502.00/505.00/505.01 [Re: nielkfj] #4649056
01/28/18 01:49 PM
01/28/18 01:49 PM
Calgary, Canada
nielkfj Offline OP
nielkfj  Offline OP
Calgary, Canada
Garak:
Thanks for the advice, I'm leaning that way too because so far I haven't found any place that sells Edge Pro 0W-40. Regular Edge 0W-40 (probably made in Belgium) is available at Wal-Mart for about $6.50/litre.
But one question I have about the Regular version is whether it is made from group IV base stock. Here are data sheets:
Regular Edge Product Line (Black Bottle) - data sheet from Castrol Canada:
https://msdspds.castrol.com/bpglis/FusionPDS.nsf/Files/B454A10084ABA20980258183005612AA/$File/BPXE-9LWGQK.pdf
Edge Pro Product Line (Gold Bottle) - data sheet from Castrol USA:
https://msdspds.castrol.com/bpglis/FusionPDS.nsf/Files/4ABA633F17A143FD80257AA90053665B/$File/EDGE%20Professional%20European%20PDS_July_2012.pdf
In particular, the pour point for regular Edge 0W-40 is -53C, whereas for Edge Pro 0W-40 it is -60C. So perhaps this is an indication that Regular Edge is made from HC base stock. What do you think?
2013 VW GTI Base Model (Canadian) - 100% stock
Re: VW 502.00/505.00 vs. 502.00/505.00/505.01 [Re: nielkfj] #4649534
01/28/18 09:35 PM
01/28/18 09:35 PM
Parts Unknown
UG_Passat Offline
UG_Passat  Offline
Parts Unknown
Garak:
The Edge 0w40 A3/B4 is in a black bottle for the US. If you look at that SDS, the CAS Number for the base stock matches up with:
http://www.cpchem.com/msds/100000010950_SDS_EU_EN.PDF
Re: VW 502.00/505.00 vs. 502.00/505.00/505.01 [Re: nielkfj] #4649708
01/29/18 03:11 AM
01/29/18 03:11 AM
Garak Offline
Garak  Offline
There is quite likely significant PAO content in the retail Edge 0w-40. I can't think of any ordinary HC base stock with a pour point like that in a 40 grade. In any case, I wouldn't worry in the least, given the specs it meets, too. With respect to price, also keep an eye on Canadian Tire, Part Source, and NAPA.
Re: VW 502.00/505.00 vs. 502.00/505.00/505.01 [Re: Garak] #4650491
01/29/18 07:19 PM
01/29/18 07:19 PM
Calgary, Canada
nielkfj Offline OP
nielkfj  Offline OP
Calgary, Canada
Ok, thanks all for the advice.
I’ll probably go with the Castrol Edge 0W-40. I am also considering trying to find some older German made stock which apparently contains higher amounts of PAO compared to the current Belgian made version.
But the Belgian made version appears to be have "Fluid Titanium Technology", whatever that means. Does anyone know, is this just a marketing gimmick or is this really an improvement to the formulation?
Re: VW 502.00/505.00 vs. 502.00/505.00/505.01 [Re: nielkfj] #4651701
01/31/18 04:39 AM
01/31/18 04:39 AM
Garak Offline
Garak  Offline
I don't think any of us could really say if there's a significant improvement, or a minor improvement followed by a major marketing push. wink In any case, I'd be confident in whatever you happen to find on the shelves. You know how it is in Canada. You could find 3 year old bottles at one location, and something fresh off the truck next door.
Re: VW 502.00/505.00 vs. 502.00/505.00/505.01 [Re: nielkfj] #4652253
01/31/18 04:43 PM
01/31/18 04:43 PM
San Francisco, CA
Flying_A Offline
Flying_A  Offline
San Francisco, CA
The one thing I haven't seen people mention is that 502/505/505 01 oils generally are mid SAPS C3 oils product where 502/505 are always full SAPS A3/B4- so the 502/505 products will have a higher ash% meaning more zinc, phos, calcium etc.
Porsche A40 is essentially the same test as VW 502.
