The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Ford 2019 F350 oil
by arowbat. 03/19/19 11:04 PM
Royal purple discontinuing 30-1218 ?
by jmj540. 03/19/19 10:02 PM
Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Can I Use Maple Syrup Instead Of Oil ?
by Warstud. 03/19/19 06:09 PM
Should criminals be given a second chance?
by ZZman. 03/19/19 04:28 PM
Oil recommendations for old car
by chromedome. 03/19/19 04:06 PM
Reply Box Window
by das_peikko. 03/19/19 03:45 PM
mm2020, emepher, headoff93, yahtzee, jmd
67560 Registered Users
32 registered members (claluja, aleneros, berniedd, Brad_C, Chesterr, 2 invisible), 625 guests, and 65 spiders.
Topics286,097
Posts4,902,476
Members67,560
Most Online2,967
Mar 10th, 2019
bearing wear #4646739
01/26/18 09:55 AM
01/26/18 09:55 AM
Golden Meadow, LA
mobilaltima Offline OP
Golden Meadow, LA
the question is regarding the F250 in my sig. A few weeks ago we had some cold weather, well cold for down here. it was between 25-35 most of the week. One morning, 29 degrees, I cycled the glow plugs twice, and tried to start it, it turned over but wouldnt start. I tried again it started, blew a ton of white smoke, ran for 2 seconds and shut off. I then tried a second time where it turned over, and then turned over, smoked, ran for 2 seconds before I gave up. A few days later, it was pretty cold again, I cycled the glow plugs 3 times, but each time after the light went it out, I waited till I heard a click, which I assume was the glow plug relay. The truck started without a hiccup. Would that cold start failure have caused significant damage to the bearings? The L-H oil pressure gauge on the dash looks like its reading a tad bit lower than usual, might just be me worrying for nothing. Not sure if the gauge is a dummy gauge or not. Anyhow, truck still runs great. Just changed the oil with some Motorcraft 15W40 and a Napa gold 1734, I'll do a UOA in 5k miles, first one ever for this truck. It'll have 237k at the time of the UOA.
2006 2500 Dodge 5.9 Cummins Mobil Delvac 15W40, Fleetguard Stratapore 90k miles
Early '99 F250 ECLB 7.3 Stroker, 223k miles
Re: bearing wear [Re: mobilaltima] #4646766
01/26/18 10:19 AM
01/26/18 10:19 AM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
I doubt it built up enough cylinder pressure to load the bearings hard. The fuel wasn’t atomizing properly and there was incomplete combustion, so there wouldn’t be high pressures involved in my humble opinion. Check your owners manual. They probably allow 10W-30 for the winter, or better yet 0W-40 synthetic. Yes, I know no one in Louisiana does that. LOL.
If you want the job done right......do it yourself.
Re: bearing wear [Re: mobilaltima] #4646777
01/26/18 10:28 AM
01/26/18 10:28 AM
MN
Tman220 Offline
Tman220  Offline
MN
It's possible a little more fuel than usual ended up past the rings and into the sump due to the failed starting attempt, but rest assured it most likely not enough to record noticeably less oil pressure, let alone bearing wear.
We have proven from DI gasoline engines it takes a TON! of fuel oil dilution to register any difference in a UOA as far as wear numbers go. In addition, the prolonged cranking from the failed starting attempt kept the bearings supplied with oil. Any time the engine is spinning, oil is being moved, the oil pump is surely a positive displacement pump.
These engines get fired up and run with 15W40 in much colder climates than you experience and there really isn't any discernible difference in engine longevity.
By the way I am almost positive those oil pressure gauges are in fact dummy gauges, so any small changes in oil pressure would be impossible to detect with the gauge.
2012 Regal GS Turbo PP 5w30
1994 Camaro Z28 LT1 355 CI, 430 RWHP PP 5W30
Re: bearing wear [Re: mobilaltima] #4646790
01/26/18 10:36 AM
01/26/18 10:36 AM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
Other than worry, what are you gonna do? 223 K miles has given the insides a little play. IF you are really worried , change the oil ASAP.and send off a sample so you can sleep at might.
Thick oil is better grin2
Re: bearing wear [Re: mobilaltima] #4647101
01/26/18 03:35 PM
01/26/18 03:35 PM
Northern Ontario, Canada
Danno Offline
Danno  Offline
In my experience, we had numerous no starts with the 7.3L in temps down to -40F. I ran a fleet with hundreds of 7.3s in the fleet. A great engine that just won't die. I think I lost one crankshaft over many years - due to low oil. Don't lose sleep over your experience.
2016 Sorento SX V6 AWD
2015 KIA RIO SX
2010 Mazda 3 2.0L
2009 Venza V6 AWD
2013 Sonata 2.4L RIP in write-off crash
Re: bearing wear [Re: mobilaltima] #4653547
02/01/18 11:15 PM
02/01/18 11:15 PM
Conroe, TX
NVRENUFF Offline
NVRENUFF  Offline
Conroe, TX
I wouldn’t worry about bearing wear due to starts like that. Those HUI injectors use high pressure oil to pop them, so you must have oil flowing before it cranks anyway. Could be as simple as needing a glow plug change. My duramaxs and cummins Fire right up in the cold, but my IDI trucks need the glow plugs nice and hot to start. When they start having issues in the cold, a quick glow plug swap cures the issue.
Re: bearing wear [Re: mobilaltima] #4657536
02/06/18 12:45 AM
02/06/18 12:45 AM
Rio Rancho, NM
Pajero Offline
Pajero  Offline
Rio Rancho, NM
Not to change subject. But, do they still write a lot of tickets in Golden Meadow? I've heard stories........
Respectfully,
Pajero!
Always remember "Planned obsolescence."
1994 Montero SR 3.5 DOHC, 133,xxx
Fram Ultra/ Snorkel with Pre-filter
K-9-Co-pilot
Re: bearing wear [Re: mobilaltima] #4657570
02/06/18 03:15 AM
02/06/18 03:15 AM
Golden Meadow, LA
Golden Meadow, LA
yes they sure do, it has not and never will change. But whats sad is people who have businesses in the town , or one guy I went high school with, his grandfather was police chief in the 70s, they can speed amongst other things and not worry about getting ticketed.
Re: bearing wear [Re: mobilaltima] #4658805
02/07/18 09:21 AM
02/07/18 09:21 AM
The American West
bbslider001 Offline
bbslider001  Offline
The American West
Plain and simple, you need glow plugs or a glow plug relay. It's all unburnt fuel. You'd do much better going over to Ford Truck Enthusiast forum or Powerstroke Nation and read up over there. what you are experiencing is common with the 7.3 and most don't find out until cold weather hits.
Byron
1999 F-350 CCLB SRW 7.3, Supertech 15w-40 protected, 300k miles
1997 F-350 CCLB DRW 7.3, SOLD
2015 Kia Soul Plus
Re: bearing wear [Re: mobilaltima] #4733598
04/20/18 10:27 PM
04/20/18 10:27 PM
MD
amcguru Offline
amcguru  Offline
MD
Great truck & great engine, but the glow plug relay is a maintenance item on those.
'16 Mercedes C300 -M1 5w40 formula M, OE filter
'03 Ford Excursion 7.3 PSD -Schaeffer 9000 5w40, Donaldson ELF7405
Re: bearing wear [Re: mobilaltima] #4738170
04/25/18 09:01 AM
04/25/18 09:01 AM
Ocala, Florida
racin4ds Offline
racin4ds  Offline
Ocala, Florida
GLOW PLUGS! with over 200K and you've never changed them, they are due!! The 7.3 was "cranky" in the cold, always was. Don't worry one bit about the bearings/bottom end, it hasn't hurt a thing and with 200K the 7.3 is just broken in!
I highly recommend switching to a 10W30 oil though, I was a long time believer in "15W40 only for a diesel" but man these HUEI systems love a 10W30! My 6.0 started and ran like a different truck when I switched especially when I was in northern VA and it got cold!
Just say NO to thin oils and M1!
05 F350 Powerstroke
05 Hyundai Tucson
08 Legacy GT
Re: bearing wear [Re: mobilaltima] #4738189
04/25/18 09:23 AM
04/25/18 09:23 AM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
Trouble shoot before changing parts . Make sure the batteries are good. My wife has a 2002.7.3 and the batteries never make 3 years before needing replacing.
2015 Ford F150 2.7
2018 Ford F350 6.2
