Air Fryer....whose got'em?
by Schmoe. 01/16/19 01:59 PM
ebates - anyone a member?
by Papa Bear. 01/16/19 01:29 PM
Ordered a 2019 X5 for the Wife
by gofast182. 01/16/19 12:48 PM
Today, I ride
by SirTanon. 01/16/19 12:02 PM
2019 Nissan Rogue SL
by JTK. 01/16/19 11:19 AM
Does GM oil life monitor % go down without driving?
by Corollaman. 01/16/19 10:37 AM
Ford tire wear issues?
by Redright9. 01/16/19 10:23 AM
New Battery
by CarlGR. 01/16/19 10:21 AM
It's January and I Need My Motorcycling "Therapy" !!
by LoneRanger. 01/16/19 10:13 AM
Are New Vehicles Too Expensive?
by SubLGT. 01/16/19 10:02 AM
Manual transmission fluid in Europe for Mazda
by zsero. 01/16/19 07:31 AM
Affected by the gov't shutdown?
by xBa380. 01/16/19 07:04 AM
Opinion Needed / 1998 Olds 88
by Mark72. 01/16/19 06:24 AM
Chevron Supreme color change
by OilUzer. 01/16/19 05:14 AM
Dual exhaust benefits
by OilUzer. 01/16/19 03:02 AM
M1 0w40
by Pinoak. 01/16/19 01:55 AM
M1 0w40
by Pinoak. 01/16/19 01:51 AM
The best in personal defense (Humor)
by StevieC. 01/15/19 11:10 PM
VV03, Witchipoo, Durco1977, ConnorM, dkar26
66950 Registered Users
107 registered members (AandPDan, 97f150, advocate, anndel, 2015_PSD, Ag76, 12 invisible), 2,284 guests, and 30 spiders.
Topics296,642
Posts4,956,475
Members66,950
Most Online2,577
Jan 14th, 2019
Page 1 of 3 1 2 3
Led headlights... #4646352
01/25/18 08:24 PM
01/25/18 08:24 PM
FL, USA
gregk24 Offline OP
gregk24  Offline OP
FL, USA
I have seen so many of these "burnt out" on new cars. Whats the deal? I thought these were supposed to last a lot longer then halogen. I do like how they look, they certainly dress up a vehicle if the manufacture designs them right, but I can only imagine how expensive that can be since the whole headlight has to be replaced when they go bad. Just a thought.
2012 Honda Accord EX-L K24z3
54,xxx miles
PPPP 0w20 / Fram Ultra
2014 VW Jetta SE 1.8T ea888
40,xxx miles
Castrol OEM dealer fill / OEM filter
Re: Led headlights... [Re: gregk24] #4646358
01/25/18 08:27 PM
01/25/18 08:27 PM
PimTac Offline
PimTac  Offline
My first guess is cheap Chinese leds.
Cannot see signatures any longer so it doesn’t matter.
Re: Led headlights... [Re: gregk24] #4646360
01/25/18 08:29 PM
01/25/18 08:29 PM
MURICA
maverickfhs Offline
maverickfhs  Offline
MURICA
Maybe it's me, but I usually see many burnt ones on german cars, maybe a coincidence? Noticed similar for halogens too.
2006 Civic EX 205K/AT
2006 Acura TSX 187K/AT
Re: Led headlights... [Re: gregk24] #4646371
01/25/18 08:43 PM
01/25/18 08:43 PM
Deplorable in apple valley, ca
Chris142 Online content
Chris142  Online Content
I hate em. They blind me.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Led headlights... [Re: gregk24] #4646378
01/25/18 08:53 PM
01/25/18 08:53 PM
MIchigan
Warstud Offline
Warstud  Offline
MIchigan
Your right there's alot of newish cars on the road with burnt out headlights. The ones I noticed aren't LED's though.
Re: Led headlights... [Re: gregk24] #4646381
01/25/18 08:58 PM
01/25/18 08:58 PM
Saskatchewan, Canada
Johnny2Bad Offline
Johnny2Bad  Offline
Might be because people are running the headlights as Daytime Running Lights when the vehicle is not equipped with DRLs.
If DRLs are part of the OEM Body&Frame computer, they either use the turn signal lamps or they use the High Beams wired in Series (which means you are running 12V into a 24V lamp set, so it's half brightness, or less than half brightness, vs high beams and dimmer than low beams). DRLs are required to be relatively dim and the MVSS will limit the lumens they can project.
They use the High Beams because DRLs in nations that require them must aim straight ahead, which low beams aren't designed to do. Turn signal lamps can be used because Canada allows amber or white for DRLs (European, UK, Russian, Japanese etc don't. This was done as a concession to the Big3 automakers who wanted to minimize parts differences in North American vehicles).
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
Re: Led headlights... [Re: gregk24] #4646385
01/25/18 09:06 PM
01/25/18 09:06 PM
NEUS
Bandito440 Offline
Bandito440  Offline
NEUS
I’ve seen lots of clowns who retrofit their halogen reflector housings with LEDs and HIDs. Those are frequently blown, but I can’t recall seeing too many factory setups that are out.
'14 Grand Cherokee EcoDiesel
Rotella T6 5w-40 & OEM filter
Re: Led headlights... [Re: gregk24] #4646405
01/25/18 09:24 PM
01/25/18 09:24 PM
Jupiter, Florida
Cujet Offline
Cujet  Offline
Jupiter, Florida
I see the LED eyebrow lights that double as daytime running lights, burned out, regularly. These are not headlights though, just mostly for show.
Re: Led headlights... [Re: Chris142] #4646408
01/25/18 09:30 PM
01/25/18 09:30 PM
San Antonio, TX
das_peikko Offline
das_peikko  Offline
San Antonio, TX
You sir took the words right out of my brain. Word theft.
Re: Led headlights... [Re: gregk24] #4646416
01/25/18 09:41 PM
01/25/18 09:41 PM
Maryland
malibuguy79 Offline
malibuguy79  Offline
Maryland
Im sick and tired of people buying PNP LEDs and stickin them into halogen housings increasing glare and reducing actual output on the ground. But bro they are so bright when I stand in front of em bro...
Greg...the exhaust guy
I have a 10 Yaris, 97 Tercel 1nzfe swap coming, 82 Malibu 1uzfe swap in progress, 84 Bonneville street/strip car
She has 18 Fit and 01 Forester
Re: Led headlights... [Re: gregk24] #4646420
01/25/18 09:46 PM
01/25/18 09:46 PM
upstate NY
dustyroads Offline
dustyroads  Offline
upstate NY
I see many LED daytime running lights out on newer GM pickups/SUVs as well as Dodge Chargers/Chrysler 300s. I don't see so many LED headlights/tail lights out, but I do see some.
I wish every vehicle on the road had LEDs, as they are much easier on my eyes on long overnight drives, especially in the rain. Some of the aftermarket LEDs are blinding if installed poorly or improperly. My Freightliner Cascadia has LED headlights and taillights (factory installed) made by Truck-Lite and I love them. When I go home and drive my F150 at night, it's almost as if I'm driving with my sunglasses on (comparatively speaking).
2013 F150 XLT 5.0 4X4 104k miles
Edge 5W-30 / Fram 10575
Re: Led headlights... [Re: gregk24] #4646422
01/25/18 09:49 PM
01/25/18 09:49 PM
Phoenix
dishdude Offline
dishdude  Offline
Phoenix
Remember the DRLs turn off on one side when turn signals on that side are turned on...at least on the GMs and Chryslers I've owned.
2018 Challenger SRT 392 PUP 0w-40 Wix 57899XP
2018 GTI
Re: Led headlights... [Re: gregk24] #4646424
01/25/18 09:51 PM
01/25/18 09:51 PM
Phoenix, AZ
Nick1994 Online content
Nick1994  Online Content
Phoenix, AZ
They burn out because people buy cheap ones off eBay.
My Sonata came with some and I hated the white light, so I put in Halogens (did the 9006->9011 bulb mod) and it's unbelievable how much brighter they are. Nice yellow color is easy to see, nice cutoff on the pattern, and more powerful.
2015 Hyundai Sonata 2.4L 89k Motorcraft Synthetic Blend 5w30 & OEM
2000 Toyota Camry 2.2L 232k Valvoline 5w30 & Fram Ultra
1996 Jeep Cherokee 4.0L 148k Mobil 1 HM 10w40 & Fram Ultra
Re: Led headlights... [Re: gregk24] #4646431
01/25/18 09:57 PM
01/25/18 09:57 PM
FL, USA
gregk24 Offline OP
gregk24  Offline OP
FL, USA
Correction: I am talking about stock OEM daytime running lights, not aftermarket.
54,xxx miles
40,xxx miles
Re: Led headlights... [Re: dishdude] #4646433
01/25/18 09:58 PM
01/25/18 09:58 PM
upstate NY
dustyroads Offline
dustyroads  Offline
upstate NY
Yup that's right, but I see many cruising the interstate with one of the DRLs out. No turn signal on. Whether they're a DRL or just a dress-up light, many are going out.
Page 1 of 3 1 2 3
