Just purchased a 2006 Honda Accord V6 with BAYA 5-Speed auto transmission. Car came with a stack of Honda dealer service invoices but nothing to indicate an ATF change. It appears the last two owners were waiting for the Maintenance Minder to tell them to service the Transmission. ATF fluid is purple in color but doesn't smell burnt. One Honda service invoice shows an additive added to the ATF and motor oil. Find this curious as my old 97 Civic owners manual specifies no use of oil additives.
Anyway, I've heard that apparently this transmission does not have a filter and that I should dump and fill the ATF for the next few oil changes, which I will probably do. Honestly, I'm kind of bewildered by what Hond's maintenance philosophy has become. Oh! And looks like I will be doing the timing belt, water pump, spark plugs, valve adjust for the first time as well thanks to the Maintenance Minder/procrastinator.
Any other suggestions?
