Old Laptop - Keeps Freezing - Help!
by reemoe2. 03/21/19 09:52 PM
Cinnamon Cake
by StevieC. 03/21/19 09:43 PM
AMALIE OILS
by kstanf150. 03/21/19 09:41 PM
oem filters
by mobilaltima. 03/21/19 09:34 PM
Magna1 10W30
by mobilaltima. 03/21/19 09:32 PM
Found triple threat
by deven. 03/21/19 09:26 PM
Chrysler Valvetrain week??
by clinebarger. 03/21/19 08:50 PM
Lisle funnel for radiator drain & fill
by paulri. 03/21/19 07:45 PM
Rattle in Catalytic Converter 2003 Suburban
by Fitz98. 03/21/19 05:59 PM
Mobil1 5W-30 EP, 8317mi, 2007 Prius Touring, 98133
by DuckRyder. 03/21/19 05:32 PM
Maxima Pro Plus 20/50 syn bike oil
by Truckedup. 03/21/19 04:54 PM
CHAMPION COS 3593A **NEW** CUT OPEN
by 53' Stude. 03/21/19 04:28 PM
NAPA PROSELECT 21348 CUT OPEN
by 53' Stude. 03/21/19 04:21 PM
Atlanta No Nonsense Honda dealer
by DuckRyder. 03/21/19 04:16 PM
Echo (PAS) - Good, Bad, Other?
by GemStater. 03/21/19 04:06 PM
Serpentine Belt - When To Change?
by Propflux01. 03/21/19 03:08 PM
Magnetic Out, ST in at Wally Auto Care Center.
by csandste. 03/21/19 02:26 PM
One license plate in a Two-Plate State
by bunnspecial. 03/21/19 02:07 PM
scottjeffrey, Mowata, LoneWolf04, Paperboy, Flinch
67579 Registered Users
78 registered members (Alfred_B, 2010Civic, Ama0787, ABCarr, 69GTX, 2015_PSD, 8 invisible), 1,503 guests, and 61 spiders.
Topics286,215
Posts4,904,411
Members67,579
Most Online2,967
Mar 10th, 2019
Should I seal slab before lay vinyl laminate floor #4646309
01/25/18 08:25 PM
01/25/18 08:25 PM
NJ
JLawrence08648 Offline OP
NJ
I have a 2 story house that is on a slab, garage, laundry room with tile floor, 1/2 bath with concrete floor, and 2 other rooms, den and bedroom, all are on the first floor slab.
I am removing the short nap carpeting and going to lay vinyl laminate plank flooring that has a thin rubber type backing. The flooring store, which also does installations, said this type of flooring does not need the floor to be sealed, nor a vapor barrier, nor any additional underlayment. However I would feel more comfortable sealing the floor. Should I not be concerned? We don't have a water table issue. Should the floor be sealed to prevent any moisture coming up? With what?
Re: Should I seal slab before lay vinyl laminate floor [Re: JLawrence08648] #4646325
01/25/18 08:38 PM
01/25/18 08:38 PM
VA
Gebo Offline
Gebo  Offline
VA
I would. I did. Listen to your guts. I used polyurethane 25 years ago. Got it in 5 gallon buckets. Used paint rollers to apply.
'98 LEX LS400 290K
'02 4Runner 230K
'05 Lex LS430 85K
'07 Lex GX470 65K
Amsoil in last two.
Schaeffer in the first two.
Re: Should I seal slab before lay vinyl laminate floor [Re: JLawrence08648] #4646336
01/25/18 08:52 PM
01/25/18 08:52 PM
Phoenix
dishdude Online content
dishdude  Online Content
Phoenix
If it already has the vapor barrier built in, you don't need it. What does the manufacturer say?
2018 Challenger SRT 392 PUP 0w-40 Wix 57899XP
2018 GTI
Re: Should I seal slab before lay vinyl laminate floor [Re: JLawrence08648] #4646342
01/25/18 09:00 PM
01/25/18 09:00 PM
NEUS
Bandito440 Offline
Bandito440  Offline
NEUS
Polyurethane won’t create a moisture barrier, if you need one.
Reference the instructions that come with your product. They’ll likely tell you to make sure the concrete is properly cured and dry. If you need a moisture barrier, plastic that’s at least 6 mils thick or a product like Pergo Gold 3mm underlayment will do the job. Be sure to tape the seams.
Here are the instructions from the Lowe’s Smartcore product that I used:
'14 Grand Cherokee EcoDiesel
Rotella T6 5w-40 & OEM filter
Re: Should I seal slab before lay vinyl laminate floor [Re: JLawrence08648] #4646394
01/25/18 10:14 PM
01/25/18 10:14 PM
out there
spasm3 Online content
spasm3  Online Content
out there
The living area of the slab , should have a vapor barrier under the concrete. The garage is any ones guess. I would take a 12x 12 or better a 2ft x 2ft piece of clear plastic sheeting and tape it to the garage floor. wait a few days or a week and see if there is any moisture under the plastic.
13 elantra 75k 5w30 QSUD
03 chevy avalanche 80k synpwr 5w30
17 mazda cx-5 9500 miles m1 0w30
Re: Should I seal slab before lay vinyl laminate floor [Re: JLawrence08648] #4646436
01/25/18 11:02 PM
01/25/18 11:02 PM
MI
doitmyself Offline
doitmyself  Offline
MI
It seems that if there IS a moisture problem, laying down a vapor barrier might still be a problem? What happens to moisture that condenses under the barrier and sits there for years? Mold? Algae?
Would installing over an engineered subfloor system be a better solution? DriCore and Barricade are a few examples. I don't know. I'm asking.
Re: Should I seal slab before lay vinyl laminate floor [Re: doitmyself] #4646441
01/25/18 11:08 PM
01/25/18 11:08 PM
VW Fanboy Island
maxdustington Offline
VW Fanboy Island
It sounds like you should consult an actual professional not sales staff at the flooring store. Many places are unfamiliar with the products they sell.
It really depends on how much you want to spend, I always see those tiles at the store but I have never seen them or even heard of them being installed and I renovate houses in Toronto professionally.
EDIT: Just paint it and rock on, that vinyl plank has good water resistance. It is also cheap enough that if it does get trashed it is whatever. That stuff feels cheap and we only use it for basements because for the reasons mentioned above.
03 Jetta AWP/09A 205k kms
Edge 0W40 + Mann 719/30
Re: Should I seal slab before lay vinyl laminate floor [Re: JLawrence08648] #4646444
01/25/18 11:10 PM
01/25/18 11:10 PM
Phoenix
Phoenix
I bought my house about 3 years ago and did a flip but moved in instead of reselling. Pulled up the laminate that was existing (house is on a slab) and there was a lot of moisture between the vapor barrier and slab. Replaced it with new laminate and a plastic vapor barrier. I think the cold slab against the warm flooring causes a natural amount of moisture to condensate - even in Phoenix.
I remember when shopping there were a lot of different options, and some included a pre-installed sound/vapor barrier.
2018 GTI
Re: Should I seal slab before lay vinyl laminate floor [Re: JLawrence08648] #4646445
01/25/18 11:10 PM
01/25/18 11:10 PM
Port Orange, Florida
Panzerman Offline
Panzerman  Offline
I am in the process of re-flooring my entire house. I definitely like tile better but not the price.
You don't need to seal the concrete. Don't skimp on the underlayment though. I had laminate with backing and they talked me into underlayment anyway. I hate that room it feels bouncy. I used three types of underlayment. I like the one that is thin black like scuba fabric it works Great but you really don't need anything.
Look at this way if the concrete sweated your carpet would get wet. It's fine.
2006 Dodge Ram 2500 Hemi 4x4
2016 Dodge Challenger Scat Pack
Re: Should I seal slab before lay vinyl laminate floor [Re: Panzerman] #4646447
01/25/18 11:11 PM
01/25/18 11:11 PM
Phoenix
Phoenix
Carpet breathes, laminate doesn't.
2018 GTI
Re: Should I seal slab before lay vinyl laminate floor [Re: Panzerman] #4646453
01/25/18 11:17 PM
01/25/18 11:17 PM
VW Fanboy Island
VW Fanboy Island
I noticed the bouncy feeling as well but it goes away after a while in high traffic areas and makes the floor feel more like a real wood floor instead of laminate on concrete
Re: Should I seal slab before lay vinyl laminate floor [Re: maxdustington] #4646455
01/25/18 11:18 PM
01/25/18 11:18 PM
MI
doitmyself Offline
doitmyself  Offline
MI
At my workplace I have required professionals come back and redo sup par work on more than a few occasions. Bad concrete. Wall in a wrong location. Illegal wiring. You name it.
It's my responsibility and ultimately rests on me. If you had added the word competent in front of professional, it would have been much more palatable. I haven't dealt with moisture underneath a vinyl floor plank and was simply asking.
So, how do you handle moisture underneath basement vinyl plank flooring?
Re: Should I seal slab before lay vinyl laminate floor [Re: JLawrence08648] #4646465
01/25/18 11:27 PM
01/25/18 11:27 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
I would never install a long life product on un-sealed concrete. I just would not do it ...
Re: Should I seal slab before lay vinyl laminate floor [Re: doitmyself] #4646494
01/26/18 12:05 AM
01/26/18 12:05 AM
VW Fanboy Island
VW Fanboy Island
I was under the impression that this was just the ground floor of a house on a slab. If I were concerned about moisture build up under my basement flooring I would repair my leaky basement before putting a floor down.
Re: Should I seal slab before lay vinyl laminate floor [Re: dishdude] #4646557
01/26/18 03:29 AM
01/26/18 03:29 AM
NY
demarpaint Offline
demarpaint  Offline
NY
It also wicks up and absorbs moisture while it is breathing. It could also allow mold to grow on the padding or carpet backing. I've seen it in several clients homes over the years.
OP I would consult the manufacturer of the laminate floor product you plan on installing.
God Bless Our Troops
