AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
How a differential works
by StevieC. 03/25/19 07:37 PM
My first!
by BigMoneyGrip. 03/25/19 07:20 PM
Sizing Rims for 17 inch Light Truck Tires
by Snagglefoot. 03/25/19 06:38 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
55 registered members (ammolab, aaronc7, ArrestMeRedZ, bbhero, 2003f7, Aero540T, 3 invisible), 1,157 guests, and 69 spiders.
Topics286,439
Posts4,908,177
Members67,622
Most Online2,967
Mar 10th, 2019
Pergola atop existing deck #4646290
01/25/18 08:06 PM
01/25/18 08:06 PM
Ceciltucky Maryland
Oldtom Online content OP
Oldtom  Online Content OP
Ceciltucky Maryland
Good evening - I want to build a 10 by 12 pergola atop an existing deck on the sun baked side of my home. I envision a 10 by 12 foot frame of 2 by 6 pressure treated, supported on 4 six by six posts. The pergola would be covered with some sort of sun block fabric during the spring and summer, with the fabric removed in the winter because I am in a windy location. Everything will be thru bolted or lagged heavily to keep the whole thing from lifting off in a wind gust.
Does this design sound sturdy enough for a windy area? Has anyone built one of these? Thanks in advance for any advice.
Re: Pergola atop existing deck [Re: Oldtom] #4646303
01/25/18 08:18 PM
01/25/18 08:18 PM
PimTac Offline
PimTac  Offline
It will all start from the bottom. Developing a separate foundation for the pergola that would be anchored in poured concrete footings would be my first thought. Using steel connections with bolts from the uprights to the roof framing should be plenty.
I’m think this way because if a strong wind is straining your pergola it would also strain the deck it sits on. That’s why I would focus on the foundation.
Cannot see signatures any longer so it doesn’t matter.
Re: Pergola atop existing deck [Re: Oldtom] #4646366
01/25/18 09:40 PM
01/25/18 09:40 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
What ever you do, DO NOT lag anything directly to the rim joists or sill of the house I'd make it free standing. Just lagged to the deck. All it needs is to support itself. Not load bearing Wind brace the corner posts. The bare joists will still catch wind.
Thick oil is better grin2
Re: Pergola atop existing deck [Re: Oldtom] #4646746
01/26/18 10:00 AM
01/26/18 10:00 AM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
My first thought is how deteriorated is the deck?
20 years of sun? 5 years old and good maintenance?
