2003 Ford CVPI, 86kmi, 6kmi on Edge HM Ti 5W30
by Colt45ws. 12/18/18 12:35 PM
2017 Kia Sportage recall notice
by SlavaB. 12/18/18 12:26 PM
My VW Service Experience
by Delta. 12/18/18 11:36 AM
Nissan high idle, P0507
by LeakySeals. 12/18/18 11:23 AM
Should i go for even thinner fluid ?
by NICAT. 12/18/18 11:06 AM
Viscosity question
by dbierman. 12/18/18 10:50 AM
48 hours and a used car
by Imp4. 12/18/18 09:32 AM
Test driving PHEV w no battery charge
by RichardS. 12/18/18 09:02 AM
2005 Ford PSD with hard shifts when cold?
by racin4ds. 12/18/18 08:08 AM
18% off Ravenol + EVERYTHING @ Blauparts.com
by CleverUserName. 12/18/18 07:48 AM
Mattress shopping .....
by dblshock. 12/18/18 04:57 AM
AmazonBasics Oil May Drive Prices Down
by knerml. 12/18/18 04:45 AM
Hemi MDS issues are how common?
by Gasbuggy. 12/18/18 03:21 AM
Why use Redline and Redline Clone oils...
by burla. 12/17/18 11:38 PM
Tire choice
by CincyReds. 12/17/18 11:14 PM
Transmission fluid leak
by dawgn86. 12/17/18 07:53 PM
QuickJack BL-5000SLX and my Optima...
by WhizkidTN. 12/17/18 07:23 PM
MuhThugga, wxo, dbierman, keyblade, leeal
66716 Registered Users
105 registered members (97prizm, 87sammy, 28oz, 14Accent, 14 invisible), 1,947 guests, and 39 spiders.
Topics295,220
Posts4,930,279
Members66,716
Most Online2,553
Oct 27th, 2018
Recognise Coolant Residue? Blocked heater cores. #4645750
01/25/18 09:26 AM
01/25/18 09:26 AM
Ontario, Canada
mightymousetech Offline OP
Ontario, Canada
Had an MDX in the shop. Signs of plugged heater cores (front and rear) and partially blocked rad (hot/cold spots).
Tried flushing with CLR, degreaser, citric acid to no avail. Ended up replacing both heater cores and the rad, along with a new thermostat and water valve.
Now that the job is done (ugh), I pulled the bottom tank off the rad, and found this residue. It is like a gritty, slimy jelly. The vehicle did have aftermarket, non Honda Type 2 coolant. No idea what it was, smelled terrible, was greenish in colour.
Anybody seen residue like this?
Mighty Mouse Tech
BMW Tech, Former Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
Re: Recognise Coolant Residue? Blocked heater cores. [Re: mightymousetech] #4645797
01/25/18 10:11 AM
01/25/18 10:11 AM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
It's Flubber!
If you want the job done right......do it yourself.
Re: Recognise Coolant Residue? Blocked heater cores. [Re: mightymousetech] #4645807
01/25/18 10:16 AM
01/25/18 10:16 AM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
Stop leak?
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Recognise Coolant Residue? Blocked heater cores. [Re: mightymousetech] #4645819
01/25/18 10:25 AM
01/25/18 10:25 AM
Raleigh ,NC CSA
rshaw125 Offline
rshaw125  Offline
Raleigh ,NC CSA
Looks like what was in my Buick courtesy of Death-cool.To flush it out I drained the death-cool and filled with water. Drove it for two days (Summer) ran the heat and drained, repeat.
2012 Porsche Carrera S
2016 Ford Edge 2.0
2002 Taurus Vulcan SOLD
2006 Explorer SOLD
Re: Recognise Coolant Residue? Blocked heater cores. [Re: mightymousetech] #4645828
01/25/18 10:33 AM
01/25/18 10:33 AM
Ontario, Canada
Ontario, Canada
I suspect it may be silicate/phosphate precipitate from using an improper coolant.
Mighty Mouse Tech
Re: Recognise Coolant Residue? Blocked heater cores. [Re: mightymousetech] #4645838
01/25/18 10:48 AM
01/25/18 10:48 AM
Idaho
CT8 Online content
CT8  Online Content
Idaho
Mixed coolants?
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Recognise Coolant Residue? Blocked heater cores. [Re: CT8] #4645852
01/25/18 10:57 AM
01/25/18 10:57 AM
Ontario, Canada
Ontario, Canada
Originally Posted By: CT8
Mixed coolants?
That is my feeling. Customer had his timing belt/water pump done a year previously at a independent garage.
Sucks because the heater core/rad job required 18 hours, and nearly $2k in parts, and that was being very generous to the customer.
Mighty Mouse Tech
Re: Recognise Coolant Residue? Blocked heater cores. [Re: mightymousetech] #4645888
01/25/18 11:35 AM
01/25/18 11:35 AM
The Motor City
Kestas Offline
Kestas  Offline
The Motor City
It looks a lot like water glass from the silicated compounds in "green" coolant. Citric acid should have taken care of it.
Isn't this why they used to rod out radiators way back when?
Re: Recognise Coolant Residue? Blocked heater cores. [Re: mightymousetech] #4645900
01/25/18 11:51 AM
01/25/18 11:51 AM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
Our water is very hard with lime / calcium deposits . That is why they used to dod out radiators when I was young .
I have 2 cars with DexCool . If I was to switch , what would be the proper coolant ?
Thanks , :-)
Wyr
God bless
Re: Recognise Coolant Residue? Blocked heater cores. [Re: WyrTwister] #4645907
01/25/18 11:55 AM
01/25/18 11:55 AM
San Rafael, CA
dogememe Offline
dogememe  Offline
San Rafael, CA
Thanks , :-)
Keep the dexcool, there is nothing wrong with it in gm vehicles as long as it's maintained properly and not mixed with non-dexcool coolants.
2010 Ford Escape 2.5 ~91K Miles: AMSOIL SS 5W-30, AMSOIL SS FE ATF.
1995 Chevy Silverado 5.7 ~277K Miles: Delo 10W-30, AMSOIL OE MV ATF.
AMSOIL
Re: Recognise Coolant Residue? Blocked heater cores. [Re: WyrTwister] #4646047
01/25/18 02:25 PM
01/25/18 02:25 PM
Snagglefoot Offline
Snagglefoot  Offline
Thanks , :-)
Distilled water and more Dexcool. I run Dexcool in my 2008 3/4 ton suburban. I won't risk changing to something else. It's running fine. Changed it once, will do again next year.
Re: Recognise Coolant Residue? Blocked heater cores. [Re: dogememe] #4646048
01/25/18 02:25 PM
01/25/18 02:25 PM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
Thanks , :-)
And not run low, and kept fresh, and in good condition, and a good radiator cap.
Yep alot of ands... Deathcool works great until it doesnt. It has many advantages. to old green
Re: Recognise Coolant Residue? Blocked heater cores. [Re: mightymousetech] #4646127
01/25/18 04:04 PM
01/25/18 04:04 PM
Snagglefoot Offline
Snagglefoot  Offline
If you're really paranoid, buy the Dexcool from the GM dealer. Wasn't much more than the aftermarket.
Re: Recognise Coolant Residue? Blocked heater cores. [Re: mightymousetech] #4646245
01/25/18 06:30 PM
01/25/18 06:30 PM
Snagglefoot Offline
Snagglefoot  Offline
Fresh Dexcool s a bright orange and looks sort of pink or red when inside the plastic reservoir. The part number on the jug is the Canadian part number.
Re: Recognise Coolant Residue? Blocked heater cores. [Re: mightymousetech] #4646281
01/25/18 06:58 PM
01/25/18 06:58 PM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
Could be tire slime? laugh
03 Jeep WJ 4.0 202k Castrol Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 186k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 153k Synpower 5w30 Supertech ST3980 (Ecore)
