- Joined
- Nov 29, 2009
- Messages
- 7,267
My garbage disposer just buzzes. It worked a couple times but it was really noisy and rough running. Then after that it just buzzes. I unstuck it with an Allen wrench, but it seems there is a stiff spot when you rotate it around where it's a little harder to spin with the wrench. Not too bad though, but apparently enough to keep it from spinning. So then I turn it on and it runs for a second until it hits that spot. I didn't put anything down there that I know of. Unless the last person who owned the place did.
