Purolator 12 Pack L25608 $21
by hatt. 03/20/19 12:04 PM
Dealer service and franchise laws.
by BMWTurboDzl. 03/20/19 11:46 AM
Tie rod tapers
by LeakySeals. 03/20/19 11:26 AM
Quality Lug Nuts
by jcartwright99. 03/20/19 10:56 AM
More than one Reality
by beanoil. 03/20/19 10:50 AM
Reusable Oil Storage Container
by BamaE92. 03/20/19 10:37 AM
Bank 1 on an Equinox
by Washoe_Mark. 03/20/19 08:47 AM
How do you pronounce the word Vehicle?
by ZZman. 03/20/19 08:21 AM
Inline Fuel Filter
by CCI. 03/20/19 08:08 AM
Are All Douglas Tires USA Made?
by Miller88. 03/20/19 07:30 AM
Turn signal bulbs for '15 BMW?
by Benzadmiral. 03/20/19 07:02 AM
Drain/refill vs diy flush?
by Back40. 03/20/19 05:59 AM
Valvoline 5w30 Synpower HSTS?
by avi1777. 03/20/19 05:05 AM
Castrol Edge 5W50 "Supercar Titanium FST"
by Berto. 03/20/19 02:43 AM
The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Ford 2019 F350 oil
by arowbat. 03/19/19 11:04 PM
Saxman657, Maxxforce, Washoe_Mark, CG_BrianM, TBF
67565 Registered Users
111 registered members (ArrestMeRedZ, 2012AccentSE, Arminius, albenjoseph, 55Test, addyguy, 13 invisible), 2,034 guests, and 62 spiders.
Topics286,147
Posts4,903,006
Members67,565
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
Garbage disposal keeps getting hung up #4645726
01/25/18 10:17 AM
01/25/18 10:17 AM
Houston, Texas
motor_oil_madman Offline OP
Houston, Texas
My garbage disposer just buzzes. It worked a couple times but it was really noisy and rough running. Then after that it just buzzes. I unstuck it with an Allen wrench, but it seems there is a stiff spot when you rotate it around where it's a little harder to spin with the wrench. Not too bad though, but apparently enough to keep it from spinning. So then I turn it on and it runs for a second until it hits that spot. I didn't put anything down there that I know of. Unless the last person who owned the place did.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: Garbage disposal keeps getting hung up [Re: motor_oil_madman] #4645727
01/25/18 10:18 AM
01/25/18 10:18 AM
Houston, Texas
Houston, Texas
Is it just worn out?
Re: Garbage disposal keeps getting hung up [Re: motor_oil_madman] #4645729
01/25/18 10:19 AM
01/25/18 10:19 AM
Wet side WA
JohnnyJohnson Online content
JohnnyJohnson  Online Content
Wet side WA
You have to clean them out once and awhile drop a beer bottle in there!
2004 Corolla 129932
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 74725
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: Garbage disposal keeps getting hung up [Re: motor_oil_madman] #4645732
01/25/18 10:20 AM
01/25/18 10:20 AM
NE,Ohio
Rand Online content
Rand  Online Content
NE,Ohio
My guess is you have an old builder/apartment grade "badger" disposal.
My recommendation is replace it with a waste king L8000.
One seller has it for 99$ with no tax
https://www.amazon.com/Waste-King-Continuous-Garbage-Disposal/dp/B000DZGN7Q
you might need to purchase the converter mount to avoid swapping out the sink drain.
Re: Garbage disposal keeps getting hung up [Re: motor_oil_madman] #4645738
01/25/18 10:21 AM
01/25/18 10:21 AM
Raleigh ,NC CSA
rshaw125 Offline
rshaw125  Offline
Raleigh ,NC CSA
Have you looked down inside for debris? Mine jammed on a very small bit of plastic. Hard to see at first but I pulled it out with some needle nose pliers. Keep it clean by running cups of ice through it once a month or more.
2012 Porsche Carrera S
2016 Ford Edge 2.0
2002 Taurus Vulcan SOLD
2006 Explorer SOLD
Re: Garbage disposal keeps getting hung up [Re: motor_oil_madman] #4645740
01/25/18 10:22 AM
01/25/18 10:22 AM
Chicago,IL,USA
pandus13 Online content
pandus13  Online Content
Chicago,IL,USA
probably has been overworked over the years?
start it with the allen .
use some running water and ice
then some spent lemons
then more running water and ice
(to clean any sludge/restriction)
Probably it is right to budget for a new one?
16 Golf SportWagen
13 Mazda5
08 Yaris
04 Elantra
95 accent
95 mystique
97 concorde
Re: Garbage disposal keeps getting hung up [Re: motor_oil_madman] #4645749
01/25/18 10:25 AM
01/25/18 10:25 AM
Houston, Texas
Houston, Texas
It doesn't jam though, just a little harder to turn. I can keep turning past the tough spot and it will free again. Apparently it's enough to overcome the motor and stop it from spinning.
Re: Garbage disposal keeps getting hung up [Re: motor_oil_madman] #4645751
01/25/18 10:26 AM
01/25/18 10:26 AM
Illinois
mrsilv04 Offline
mrsilv04  Offline
Illinois
My folks somehow got a small piece of steel wire in theirs, and it gave me fits until I finally found it. I was ready to simply replace it (had a new one bought) when I finally found it in there.
2004 Silverado - on its 3rd Jasper engine in less than one year.
Re: Garbage disposal keeps getting hung up [Re: motor_oil_madman] #4645774
01/25/18 10:43 AM
01/25/18 10:43 AM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
We have a big bucket with red wiggler worms in it.
Try vermicomposting, they love vegetal garbage.
2019 VW Jetta S,6M OCI#0 1136mi-Castrol Edge Prof? VW508+OE Filter; '17 Subaru Crosstrek CVT OC#6 43467mi-Valvoline Adv 0w20 + SOA Filter
Re: Garbage disposal keeps getting hung up [Re: motor_oil_madman] #4645802
01/25/18 11:13 AM
01/25/18 11:13 AM
Nokesville, VA
brianl703 Offline
brianl703  Offline
Nokesville, VA
Get an impact wrench and a hex bit that fits the garbage disposal.
Spin it with the impact wrench until it turns freely.
I did this on a garbage disposal that was so jammed the sink was bending when using a breaker bar with a hex bit on it!
The impact wrench unjammed the disposal after almost 20 seconds of hammering away at it.
Protip: If you run your garbage disposal once in a while, it won't get jammed to the point of needing an impact wrench to unjam it...
Re: Garbage disposal keeps getting hung up [Re: motor_oil_madman] #4645808
01/25/18 11:19 AM
01/25/18 11:19 AM
Michigan
64bawagon Offline
64bawagon  Offline
Michigan
you need a Binford 6100, they have more power !
64 Chevy wagon, 10 Jeep Wrangler, 18 Silverado 1/2 ton
Re: Garbage disposal keeps getting hung up [Re: motor_oil_madman] #4645812
01/25/18 11:22 AM
01/25/18 11:22 AM
Houston, Texas
Houston, Texas
It was a sliver of metal. Works great now. Lol I'm not really sure what it goes to though.possibly a fork at one point?
Re: Garbage disposal keeps getting hung up [Re: motor_oil_madman] #4645815
01/25/18 11:24 AM
01/25/18 11:24 AM
Houston, Texas
Houston, Texas
It was jammed on the outside part where those scissor looking things are along side the wall of the disposer. I used a knife to hold back the rubber so I could get a good look.
Re: Garbage disposal keeps getting hung up [Re: motor_oil_madman] #4645836
01/25/18 11:46 AM
01/25/18 11:46 AM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
Buy a new one. Report back.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Garbage disposal keeps getting hung up [Re: motor_oil_madman] #4645839
01/25/18 11:48 AM
01/25/18 11:48 AM
Minnesota
2010Civic Offline
2010Civic  Offline
Minnesota
I think garbage disposals are gross. When we bought our house last year (a fixer upper) it had one and after a month or so it stopped working and had the grossest smell know to man. When we redid the kitchen we opted to not install a new one.
2010 Honda Civic LX
Valvoline SynPower 5w-20 - Napa Gold oil filter
59,992 miles
Page 1 of 3 1 2 3
