Synthetic motor oil in a gun
by Yuk. 03/26/19 01:07 AM
air suspension on a towed trailer?
by columnshift. 03/25/19 11:57 PM
AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
28 registered members (Atesz792, bmod305, Brad_C, Chesterr, carlprop, alcyon, 2 invisible), 691 guests, and 62 spiders.
Topics286,442
Posts4,908,225
Members67,622
Most Online2,967
Mar 10th, 2019
Buying a car serviced @ QuickLube for 100K miles #4645429
01/24/18 10:17 PM
01/24/18 10:17 PM
Los Angeles, CA
Vitt Offline OP
Vitt  Offline OP
Los Angeles, CA
I am looking to buy a used Honda Fit in my area. It's from a private party, original owner. When I asked him about service history, he told me he usually takes it to one of these quick lube shops for maintenance. I didn't even ask about the auto transmission service but I assume the same. I haven't been to one of those places in over 2 decades or so but from time to time I drive by one and see advertising stating they use this or that premium brand oil (e.g., Castrol). But the filter quality is most likely subpar unless it's also sold by a name brand like Pennzoil.
In any case, I won't be able to take the car to a mechanic for a PPI since the seller is about 40 miles from me. Should I be worried about the lube xpress that doesn't use quality oils for lack of additives? Assuming he did the oil changes (for which he says he has records), would this engine have extra wear due to low quality oils? Thanks.
Edit: As mentioned on the subject line, the car has 106,xxx miles.
Re: Buying a car serviced @ QuickLube for 100K miles [Re: Vitt] #4645435
01/24/18 10:21 PM
01/24/18 10:21 PM
Dallas,Tx USA
aquariuscsm Offline
aquariuscsm  Offline
Dallas,Tx USA
If the oil was changed at oem intervals,you'll be fine.
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Pennzoil Platinum HM 10W30
Re: Buying a car serviced @ QuickLube for 100K miles [Re: Vitt] #4645436
01/24/18 10:21 PM
01/24/18 10:21 PM
CA
CharlieBauer Offline
CA
Frequency of oil changes and driving style is what matters most.
Will it still be under warranty?
Get hold of the maintenance schedule and find out what and when things were done, before going out there.
It ain't what you don't know that gets you into trouble. It's what you know for sure that ain't so.
- mistakenly attributed to Mark Twain
Re: Buying a car serviced @ QuickLube for 100K miles [Re: Vitt] #4645452
01/24/18 10:44 PM
01/24/18 10:44 PM
Ontario, Canada
IndyIan Offline
IndyIan  Offline
Ontario, Canada
Quick lube engine oil and filter is fine for cars that don't need anything special, but if the trans fluid has been changed, odds are its got the wrong fluid in it, or "universal" atf. Do some reading on how much it matters for a Fit.
07 Focus ZXW, 5spd manual, 230km M1 5W30
18 Outback 2.5 CVT 22km 0W20
Re: Buying a car serviced @ QuickLube for 100K miles [Re: Vitt] #4645453
01/24/18 10:45 PM
01/24/18 10:45 PM
MURICA
maverickfhs Offline
maverickfhs  Offline
MURICA
Honestly, majority of people take their cars to quick express type and usually cars like Honda/Toyota won't last more than 48 hrs in my area if price is good and vehicle is maintained. No matter, where and how...
People, including myself don't care for mileage, for a less than $5K car. YMMV.
2006 Civic EX 205K/AT
2006 Acura TSX 187K/AT
2007 Accord VP 151K/AT
Re: Buying a car serviced @ QuickLube for 100K miles [Re: IndyIan] #4645454
01/24/18 10:47 PM
01/24/18 10:47 PM
Virginia
bbhero Offline
bbhero  Offline
Virginia
Great point by IndyIan.
Nissan Altima 3.5 Coupe
Mobil Super 5w30 Wix 57356
"Treat your family like your friends and treat your friends like your family."
Re: Buying a car serviced @ QuickLube for 100K miles [Re: Vitt] #4645455
01/24/18 10:48 PM
01/24/18 10:48 PM
socal
barkingspider Offline
socal
Just inspect and test drive the car like you would any other used car, have a mechanic friend look at it, and it checks out and he price is right, do it
06 Cadillac Escalade Ext
17 Cadillac ATS (wife)
05 Toyota Camry (daughter)
11 GMC Canyon off-road (daily)
Re: Buying a car serviced @ QuickLube for 100K miles [Re: Vitt] #4645460
01/24/18 10:58 PM
01/24/18 10:58 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
ask the seller if he has any receipts from the Quickee Lube. I used Valvoline for my work van and the '09 Camry I had briefly. Totally satisfied with service. Valvoline has a block diagram procedure that would take at least 3 idiots to defeat. These days 106K is barely broken in.
Thick oil is better grin2
Re: Buying a car serviced @ QuickLube for 100K miles [Re: Vitt] #4645465
01/24/18 11:04 PM
01/24/18 11:04 PM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
See if he has receipts. Going to quick lube and having receipts is better than some guy making up a story about oil changes.
If you want the job done right......do it yourself.
Re: Buying a car serviced @ QuickLube for 100K miles [Re: Vitt] #4645492
01/24/18 11:41 PM
01/24/18 11:41 PM
NJ
Leo99 Offline
Leo99  Offline
NJ
My Rav4 was serviced exclusively at a quick lube for the first 220k miles. Their oil and filters are adequate.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles (RIP)
2004 Corolla 125,000 miles
2004 Rav4 370,000 miles
2015 Camry 70,000 miles
Re: Buying a car serviced @ QuickLube for 100K miles [Re: Vitt] #4645538
01/25/18 01:10 AM
01/25/18 01:10 AM
California
jj51702 Offline
jj51702  Offline
California
Why not call a mechanic near the seller to perform a PPI? I did this for my dads car when we had to drive 70+ miles to look at the car. If u like what u see just tell him u wanna buy peninsula a PPI nearby. If he's confident in the car it's a good sign if he agrees, if he doesn't want u to do that then run.
Re: Buying a car serviced @ QuickLube for 100K miles [Re: Vitt] #4645564
01/25/18 03:06 AM
01/25/18 03:06 AM
St. Charles County, Missouri
csandste Online content
csandste  Online Content
I use Auto Tire because they have steep discounts on MaxLife if you use their credit card. Also had them do a MaxLife ATF change. Also used VIOC in the past. Frankly they've all done as good or better than routine maintenance done by the dealer, master mechanics don't generally spend their time doing oil changes.
2017 Kia Soul Plus-- Super Tech Synthetic 5w30 59000 miles
Re: Buying a car serviced @ QuickLube for 100K miles [Re: Vitt] #4645590
01/25/18 06:44 AM
01/25/18 06:44 AM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
The quick oil change places do a lot of oil changes, probably screwing up a tiny percentage. My brother had his older Toyota serviced at dealer and they did not tighten the drain plug fully. I would say it's typical service, so no negative points there.
2015 Ford F250 w/Powerstroke
Re: Buying a car serviced @ QuickLube for 100K miles [Re: Donald] #4645643
01/25/18 08:34 AM
01/25/18 08:34 AM
Wet side WA
JohnnyJohnson Offline
Wet side WA
That's why I do my own. Yes when someone you pay money to do a job screws up it is negative points!
2004 Corolla 130035
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 74725
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: Buying a car serviced @ QuickLube for 100K miles [Re: Snagglefoot] #4645702
01/25/18 09:48 AM
01/25/18 09:48 AM
Iowa
Iowegian Offline
Iowegian  Offline
Iowa
If he doesn't, the quick lube places will have them in their data base. They will be happy to print them out.
2011 Equinox, 2.4l
2009 Sienna, 3.5l
