Food photography trickery
by nthach. 12/13/18 11:29 AM
oil for 2.5 2013 vw passat?
by jstert. 12/13/18 09:47 AM
Scotty Kilmer Parody
by oilpsi2high. 12/13/18 09:41 AM
ID this old tool
by John_Conrad. 12/13/18 09:30 AM
Weak New CR2032/remote start + fob batteries
by redhat. 12/13/18 09:23 AM
Smart charges/time
by Duffyjr. 12/13/18 08:24 AM
7.3 powerstroke water pump
by mobilaltima. 12/13/18 07:10 AM
98 Jeep Cherokee, what oil is spec'd?
by otis24. 12/13/18 06:31 AM
fixing LED Christmas lights
by danez_yoda. 12/13/18 06:30 AM
Things are not as they seem to be..
by CourierDriver. 12/13/18 06:09 AM
Oz Ranger Raptor
by Shannow. 12/13/18 05:22 AM
Shop vac recommendations
by dlundblad. 12/13/18 05:06 AM
Internet Network Issues
by ZeeOSix. 12/13/18 04:13 AM
Looking for Fram Ultra XG30 and XG5 cut open
by rubberchicken. 12/12/18 10:27 PM
92 f150 332 code
by ram_man. 12/12/18 10:05 PM
Mixing brands of brake fluid / gear lube
by SureshR. 12/12/18 09:26 PM
45,000 miles in the Caprice.
by ls1mike. 12/12/18 09:21 PM
Poles19, HinaMach, Horsehaulin, JLew, bmrk1100
66666 Registered Users
88 registered members (atikovi, aba4430, Bailes1992, AZjeff, aquariuscsm, 28oz, 15 invisible), 1,835 guests, and 41 spiders.
Topics295,019
Posts4,926,184
Members66,666
Most Online2,553
Oct 27th, 2018
Michelin tires wore out rapidly - update #4645232
01/24/18 06:00 PM
01/24/18 06:00 PM
ny
llmercll Offline OP
llmercll  Offline OP
ny
I'm continuing from this thread here...
https://bobistheoilguy.com/forums/ubbthr...idl#Post4643547
I went outside and took some pictures of the tires, it looks like there's some uneven wear in the front insides of the tires. The drivers side is significantly worse than the passengers. The rear tires seem fine. It's my moms car, and she claimed to have had the tires rotated every other oil change. Does this look like a lack of rotation or alignment/balancing issue?
Front Left: https://i.imgur.com/EgEKOwW.jpg
Front Right: https://i.imgur.com/2kF1Ul0.jpg https://i.imgur.com/FrxLvYX.jpg
I don't know where to go from here. The rears aren't bad, and the front right isn't too bad either. Maybe I could just get one new tire or do a rotation on these? Would the front left do ok in the back of the car?
I doubt sears would warranty them and probably say it's a lack of maintenance. Not sure if mom can provide receipts.
Re: Michelin tires wore out rapidly - update [Re: llmercll] #4645236
01/24/18 06:06 PM
01/24/18 06:06 PM
California's Wine Country
SLO_Town Offline
SLO_Town  Offline
OP, the reason your tires wore our rapidly is because your suspension needs work. Given the mileage of the car it probably needs bushings, ball joints, tie rod ends, struts/shocks, etc; and the subsequent alignment.
Scott
03 BMW 330Ci (Euro Castrol 0W-30)
10 Honda Element (Kendall GT1 Max 5W-30)
11 BMW 328i (Euro Castrol 0W-30)
15 Ford Focus (Redline 5W-20)
Re: Michelin tires wore out rapidly - update [Re: llmercll] #4645237
01/24/18 06:08 PM
01/24/18 06:08 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
Thats an alignment problem. Not the tires fault.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Michelin tires wore out rapidly - update [Re: llmercll] #4645242
01/24/18 06:11 PM
01/24/18 06:11 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
I'd have an alignment shop look at it and do a proper alignment. Sears wouldn't be on my list of options for an alignment. If you have a Discount Tire nearby they might be able to help with a pro-rate on a different set of tires. They usually do a great job with pro-rates. And all they do is tires.
Re: Michelin tires wore out rapidly - update [Re: llmercll] #4645243
01/24/18 06:11 PM
01/24/18 06:11 PM
Great Lakes
Quattro Pete Offline
Great Lakes
Front right looks like it may have been ran underinflated, too.
'02 530i (Edge 0W-40)
'15 Q5 3.0T (Edge 5W-40)
'18 Charger SRT (PUP 0W-40 SRT)
Re: Michelin tires wore out rapidly - update [Re: llmercll] #4645247
01/24/18 06:13 PM
01/24/18 06:13 PM
out there
spasm3 Offline
spasm3  Offline
out there
I think the toe is off on one wheel. But i had defenders wear evenly and wore out at 28k. The air pressure was maintained at 32f 34r. When the tires were replaced, the alignment was checked and was fine. I have pirelli P4 plus all season on there now, and they are holding up great.
https://bobistheoilguy.com/forums/ubbthreads.php/topics/4287363/Michelin_defender_issue#Post4287363
13 elantra 72k 5w30 QSUD
03 chevy avalanche 80k synpwr 5w30
17 mazda cx-5 7300 miles m1 0w30
Re: Michelin tires wore out rapidly - update [Re: llmercll] #4645252
01/24/18 06:15 PM
01/24/18 06:15 PM
VA
maverickfhs Offline
maverickfhs  Offline
VA
Definitely an alignment issue...probably camber issue?
2006 Civic EX 202K/AT
2006 Acura TSX 180K/AT
Re: Michelin tires wore out rapidly - update [Re: llmercll] #4645260
01/24/18 06:19 PM
01/24/18 06:19 PM
Chicago, IL
tomcat27 Offline
tomcat27  Offline
Chicago, IL
agree. the problem is not the tires; they should not warranty them for problems with alignment/suspension/steering. I also believe that if the tires were rotated every oil change, the rears would show similar wear issues. of course, what is the OCI ?
2019 Cherokee, 2018 Jetta, 2014 Sentra, 1995 Escort, 1970 Cougar, 2013 XT250, 2010 Vstar, 2014 CTX1300
Re: Michelin tires wore out rapidly - update [Re: SLO_Town] #4645262
01/24/18 06:20 PM
01/24/18 06:20 PM
NEUS
Bandito440 Offline
Bandito440  Offline
NEUS
It is a lack of maintenance.
There you have it.
If you put new tires on the car before addressing the suspension/steering/alignment, this will happen again.
'14 Grand Cherokee EcoDiesel
Rotella T6 5w-40 & OEM filter
Re: Michelin tires wore out rapidly - update [Re: spasm3] #4645269
01/24/18 06:27 PM
01/24/18 06:27 PM
OH
fdcg27 Offline
fdcg27  Offline
OH
Although it is off topic, I'm really pleased with the same Pirelli tires on our '12 Accord.
They're wearing really well after 25K+, they're good in winter conditions, they offer a plush ride and they're quiet.
Best of all, I bought them from Belle Tire's online sales outlet (treaddepot?) for a song.
They sent me an email back in April '16 offering these tires at something like eighty bucks each, so I bit intending to have them mounted before the next winter. There was also a sixty dollar Pirelli MIR, which made them even cheaper.
Had them mounted in early December of that year and have been very happy with them since.
The typical Michelin shopper would be well advised to take a look at Pirellis.
18 Accord Hybrid FF
17 Forester 18K VME 0W-20
12 Accord LX 96K SSO 0W-20
09 Forester 95K M1HM 10W-30
01 Focus ZX3 118K PP 5W-20
96 Accord LX 104K T5 10W-30
95 318i
Re: Michelin tires wore out rapidly - update [Re: fdcg27] #4645297
01/24/18 06:53 PM
01/24/18 06:53 PM
out there
spasm3 Offline
spasm3  Offline
out there
I must say, that the in previous winters i could not even move the car in 2 inches of snow, i mean it would not budge with the defenders on there. I just thought it was hyundai suspension or the car was just not good on snow. With the pirelli tires, I had no problem leaving where it was parked and driving on the snow that was packed down.
Re: Michelin tires wore out rapidly - update [Re: llmercll] #4645328
01/24/18 07:31 PM
01/24/18 07:31 PM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
As said above, suspension is worn out (an alignment will NOT solve this) and the tires haven't had the tire pressure maintained, they've been run too low.
Alignment can only change from one of two things:
1. Worn out suspension parts
2. Bent/broken suspension parts.
Hitting a pothole isn't going to just simply change your alignment. If it does, something is either bent or broken, and an alignment won't solve that.
2015 Hyundai Sonata 2.4L 88k Motorcraft Synthetic Blend 5w30 & OEM
2000 Toyota Camry 2.2L 231k Valvoline 5w30 & Fram Ultra
1996 Jeep Cherokee 4.0L 147k Mobil 1 HM 10w40 & Fram Ultra
Re: Michelin tires wore out rapidly - update [Re: llmercll] #4645334
01/24/18 07:39 PM
01/24/18 07:39 PM
New England
gathermewool Offline
New England
Update your OP - no need to start a new thread.
'14 Forester XT FA20DIT (Cobb Stage 1)
Edge 0W-40 + FU filter (64,774 miles)
'15 Legacy FB25 (OEM Stage, uh, neg. 7?)
Edge 0W-20 + FU filter (40,803 miles)
Re: Michelin tires wore out rapidly - update [Re: llmercll] #4645386
01/24/18 08:39 PM
01/24/18 08:39 PM
MTL, CANADA
Rolla07 Offline
Rolla07  Offline
MTL, CANADA
Underinflated on both fronts and clearly you need the suspension checked out as well.
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
Re: Michelin tires wore out rapidly - update [Re: maverickfhs] #4645399
01/24/18 08:49 PM
01/24/18 08:49 PM
Dallas,Tx USA
aquariuscsm Online content
aquariuscsm  Online Content
Dallas,Tx USA
That's what I'm thinking. Negative camber issue.
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Pennzoil Platinum 5W20
