Break in filter cut open/ Filtermag
by UncleDave
25 minutes 15 seconds ago
Changed coil pack, now throwing cat code
by llmercll
25 minutes 21 seconds ago
07 V6 Mustang oil leak.
by aquariuscsm
28 minutes 34 seconds ago
Windows 10 Update, version 1803
by Sayjac
Today at 09:55 AM
Super Tech Euro Spec Synthetic
by Snagglefoot
Today at 09:48 AM
Super Tech Conventional 15w40 HDEO. CK-4/SN
by Snagglefoot
Today at 09:38 AM
1 gallon jug of Sta-bil for $7 at Rural King
by classic70
Today at 09:34 AM
Anger on BITOG
by Gebo
Today at 08:55 AM
2010 Acura MDX w/ 3.7 lire oil consumption issue
by Varbill
Today at 08:45 AM
Surprising oil filter service interval.
by jakewells
Today at 08:12 AM
World Population
by CourierDriver
Today at 08:11 AM
SBC Finned Aluminum Dress Up Kit $32
by hatt
Today at 07:35 AM
Meguiars
by dslofti
Today at 07:20 AM
Roller Bearing Setup For Dillon Shellplate
by billt460
Today at 05:59 AM
Omnia - the band
by Shannow
Today at 02:58 AM
Guest's devices cannot connect to my WiFi
by boulderdentist
Today at 12:54 AM
Battery stuck in flashlight.
by Chris142
Yesterday at 11:53 PM
Must read for everyone watching their diet
by JLTD
Yesterday at 11:28 PM
2014 Mazda5 Valvoline Synpower 0W-20 7500 miles
by PWMDMD
Yesterday at 10:54 PM
VOA Ravenol ECS 0W-20
by PWMDMD
Yesterday at 10:47 PM
azzid0906, OilGeek91, DRancher, Newuser, Varbill
65299 Registered Users
85 registered (4WD, 2002 Maxima SE, Atesz792, ArrestMeRedZ, aquariuscsm, advocate, 11 invisible), 1655 Guests and 29 Spiders online.
65299 Members
67 Forums
285845 Topics
#4644741 - 01/24/18 08:18 AM Mercedes MB 229.51 synthetic oil
LaszloToth Offline
Loc: Toronto, Canada
A friend of mine got a fancy AMG C63 Coupe – 507 Edition and says it takes 9L of this Mercedes spec oil. It's the naturally aspirated version and he got it used.
What's special about this oil, and are there similar consumer-grade oils that would meet the Mercedes spec following the warranty coverage?
Edited by LaszloToth (01/24/18 08:21 AM)
White '11 STi
Buckle up. The new Subaru WRX STi is here.
#4644750 - 01/24/18 08:27 AM Re: Mercedes MB 229.51 synthetic oil [Re: LaszloToth]
Quattro Pete Offline
Loc: Great Lakes
Does it have the M156 engine? If so, it can run on 229.5 oil which is easy to find just about anywhere.... M1 0w-40, Castrol 0w-40, etc...
http://bevo.mercedes-benz.com/downloadf.php?filename=en/Spec_223_2.pdf
Very nice car!
'02 530i (Edge 0W-40)
'15 Q5 3.0T (Edge 5W-40)
'18 Charger SRT (FF)
#4644822 - 01/24/18 10:10 AM Re: Mercedes MB 229.51 synthetic oil [Re: LaszloToth]
ctrcbob Offline
Loc: Mount Dora FL, Penfield NY, R...
229.5 is for gas engines.
229.51 is for Diesel engines.
I can purchase a six pack of 5W-40 Mercedes brand 229.5 for less than $50 at my local Mercedes dealer. (Sweet talk your parts guy 😇).
Bob CTRC USN Ret.
Mount Dora FL,
Penfield NY
Roswell NM
2018 Sonata 2.0T Limited
2015 Sonata Sport 2.0T Limited
#4644855 - 01/24/18 10:54 AM Re: Mercedes MB 229.51 synthetic oil [Re: LaszloToth]
Wolf359 Offline
Loc: MA
Yeah, he's confused, should be 229.5, the 229.51 is for diesels. If you want to think you're fancy, you can buy the special MB Mobil 5w40 oil that's only available at the dealer. But regular Mobil 1 0w40 should be fine. Mobil will probably start having their $12 rebate again in March.
#4644896 - 01/24/18 11:41 AM Re: Mercedes MB 229.51 synthetic oil [Re: LaszloToth]
Linctex Offline
Loc: Waco, TX
Pentosin Super III 5W-30 is pretty common.
#4644900 - 01/24/18 11:43 AM Re: Mercedes MB 229.51 synthetic oil [Re: LaszloToth]
Linctex Offline
Loc: Waco, TX
#4644966 - 01/24/18 01:05 PM Re: Mercedes MB 229.51 synthetic oil [Re: LaszloToth]
mattwithcats Offline
Loc: Virginia
Pennzoil Euro in 0W-40 is at Maul-mart for about $25 for 5 quarts.
Really like this oil, super smooth in my 3 cylinder.
https://www.walmart.com/ip/Pennzoil-Platinum-Euro-0W-40-Motor-Oil-5-qt/163165881
Also Castrol Edge 0W-40 A3/B4, and Mobil 1 0W-40
Careful with the Mobil 1, don’t mix it up with the Mobil 1 Turbo Diesel 5W-40...
2009 Smart Pure
Pennzoil Platinum Euro 0W-40, Purolator Synthetic PSL 14610, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
#4645220 - 01/24/18 05:39 PM Re: Mercedes MB 229.51 synthetic oil [Re: LaszloToth]
zeng Offline
Loc: Malaysia
Not sure if MB229.51 is meant 'only' for diesel engines, this normally C3 oil surely can be used in gasoline engines.
#4645250 - 01/24/18 06:15 PM Re: Mercedes MB 229.51 synthetic oil [Re: zeng]
rooflessVW Offline
Loc: North Carolina
But why? It's harder to find, will offer less protection, and TBN won't hold up as well to the sulfer in gasoline.
"Zed's dead baby, Zed's dead."
#4645345 - 01/24/18 07:52 PM Re: Mercedes MB 229.51 synthetic oil [Re: rooflessVW]
Garak Offline
Loc: Regina, Saskatchewan, Canada
You know what he means. wink The rest of the world is using C3 lubes in gasoline engines. We're just not doing so in North America, and the confusion is amplified by oil companies listing C3 oils as diesel oils on their sell sheets, despite a nominal SN rating on all the varieties I've seen.
Plain, simple Garak.
2008 Infiniti G37 - Shell ROTELLA T6 Multi-Vehicle 5w-30, NAPA Gold 7356
#4645831 - 01/25/18 10:37 AM Re: Mercedes MB 229.51 synthetic oil [Re: Garak]
zeng Offline
Loc: Malaysia
You're right, Garak.
Kia SC here recommends C3 5W40 for its 2.0L gas engine with good result (as is Europe IIRC), not that AxBy is unsuitable.
Besides,I'm 'seeing' C3 delivering equally good performance as is A3B4 or SN/SM with Euro II 500 ppm 'high' sulfur gasoline ....
and the often quoted purported 'under-performance' of C3 vis-a-vis SN/SM AxBy in 'non-ultra low sulfur' gasoline may be a myth afterall, in terms of wear reduction or prevention.
#4646079 - 01/25/18 02:52 PM Re: Mercedes MB 229.51 synthetic oil [Re: zeng]
Wolf359 Offline
Loc: MA
If you look at the recommended oils, 229.5 is spec for the C63. I don't think 229.51 is actually an approved oil for that motor although it would probably be fine for short term usage. I don't think it meets the specs for their regular 10k oil change interval.
#4646095 - 01/25/18 03:21 PM Re: Mercedes MB 229.51 synthetic oil [Re: zeng]
Loc: Great Lakes
If you look at the Bevo sheet I linked to earlier, you will see that the only place where they allow MB229.51 oil in this engine is Western Europe. In other parts of the world, it has to be MB229.5 oil.
I'm guessing it has to do with gasoline sulfur levels in various parts of the world. BMW follows similar strategy.
#4646544 - 01/26/18 01:32 AM Re: Mercedes MB 229.51 synthetic oil [Re: zeng]
Garak Offline
If a person is running short enough OCIs here, I can't see it being a concern. However, my main concern would be cost. Every C3 oil I've seen here is in one litre bottles, which winds up being much more expensive than a 5 L container of an A3/B4.
As for gasoline engines, as I've posted before, Castrol's lube selector recommends Edge 5w-30 C3/dexos2 as a suitable oil for my G37, because the G37 calls only for an SN 5w-30, with GF-5 optional, not to mention 6000 km severe service OCIs. So, given that Edge 5w-30 C3/dexos2 is also SN, it fits the OEM requirements of the car.
