Synthetic motor oil in a gun
by Yuk. 03/26/19 01:07 AM
air suspension on a towed trailer?
by columnshift. 03/25/19 11:57 PM
AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
33 registered members (AndyB, ArrestMeRedZ, Atesz792, Bailes1992, bmod305, Brad_C, 2 invisible), 667 guests, and 61 spiders.
Topics286,442
Posts4,908,228
Members67,622
Most Online2,967
Mar 10th, 2019
2015 Kia Optima SX 2.0 Turbo Oil? #4644500
01/23/18 10:33 PM
01/23/18 10:33 PM
Georgia
jgscott Offline OP
jgscott  Offline OP
Georgia
Hey my g/f is getting a pre owned great condition 2015 Kia Optima SX 2.0 Turbo w/ 36k on it. Carfax said it had regular Dealer oil changes every 7500k up till now.
Did a little reading about recommendations on Kia Turbo oils. Want to run the PP Ultra 5w-30 full sys oil in it. Not sure if Kia Brand Filter that is made for a blend sys oil will hold up ok with Full sys oil?
So will the PP Ultra be the best in this 2.0 Turbo? Filter? Read something about run a GDI? Not even sure about what GDI oil is? What are some recommendations you expert think? Oil, Brand, Type, Weight, Filter. Thanks. Love this forum!
*13'Lex ES350 92k/Fram US & Pennzoil Ul HM 0w-20
*06'Honda Civ Cpe 230k/Honda & Honda 5w-20 Blend
*02 Linc LS Sport V8 241k/Ford & Ford 5w-20 Blend
Re: 2015 Kia Optima SX 2.0 Turbo Oil? [Re: jgscott] #4644508
01/23/18 10:38 PM
01/23/18 10:38 PM
St. Charles County, Missouri
csandste Online content
csandste  Online Content
For a combo of GDI and turbo, I'd go with any Dexos 1 v 2 oil. Last time I owned a HyunKia (13 Rio-gdi, not turbo), I think they allowed a broad variation in weight. I always ran 5w20.
2017 Kia Soul Plus-- Super Tech Synthetic 5w30 59000 miles
Re: 2015 Kia Optima SX 2.0 Turbo Oil? [Re: jgscott] #4644513
01/23/18 10:48 PM
01/23/18 10:48 PM
Indy
69Torino Offline
69Torino  Offline
Indy
You may use the Kia 504 filter with any oil of your choice. Those filters are built extremely well. The filter doesn't care what oil goes through it. I would stick with a 5k interval on a 2.0 turbo Kia (or less) with any name brand synthetic 5-30. PP would be just fine.
1969 Ford Torino GT 390 Auto
2003 Mercury Marauder
1992 Mercury Capri Convertible
2005 Ford Freestyle
2008 Hyundai Santa Fe
2015 Kia Optima
1947 Ford 2N
1978 Honda XL75
Plus Other Stuff...
Re: 2015 Kia Optima SX 2.0 Turbo Oil? [Re: 69Torino] #4644525
01/23/18 11:06 PM
01/23/18 11:06 PM
Northern Ontario, Canada
Danno Offline
Danno  Offline
If it was my car, +1 on this guidance.
2016 Sorento SX V6 AWD
2015 KIA RIO SX
2010 Mazda 3 2.0L
2009 Venza V6 AWD
2013 Sonata 2.4L RIP in write-off crash
Re: 2015 Kia Optima SX 2.0 Turbo Oil? [Re: jgscott] #4644532
01/23/18 11:31 PM
01/23/18 11:31 PM
IL
lukejo Offline
lukejo  Offline
IL
PUP is not Dexos Gen2...
Re: 2015 Kia Optima SX 2.0 Turbo Oil? [Re: jgscott] #4644561
01/24/18 01:16 AM
01/24/18 01:16 AM
Georgia
jgscott Offline OP
jgscott  Offline OP
Georgia
So don't run PP Ultra????
Re: 2015 Kia Optima SX 2.0 Turbo Oil? [Re: jgscott] #4644594
01/24/18 04:25 AM
01/24/18 04:25 AM
Kendall, FL
wemay Offline
wemay  Offline
Kendall, FL
Run anything that shows up on this list...
http://www.centerforqa.com/dexos-brand2015/
dexos1Gen2 oils are meant for small displacement Turbo GDi engines to help combat LSPI (catastrophic knock events) and reduce timing chain wear. Another option is going with a Xw40 A3/B4 oil.
All that being said, i doubt PUP would be an issue.
Any quality filter will do. I can't tell you the last time i used an OE oil filter on the SFS 2.0T.
18 KIA Sportage 2.4 AWD
M1HM 10W30, OEM
ST SYN 5W30, ST9688 (next)
13 Hyundai Santa Fe Sport 2.0T
PPeL 5W30, OEM
M1HM 10W30, OEM (next)
Re: 2015 Kia Optima SX 2.0 Turbo Oil? [Re: jgscott] #4644778
01/24/18 10:10 AM
01/24/18 10:10 AM
So. Calif.
turnbowm Offline
turnbowm  Offline
So. Calif.
The Kia Owner's Manual for the 2015 2.0L GDI-T calls for an ACEA A5-rated oil with various grades (5W30, 5W40, etc.) depending on temperature. Because of LSPI issues in these engines, a Dexos1 Gen2 oil should be considered. PP meets the D1 G2 specs but PUP does not. My recommendation would be to use the newer PP that is D1 G2 rated in a 5W40 grade. The 5W40 is preferred over 5W30 because of fuel dilution issues.
Edit- Kia recommends the OEM oil filter because of problems identified in some after-market filters.
2015 Kia Optima EX 2.4L GDI
2015 Chevy Volt
Re: 2015 Kia Optima SX 2.0 Turbo Oil? [Re: jgscott] #4649606
01/28/18 10:39 PM
01/28/18 10:39 PM
Georgia
jgscott Offline OP
jgscott  Offline OP
Georgia
We got the Kia Optima SX 2.0 Turbo yesterday. Not knowing what oil the dealer changed it with, I bought the PP Dextor , 5-30. Took to the Kia Dealer, had them change it. With a Kia filter. Car checked out perfect.
I'm going to change at 5k intervals. Still wonder if the Fram UG Sys filter would be better, and or the 5-40 weight?
Re: 2015 Kia Optima SX 2.0 Turbo Oil? [Re: turnbowm] #4649610
01/28/18 10:43 PM
01/28/18 10:43 PM
Georgia
jgscott Offline OP
jgscott  Offline OP
Georgia
Thanks. What are LSPI issues? And what are fuel dilution issues?
Re: 2015 Kia Optima SX 2.0 Turbo Oil? [Re: jgscott] #4649627
01/28/18 11:02 PM
01/28/18 11:02 PM
Georgia
MParr Offline
MParr  Offline
Georgia
LSPI is pre-ignition knock. Fuel dilution is gasoline mixing with engine oil.
2013 KIA Optima EX 2.4L. Now: Unknown &OE filter
2017 Ford Escape SE 2.0T Now: NAPA Synthetic 5W30 & NAPA Gold 1348
