What’s the odds..
by Eric Smith
06/19/18 09:51 PM
Who can relate?
by Reddy45
06/19/18 09:43 PM
No more oil changes
by goodtimes
06/19/18 09:19 PM
Separating toddlers from their parents?
by fdcg27
06/19/18 08:50 PM
gm 8.6 truetrac
by Spitter
06/19/18 08:45 PM
New addition to my garage: 2000 Corvette FRC
by MrHorspwer
06/19/18 08:34 PM
Rockauto 5% off
by Spitter
06/19/18 08:32 PM
fumoto oil valve
by Santo
06/19/18 08:19 PM
Grand solar minimum...
by ridgerunner
06/19/18 07:57 PM
Pentofrost coolant $10 Autozone
by PD001
06/19/18 07:49 PM
The things you find cleaning Garage 30+ btls slob
by digger327
06/19/18 07:20 PM
Castrol GTX Magantec 0w20 - 6 pack $21.99 - Amazon
by 04SE
06/19/18 07:07 PM
Havoline Pro DS 5w20 $3.15/quart - Amazon
by 04SE
06/19/18 07:06 PM
Needing New Dipstick
by Geauxtiger
06/19/18 05:11 PM
'98 Mercedes E300TD Rotella T5 10W-30 5k miles
by KenO
06/19/18 04:35 PM
Premium guard oil filters
by Jaha24k
06/19/18 04:09 PM
76 super motor oil- synthetic blend 5w-30
by Jaha24k
06/19/18 04:07 PM
Who makes the Mopar 5038041AA filter?
by Quattro Pete
06/19/18 03:55 PM
Ruger Mini-14, yay or nay?
by 28oz
06/19/18 03:51 PM
USPS long long delivery to BlackStone Labs
by Pajero
06/19/18 02:58 PM
Shassis, Santo, aligoodn, memyself, MichiganKid419
65274 Registered Users
80 registered (2015_PSD, 77GrandPrix, BigCahuna, Aero540T, 6 invisible), 1415 Guests and 44 Spiders online.
65274 Members
67 Forums
285627 Topics
Page 1 of 6 1 2 3 4 5 6 >
#4644410 - 01/23/18 08:10 PM Coolant expansion tank boiling
Emanuel Offline
Loc: Venezuela, South America
I have a 01 Corolla with almost 290k miles, itīs thermostat have been removed I know that I should buy and put one again but I canīt afford it and I will stick with the consequences, I live in Venezuela and hyperinflation is crazier than you will ever be able to imagine so please focus on the rest of the post:
- The car doesnīt have any problems on under 60 minutes drives.
- It doesnīt overheats in heavy traffic in the middle of day when the ambient temp and solar radiation are crazy.
- After long journeys the coolant in the expansion tank is boiling and I can feel bubbles in the upper radiator hose.
- In long journeys the coolant temp is very low because there is no thermostat.
- The car has good torque and I have tested opening the radiator cap to see if there are combustion gases in the cooling system and everything looks fine, it doesnīt have a blown headgasket.
Is my car overheating?
Can a car overheat even when the coolant temp is very very low?
Are bubbles in the upper radiator hose normal?
Thanks
Edited by Emanuel (01/23/18 08:21 PM)
#4644443 - 01/23/18 08:32 PM Re: Coolant expansion tank boiling [Re: Emanuel]
tig1 Offline
Loc: Illinois
Blown head gasket?
2007 Ford Fusion 227,000 miles
M1 0-20 EP
2017 Ford Fusion 49K
M1 0-20 EP
M1 ATF and MC LV
M1 10-30 in all OPE
MC filters
#4644448 - 01/23/18 08:35 PM Re: Coolant expansion tank boiling [Re: Emanuel]
KneeGrinder Offline
Loc: North of you Idaho
Do you have an overflow bottle with a small hose line feeding it from the radiator just below the radiator cap?
Do you, or have you added any coolant or water to the radiator? or overflow bottle?
Bubbles are not ok. They are not normal.
08 Tribeca 82k PUP 5w30 wix
06 Accord Hybrid 131k PUP 5w20 wix
02 Chevy k3500 97k Delvac 1 esp 5w40 wix
00 F350 133k Delvac 1300 15w40 wix
#4644452 - 01/23/18 08:37 PM Re: Coolant expansion tank boiling [Re: KneeGrinder]
Emanuel Offline
I was confused when I said coolant expansion tank, it has a overflow tank. When the radiator cap reaches certain pressure the coolant goes into this overflow tank.
#4644454 - 01/23/18 08:39 PM Re: Coolant expansion tank boiling [Re: Emanuel]
Emanuel Offline
I think that the engine needs the thermostat because it creates a restriction so bubbles can form in the cooling jackets
#4644458 - 01/23/18 08:43 PM Re: Coolant expansion tank boiling [Re: Emanuel]
mk378 Offline
Loc: USA
Before each trip, when completely cold, open the radiator cap and confirm the radiator is full to the top. The expansion tank should be about 1/3 full, or to the "FULL COLD" line if it has one.
If it stays cool on the highway, the radiator fan may not be working. That causes overheating when sitting still or in slow traffic.
Edited by mk378 (01/23/18 08:52 PM)
#4644466 - 01/23/18 08:57 PM Re: Coolant expansion tank boiling [Re: Emanuel]
KneeGrinder Offline
Your goal will be to evacuate all air out of the coolant system. Like post above says, start with filling radiator upon every cold start.
"No air bubbles around and cooling jacket or anywhere else"
#4644469 - 01/23/18 08:59 PM Re: Coolant expansion tank boiling [Re: Emanuel]
eljefino Offline
Loc: ME
It could be the radiator cap is no good. This keeps pressure on, and prevents boiling.
Are you running 50/50 coolant or is there more water in there?
I'd say, yeah, you're overheating.
Maybe the water pump is no good?
If you have bubbles in the upper hose, your radiator fan should be running, and you should feel the car throwing off a lot of heat if you stand by the driver's door. If it isn't, you aren't getting water flow to or through the radiator, the fan is weak, etc. Similarly, turn on the heat inside and run the fan high, it should roast you out of there.
#4644496 - 01/23/18 09:26 PM Re: Coolant expansion tank boiling [Re: Emanuel]
PeterPolyol Offline
Loc: toronto
Having no thermostat is bad news. It not only regulates flow to the rad but when it opens, it closes the bypass circuit. No thermostat means the bypass is fully open along with the radiator and so coolant flow is unpredictable. Find a tstat asap, even a used one if you have to...
Edited by PeterPolyol (01/23/18 09:28 PM)
#4644507 - 01/23/18 09:37 PM Re: Coolant expansion tank boiling [Re: Emanuel]
Ducked Offline
Loc: Taiwan
How do you know this?
I have some evidence of bubbling into the expansion tank, and I suspect I have a blown head gasket, but its slight, intermittant and so far doesnt seem to be getting ant worse.
Yesterday I tried working a plastic bag full of coolant into the overflow tank and everting it.
The idea is that if its blowing combustion gases through the tank the bag will trap some of the bubbles.
If its blowing steam, it won't, because the steam will re-condense.
Tricky to get the bag to evert neatly so I dunno if it'll work. Yesterday it didn't seem to catch anything.
The usual "First World" advice is to get a chemical test for combustion gases. Dunno if that's available here (in Taiwan) or in Venesuala, or how I would ask for it here, or how much it'd be likely to cost.
#4644523 - 01/23/18 10:04 PM Re: Coolant expansion tank boiling [Re: Emanuel]
Ducked Offline
Loc: Taiwan
Venezuela
Apologies; that was sloppy.
#4644541 - 01/23/18 10:48 PM Re: Coolant expansion tank boiling [Re: PeterPolyol]
Silk Offline
Loc: New Zealand
This - if your thermostat has a poppet valve, it also controls the bypass circuit...coolant will be doing a loop in the bypass (often the heater) and not going through the radiator.
1987 BMW R65 - Penrite V Twin 20/50
2005 Nissan Expert - Gulf Western 10W-40
1996 Volvo T5 - Penrite HPR15 - 15W-60. Ryco syntec filter.
#4644555 - 01/23/18 11:26 PM Re: Coolant expansion tank boiling [Re: Emanuel]
Chris142 Online   content
Loc: Deplorable in apple valley, ca
Replace the radiator cap.
02 Wrangler durablend 10w40
87 F250 traveler 15w40
04 Tahoe super-s 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
#4644567 - 01/24/18 01:24 AM Re: Coolant expansion tank boiling [Re: Emanuel]
OneEyeJack Offline
Loc: S California
The thermostat slows the coolant down so that it spends enough time in the radiator to cool down.
Many also control a bypass circuit as suggested above.
Can you use the Internet to get one from Florida? Working out getting one will be cheaper in the long run than paying for the damage in the short run.
#4644581 - 01/24/18 02:43 AM Re: Coolant expansion tank boiling [Re: OneEyeJack]
Ducked Offline
Loc: Taiwan
Originally Posted By: OneEyeJack
The tjavascript: void(0)hermostat slows the coolant down so that it spends enough time in the radiator to cool down.
This seems very unlikely.
I'd think the radiator will remove heat at a rate determined by the air flow from the fan plus forward movement and the temperature differential between the coolant and the air.
If the coolant goes around faster, the temperature differential will be maintained at a higher level, so more heat will be removed.
