I am frequently reading about ceramic coatings and seeing for myself, via videos, how good they make a vehicle look after one is completed.
Mind you, a lot of prepwork is required beforehand, which makes me wonder, if that much prep work is required beforehand, would not a good quality wax on there look just as good?
I would assume the ceramic or similar coatings real benefit is longevity and protection, which brings me to my questions.
How long does one typically last?
How do you know it is worn out?
What is required to re-do it when it is worn out?
And, as I assume, it doesn't all wear away evenly (depending on the location on the car), how do you remove those spots where it still may be in decent shape?
Also, if one chooses not to reuse/reapply it, will there be any noticeable differences in the paint or will you be able to tell that it was ever used?
Like I mentioned, I like it and I want to at least use/try it on my wife's Impala's wheels, but I also think it would look great if I had her whole car done.
Typically, if I don't feel comfortable/skilled enough to go through all the prep work that is required, how much could I expect to pay to have someone do this for me?
Thanks in advance.
Thanks in advance.
