Lets Get a True Group 4 Sticky going!
by KMJ1992
54 minutes 53 seconds ago
Rotella 10W40
by jakewells
Today at 10:43 AM
Extend WiFi Range at the Laptop?
by clarkflower
Today at 10:40 AM
Silicone containing waxes
by mjoekingz28
Today at 09:44 AM
Matrix totaled
by circuitsmith
Today at 08:32 AM
Door rust problems
by Dave Sherman
Today at 07:51 AM
2016 Honda Civic problems
by dbias
Today at 07:39 AM
Royal purple 75-140 in a subaru rear
by 91camarosRS
Today at 07:32 AM
OCI. With short trips. Nissan 4 liter
by Gawardawg
Today at 06:52 AM
Approach Watching on the Beach @ St Maarten ...
by LoneRanger
Today at 06:41 AM
Honda Accord Needs Shocks; Front, Back, or Both?
by tc1446
Today at 05:50 AM
How much oil does your oil filter hold?
by Snagglefoot
Today at 05:44 AM
better day
by mx5miata
Today at 05:26 AM
BRAVO to Officer Wheeles......
by Sayjac
Today at 05:17 AM
People Watching ....Airport style.
by ZZman
Today at 04:24 AM
Subaru's at play...
by OneEyeJack
Today at 03:50 AM
Treating a 2003 Jetta
by llmercll
Today at 01:41 AM
Brakes not working - brake pedal sinks
by tookien
Today at 12:42 AM
Dave thinks I can make it 12--15k
by Marco620
Today at 12:26 AM
'05 Impala front wheel "squeal". Cost !
by Lee4212
Today at 12:16 AM
JustaDude, 3horseman, Firedog45, WtsTacoma01, Orion62
65265 Registered Users
104 registered (Astro14, 97prizm, 853okg, andyd, ArrestMeRedZ, Andy636, 10 invisible), 1551 Guests and 46 Spiders online.
65265 Members
67 Forums
285593 Topics
#4644051 - 01/23/18 12:34 PM Condensation Issue
littleant Offline
Loc: Vermont
I keep my 2010 mountaineer AWD in the garage in the winter and only drive it if absolutely necessary. Its the only way to keep from rusting due to tons of road salt in Vermont. We had -30 to -40 below 2 weeks ago now we have 40 and rain. With the door garage door open the floor gets wet and the vehicle is wet and some condensation under the hood. With the door closed not as bad but still some condensation. Is there a chance I am getting condensation inside the oil pan/transmission/differential's/transfer case.Thanks Guy's.
I can't prevent getting old but I REFUSE to grow up.
2010 Mountaineer 4.0
2002 Jeep Wrangler TJ 4.0
#4644067 - 01/23/18 12:58 PM Re: Condensation Issue [Re: littleant]
Danh Online   content
Loc: .
Youd have to have a pretty large amount of moist (high dew point) air displacing dry (low dew point ) air in these components for condensation to occur. As these are largely or completely sealed units Id expect any air exchange while they are inactive to be minimal, so I wouldnt worry.
Of course, the condensation on the body, chassis and perhaps inside body panels wont do your corrosion issues any favors. If the roads arent wet and salty Id get it out for a drive.
#4644073 - 01/23/18 01:05 PM Re: Condensation Issue [Re: littleant]
KrisZ Online   happy
Loc: Toronto, Canada
Pure water is not really a problem as far a rust is concerned. Otherwise places like Florida or California would have rust problems, but they don't.
But if you want to get rid of the condensation problem, you have to run a hot air vent from your house into the garage.
Personally I don't see a little dew causing any problems.
2015 Dodge Grand Caravan-21k miles.
2006 Mazda 3-155k miles
#4644076 - 01/23/18 01:11 PM Re: Condensation Issue [Re: Danh]
littleant Offline
Loc: Vermont
Thanks for your input Danh. The roads should be better after the rain. I'll take it out then. The body/frame are mint and would like to keep it that way. Vermont is a nightmare for salt and corrosion. Now they are talking going to brine.
#4644085 - 01/23/18 01:24 PM Re: Condensation Issue [Re: KrisZ]
Reddy45 Offline
Loc: USA
In case anyone is going to try this, it's probably against building codes to have HVAC systems connected between the garage and living space. The threat of CO infiltration in the home is the reason.
Better to just run space heaters in the garage to dry it out.
#4644092 - 01/23/18 01:35 PM Re: Condensation Issue [Re: Reddy45]
KrisZ Online   happy
Space heaters are quite a fire hazard. Why would anyone, seemingly concerned with safety, suggest putting one in a garage of all places?
Edited by KrisZ (01/23/18 01:36 PM)
#4644100 - 01/23/18 01:52 PM Re: Condensation Issue [Re: KrisZ]
Donald Offline
Loc: Upstate NY
If you want to heat the garage get an electric garage heater and permanently install it and wire it. Installed up high it will be safe. Angle the air louvers down. I used stranded wiring in flex conduit. I felt the vibration of the fan might over time damage solid wire.
2015 Ford F250 w/Powerstroke
#4644119 - 01/23/18 02:18 PM Re: Condensation Issue [Re: Reddy45]
wag123 Offline
Loc: Texas
Not where I live. Here they just require that the HVAC system be correctly sized (for the included square footage), that the garage be properly insulated, and the garage doors have weather seals on them.
If you run a vehicle in a closed garage it doesn't really matter if you have the HVAC system routed to the garage, the CO can still kill you inside the house.
#4644133 - 01/23/18 02:39 PM Re: Condensation Issue [Re: littleant]
littleant Offline
Loc: Vermont
It's a small one car detached garage about 30 yards from house. Electric garage heater sounds like an option. Amazon has smaller ones for $100-150. I do have 220 in garage
#4644358 - 01/23/18 07:30 PM Re: Condensation Issue [Re: littleant]
Superflan Offline
Loc: Reunion Island
Chances are you need to better insulate the garage, then put a garage heater. Im worried about the heater running 100% duty cycle and yet not be able to keep up with the losses
Yaris 1.0 201mkm 5W40 ACEA A3/B4
Kangoo 1.5 DCi 15W40 ACEA E7
Wife's Koleos 2.0 dCi DPF 6AT eco-map 162mkm 5W40 C3
