ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
FYI: Costco is now stocking the 'good' Techron
by mbz321. 03/20/19 12:32 PM
Auto maintenance advice from a locksmith?
by Variant_S. 03/20/19 12:18 PM
Purolator 12 Pack L25608 $21
by hatt. 03/20/19 12:04 PM
Dealer service and franchise laws.
by BMWTurboDzl. 03/20/19 11:46 AM
Tie rod tapers
by LeakySeals. 03/20/19 11:26 AM
Quality Lug Nuts
by jcartwright99. 03/20/19 10:56 AM
More than one Reality
by beanoil. 03/20/19 10:50 AM
Reusable Oil Storage Container
by BamaE92. 03/20/19 10:37 AM
Bank 1 on an Equinox
by Washoe_Mark. 03/20/19 08:47 AM
How do you pronounce the word Vehicle?
by ZZman. 03/20/19 08:21 AM
GG16v, fleetwood62, varalakshmi, AllyMac, Saxman657
67569 Registered Users
104 registered members (2whlgeezer, 2015_PSD, 53' Stude, 2012AccentSE, 15 invisible), 2,182 guests, and 62 spiders.
Topics286,159
Posts4,903,310
Members67,569
Most Online2,967
Mar 10th, 2019
Key won't go in mechanical door lock #4643617
01/23/18 05:15 AM
01/23/18 05:15 AM
Taiwan
Ducked Offline OP
Ducked  Offline OP
Taiwan
As per subject. Have tried a skoosh with the GUNK equivalent of WD-40, to no avail.
Might try solvent (brake cleaner?) and a blast with compressed air, if I can get to some, next. I see graphite sprays recommended, but I dunno if I can get them here, though I can get pencil lead, so maybe I can blow graphite into it.
After that I suppose I MIGHT try to take it apart, but I'm not very keen.
Any other ideas? Lock picks?
One consolation is its fairly low risk leaving it unlocked here even with stuff inside it, and I should make a sun cover anyway, so maybe I can live with it, and/or use a padlock.
Re: Key won't go in mechanical door lock [Re: Ducked] #4643717
01/23/18 08:41 AM
01/23/18 08:41 AM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
Check out Scottys You Tube video on changing door locks. Most of the work is removing the interior door panel. An afternoon and a few beers with a friend should do it.
If you want the job done right......do it yourself.
Re: Key won't go in mechanical door lock [Re: Ducked] #4643783
01/23/18 09:33 AM
01/23/18 09:33 AM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
Being able to fix it depends on the construction as well. On my BMW you can quite easily disassemble the lock cylinder and remove the wafers and springs, clean everything up and put it back together. The Toyota cylinders are different though and you can't get them apart without drilling out a portion of the housing somehow.
Once I got the BMW cylinders apart it became clear why spraying stuff into the lock wasn't going to help much. The grease had become old and hard and the springs could no longer align the wafers properly. BMW gives a small tube of grease with a new wafer set that works pretty well, I haven't been able to find an equivalent grease anywhere else.
1994 BMW 530i, 241K
1996 Honda Accord, 267K
1999 Toyota Sienna, 409K
2000 Toyota ECHO, 280K
Re: Key won't go in mechanical door lock [Re: Ducked] #4643812
01/23/18 09:52 AM
01/23/18 09:52 AM
USA
mk378 Offline
mk378  Offline
USA
Swap cylinders from driver door with the passenger door. They are usually the same cylinder and of course the same key.
Re: Key won't go in mechanical door lock [Re: Ducked] #4643815
01/23/18 09:56 AM
01/23/18 09:56 AM
Snagglefoot Offline
Snagglefoot  Offline
Once you get the cylinder out, I would recommend just taking it to a locksmith. It isn't all that bad in cost.
Re: Key won't go in mechanical door lock [Re: kschachn] #4644114
01/23/18 03:11 PM
01/23/18 03:11 PM
Cheshire, England
barryh Offline
barryh  Offline
Cheshire, England
I did the same on an old Mercedes. Really quite straight forward.
Barry
1979 BMW R45 (Triple QX 5W40)
2009 Mercedes C180K (Shell Helix Ultra 5W40)
Re: Key won't go in mechanical door lock [Re: Ducked] #4644282
01/23/18 07:04 PM
01/23/18 07:04 PM
Taiwan
Ducked Offline OP
Ducked  Offline OP
Taiwan
Thasnks, all, for the reponses. This is a Daihatsu so it'll likely be the uncooperative Toyota style lock, though they probably arent the originals.
Passenger side hasn't worked since I got the car, but is probably different, since I have three keys and the rear hatch and driver side ones are different.
I'll try and get some idea of the local cost of a pro job. It'll likely be more than I paid for the car, but thats not an especially relevent metric, since I didnt pay much for the car.
Re: Key won't go in mechanical door lock [Re: Ducked] #4644299
01/23/18 07:30 PM
01/23/18 07:30 PM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
Um, I might approach this problem with a hammer...
2010 Ford Fusion SE 3.0L V6, 181 miles M1 HM 10w-30
Re: Key won't go in mechanical door lock [Re: SilverFusion2010] #4644516
01/23/18 10:53 PM
01/23/18 10:53 PM
Taiwan
Ducked Offline OP
Ducked  Offline OP
Taiwan
I could get in via the rear hatch and open it, so no hammer immediately required. Its now open, but of course wont lock, which isn't too big a deal, though of course not ideal.
If I really wanted to lock it I could do so from the inside and exit via the hatch, but Id have to REALLY want to.
Re: Key won't go in mechanical door lock [Re: Ducked] #4644590
01/24/18 04:14 AM
01/24/18 04:14 AM
Taiwan
Ducked Offline OP
Ducked  Offline OP
Taiwan
Looked at those Scotty Kilmer vids.
He was using replacement parts from a scrappy. I think I'll be lucky to find one of these in a scrappy, since this is an old (1986) and now quite rare but not "collected" car so there'll be no demand for parts.
AFAIK the only old cars in demand in Taiwan are the BMC Mini, VW Beetle, and maybe the Datsun Sunny, a bit.
These days (in the UK anyway) scrappies tend to be depressingly efficient, and low-demand cars tend to go straight to the crusher. Probably the same in Taiwan since space is at a premium.
If there are any I'll have to go through a mechanic to find them which'll put the price up.
Scotty seems to be a big WD-40 fan, which apparently is a bit controversial for locks.
