Bad cylinder 3 misfire.
by Hemispheres. 12/14/18 02:49 PM
Small leak at toilet base - bad wax ring?
by Oro_O. 12/14/18 02:38 PM
Ok I take it back about Keurig
by StevieC. 12/14/18 02:29 PM
Edge 5W-30 7.9k miles '13 F150 5.0
by dustyroads. 12/14/18 02:11 PM
Stick with WSS-M2C946-A?
by BlueFog. 12/14/18 01:42 PM
How engine capacity affects fuel consumption?
by NICAT. 12/14/18 01:12 PM
Pep Boys
by Zee09. 12/14/18 12:41 PM
How early in engines life can I start to extend OCI
by Doublehaul. 12/14/18 12:33 PM
EFB and AGM batteries charge faster?
by slybunda. 12/14/18 11:20 AM
97.5 Regal GS climate control illumination
by 71Chevyguy. 12/14/18 11:04 AM
Cool train site for Canadians
by Papa Bear. 12/14/18 10:09 AM
Putting together a groups 3/4/5 synthetic list
by MrWideTires. 12/14/18 10:02 AM
VW Atlas V6 Oil
by motech. 12/14/18 09:32 AM
Great shakes, it's Yahtzee... or a Taurus
by redhat. 12/14/18 09:03 AM
MWI Micro Wave Ignition
by Danno. 12/14/18 08:52 AM
8k Miles on M1 EP 2017 Subaru 3.6
by BISCUT. 12/14/18 08:47 AM
Wrong ATF Fluid in my 07 Chevy Impala
by CM613. 12/14/18 08:39 AM
Hyundai motor oil
by pbm. 12/14/18 08:16 AM
Which Exhaust Manifold Should I Buy
by Miller88. 12/14/18 08:10 AM
wsalopek, jcr1293, maxwellk, BlueFog, Frank_G35
66682 Registered Users
103 registered members (Big Dave, barryh, 03s, bdcardinal, ARB1977, 94astro, 12 invisible), 2,003 guests, and 50 spiders.
Topics295,068
Posts4,927,192
Members66,682
Most Online2,553
Oct 27th, 2018
4L60E add filter/cooler/temp gauge #4643571
01/22/18 11:37 PM
01/22/18 11:37 PM
San Rafael, CA
dogememe Offline OP
dogememe  Offline OP
San Rafael, CA
I haven't even looked if this thing has a separate tranny cooler, so I have to look at it. If it doesn't, I want to add one. I also want to add a spin-on transmission filter and a transmission temperature gauge. Does anybody know of a kit that allows me to add a spin-on filter in line with the tranny cooler, and maybe even have a place for a tranny temp gauge probe? Any recommendations on a gauge? Thanks!
PS: referring to my 97 Suburban K1500 if that isn't clear.
2010 Ford Escape 2.5 ~91K Miles: AMSOIL SS 5W-30, AMSOIL SS FE ATF.
1995 Chevy Silverado 5.7 ~277K Miles: Delo 10W-30, AMSOIL OE MV ATF.
AMSOIL
Re: 4L60E add filter/cooler/temp gauge [Re: dogememe] #4643594
01/23/18 01:11 AM
01/23/18 01:11 AM
Fort Lauderdale, FL
DoubleWasp Online content
DoubleWasp  Online Content
Fort Lauderdale, FL
You want a filter mount that has extra ports for you to take advantage of. Typical remote filter mount has two ports in and two ports out. Replace one with the appropriate fitting for the temp sensor. Might be a good idea to have the filter mount before any of the coolers for the most accurate temp reading.
I like Autometer gauges.
Re: 4L60E add filter/cooler/temp gauge [Re: dogememe] #4643650
01/23/18 05:53 AM
01/23/18 05:53 AM
PV Az
AZjeff Offline
AZjeff  Offline
PV Az
I put a an additional trans cooler and temp gauge on a previous 4L60E. There's a little bung up on the side of the tranny that gives temp readings very close to scan tool readings. Found it with a search "temp gauge port 4L60E". Not what you're looking for but it was easy to access.
86 Samurai 1.3 leftovers
14 RAV4 2.5 5W-20 PP
16 Silverado 1500 4.3, DI, AFM 5W-30 PP
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: 4L60E add filter/cooler/temp gauge [Re: dogememe] #4643736
01/23/18 07:55 AM
01/23/18 07:55 AM
Phladelphia
NYSteve Offline
NYSteve  Offline
Phladelphia
Haven't had a 4L60 in a long time but always seems like a hayden cooler and permacool filter mount were the way to go.
Re: 4L60E add filter/cooler/temp gauge [Re: DoubleWasp] #4643901
01/23/18 09:51 AM
01/23/18 09:51 AM
Southeast
meep Offline
meep  Offline
Southeast
did exactly this in the tundra. works great. pretty sure this is what I used: https://www.amazon.com/Derale-25709-Remo...il+filter+mount
ditto on Autometer gauges. I've used both them and SunPro. Suntune used to be good stuff but now even their higher line is junk. if I'm going to invest the time to do it, I'll spend for AM.
-m
2018 F150
2015 crv (wifey!)
Re: 4L60E add filter/cooler/temp gauge [Re: dogememe] #4643935
01/23/18 10:15 AM
01/23/18 10:15 AM
southwest Mo.
wtd Offline
wtd  Offline
southwest Mo.
You probably already have the tranny cooler. face the front of your truck and look through the lower left portion of the grill opening. If you see a small square radiator looking part, that is your tranny cooler.
2014 Mustang GT
1998 Chevy K3500
1998 Chevy K1500
(2) 1992 Cavaliers
1970 Monte Carlo
Re: 4L60E add filter/cooler/temp gauge [Re: dogememe] #4645280
01/24/18 06:31 PM
01/24/18 06:31 PM
Townsville, Australia
IPCOlsenVZ Offline
IPCOlsenVZ  Offline
Same transmission, different vehicle.
Installed a DieselSite remote mount housing. Much bigger than the standard type. Has a large thread for the filter (BT839) and the inlet and outlets are large so fittings will be pricey to reduce down to 3/8 hose. Inbuilt bypass valve inside. All Billet aluminum. Beautiful piece.
I also installed a Derale pan but it wont fit due to the deep pan filter, need the short filter instead. Has an outlet fitting for a temp sender. I just mount the gauge under the bonnet with a switch for power. B&M and others make pans for the 4L60 as well.
Trans cooler - I bypassed the in tank cooler and went direct to a B&M Hi-tek fan cooler (large one). The fan very rarely turns on (normal city driving, no towing)
Fluid: Castrol Transmax Z
Hope this helps
Re: 4L60E add filter/cooler/temp gauge [Re: dogememe] #4712318
03/31/18 10:53 AM
03/31/18 10:53 AM
San Rafael, CA
dogememe Offline OP
dogememe  Offline OP
San Rafael, CA
Well, the tranny is acting up, before I got a chance to install a filter, so I am not going to bother with a filter, and yes, it already has an OEM cooler. When my new trans goes in, I'll install the temp gauge. When I have the new one sitting here I'll beat the [censored] out of the old tranny (still driveable) so the rebuilder has work to do laugh
AMSOIL
Re: 4L60E add filter/cooler/temp gauge [Re: DoubleWasp] #4712365
03/31/18 11:41 AM
03/31/18 11:41 AM
Texas & Global
4WD Offline
4WD  Offline
Texas & Global
Yes ... my Derale mount has two inlets and two outlets
2018 Chevy 1500 Z71 4WD
2017 Chevy Tahoe LT 4WD
2014 Fusion Hybrid Titanium
2013 Cruze LTZ - RS Turbo
Re: 4L60E add filter/cooler/temp gauge [Re: dogememe] #4712396
03/31/18 12:17 PM
03/31/18 12:17 PM
Cedarbrae, Ontario
xxch4osxx Offline
xxch4osxx  Offline
Cedarbrae, Ontario
I wouldn't bother doing anything till you have the new tranny installed, but thats just me.
2015 RAM SXT Crew Cab 5.7 with 6 speed tranny.
2008 Mazda 3 GS Sport Hatchback 5sp MT (Girlfriend's car)
