sonata plastic fork starter failed three times.
by JustinH. 12/15/18 09:17 AM
HVAC Problems
by WTJackalope. 12/15/18 09:15 AM
Rough Idle after short trip
by Datarock. 12/15/18 09:07 AM
Homelite 360
by mobilaltima. 12/15/18 09:04 AM
Lovin' the Etec!
by IndyFan. 12/15/18 06:10 AM
Air Impact Wrench
by BenZahel. 12/15/18 05:19 AM
Luber finer 750 bypass oil filter info
by BigRich954. 12/15/18 03:59 AM
Ford Pickup Front Wheel Bearings 2WD
by benjamming. 12/14/18 10:52 PM
GMC oil fill tube
by Redright9. 12/14/18 10:24 PM
Where do I buy Toto toilets? That has them!
by Vern_in_IL. 12/14/18 10:04 PM
Best filter cutter for the price?
by DONWATERS. 12/14/18 09:38 PM
5W-40 vs 10W-30 for a 2018 Audi A4
by jcr1293. 12/14/18 09:25 PM
Gave up on quadrajet electric choke today...
by leroyd92. 12/14/18 08:54 PM
2015 Odyssey - Which synthetic ATF?
by AngryScientist. 12/14/18 07:56 PM
Hyundai extended my warranty
by ernied. 12/14/18 07:33 PM
2016 Traverse 6350mi Schaeffers 9000 5W30
by chevman4life. 12/14/18 07:21 PM
Oil filter for Canadian winter
by Popsy. 12/14/18 06:11 PM
NEKGuy, Deltafaatl, wsalopek, jcr1293, maxwellk
66684 Registered Users
84 registered members (53' Stude, amblerman, antonmnster, A310, 69GTX, 7 invisible), 1,904 guests, and 38 spiders.
Topics295,101
Posts4,927,813
Members66,684
Most Online2,553
Oct 27th, 2018
Page 1 of 5 1 2 5
Michelin tires wore out rapidly #4643547
01/22/18 11:09 PM
01/22/18 11:09 PM
ny
llmercll Offline OP
llmercll  Offline OP
ny
I have Michelin defenders on a 2003 Volkswagon Jetta. P195/65/R15. I purchased them 28 months ago, at 178k miles. The car now has 218k miles, and the tires are well below 2/32". They have completely worn out in about 40k miles, short of the 90k warranty. I had them done at sears, and have not noticed any issues over the 2 years I've had them.
Does anyone know what could cause this? Aren't defenders some of the best tires out there? I paid [censored] near $800 for them 2 years ago!
I can get them replaced under warranty for about 55% off, but am kind of afraid to touch another Michelin tire again...
Any thoughts/advice?
Re: Michelin tires wore out rapidly [Re: llmercll] #4643554
01/22/18 11:16 PM
01/22/18 11:16 PM
Canada
Run Offline
Run  Offline
Canada
Have you had your alignment checked recently? If tires are wearing out that fast the problem might not be the rubber itself.
03 Neon 2.0 - VSP 5W-30 Pentius XL
Re: Michelin tires wore out rapidly [Re: Run] #4643559
01/22/18 11:19 PM
01/22/18 11:19 PM
ny
llmercll Offline OP
llmercll  Offline OP
ny
No, I have not. It was done just over 2 years ago with the new tires though, and I haven't hit anything so I'd be surprised if it went out that badly that quickly.
Re: Michelin tires wore out rapidly [Re: llmercll] #4643563
01/22/18 11:22 PM
01/22/18 11:22 PM
Where the wind comes sweepin'
Reddy45 Offline
Reddy45  Offline
Are you saying the tread thickness is somehow guaranteed to last 90k miles? Where did you see that stated?
Re: Michelin tires wore out rapidly [Re: llmercll] #4643564
01/22/18 11:22 PM
01/22/18 11:22 PM
Iowa
Nyquist Offline
Nyquist  Offline
Iowa
How good are your shocks/struts? Are your steering parts tight? Also, what is your driving style like?
2015 Chevy Traverse 3.6L (LLT) Mobil 1 5w30 w/ Fram Ultra
2017 Chevy Cruze Hatchback 1.4L (LE2) Mobil 1 5w30 w/ Wix
Re: Michelin tires wore out rapidly [Re: Reddy45] #4643568
01/22/18 11:31 PM
01/22/18 11:31 PM
ny
llmercll Offline OP
llmercll  Offline OP
ny
The defenders have 90k warranty. It's on my receipt from sears.
Driving style is smooth.
Shocks and struts are pretty bad, OEM from a 2003 model so...
I have no way of knowing if my steering parts are tight, I assume so.
Re: Michelin tires wore out rapidly [Re: llmercll] #4643578
01/22/18 11:46 PM
01/22/18 11:46 PM
Illinois
mrsilv04 Offline
mrsilv04  Offline
Illinois
I had a set of Defenders wear down to 5/32" remaining, in 37,500 miles.
Not as bad as the wear that you saw, but I was disappointed in this result as well.
2004 Silverado - on its 3rd Jasper engine in less than one year.
Re: Michelin tires wore out rapidly [Re: llmercll] #4643588
01/23/18 12:38 AM
01/23/18 12:38 AM
Reddy45 Offline
Reddy45  Offline
I'm still not understanding how a warranty for 90k = tread should last 90k.
Your driving style, the roads you frequently drive on, the amount of weight you carry -- these all impact tread wear.
I can see the warranty covering if the tire had a manufacturing defect that caused it to explode exactly at 89,999 miles, but that's different than routine wear and tear from use. (and they'd warranty just the one tire that exploded)
Seems like if you got 40k out of them, AND Michelin is offering to prorate a new set by half the price then you're about even steven.
Re: Michelin tires wore out rapidly [Re: llmercll] #4643590
01/23/18 12:55 AM
01/23/18 12:55 AM
Texas
FZ1 Offline
FZ1  Offline
Texas
Get the new tires at 55% off. When the new tires wear out at 40,000 get another 55% off set and repeat.
Re: Michelin tires wore out rapidly [Re: Reddy45] #4643592
01/23/18 01:04 AM
01/23/18 01:04 AM
MA
Wolf359 Offline
Wolf359  Offline
MA
Hmm... I thought a tread wear warranty that says the tread should last 90k is the indication that the tread should last 90k on a properly maintained vehicle. Of course worn suspension components, and worn out front end parts could lead to premature wear. The other question would be if the ball joints, tie rods, control arms, wheel bearings etc are in good condition. A good mechanic can check those out. Those would also lead to premature wear. The OP is lucky that Sears is pro-rating them. Usually there's several exceptions where if the tires aren't rotated, they don't honor the warranty. It also excludes improper maintenance. Over/under inflation would also be another factor.
I'm leaning toward blaming the OP as he already admitted that the suspension components were worn.
Re: Michelin tires wore out rapidly [Re: llmercll] #4643593
01/23/18 01:11 AM
01/23/18 01:11 AM
New England
gathermewool Offline
New England
Even wear?
Any unusual wear pattern, cupping, etc?
'14 Forester XT FA20DIT (Cobb Stage 1)
Edge 0W-40 + FU filter (64,774 miles)
'15 Legacy FB25 (OEM Stage, uh, neg. 7?)
Edge 0W-20 + FU filter (40,803 miles)
Re: Michelin tires wore out rapidly [Re: llmercll] #4643595
01/23/18 01:19 AM
01/23/18 01:19 AM
Fl
carloz Offline
carloz  Offline
Fl
Load rating and tire inflation are also some factors that can affect tread life.
Re: Michelin tires wore out rapidly [Re: llmercll] #4643610
01/23/18 03:24 AM
01/23/18 03:24 AM
Silicon Valley
PandaBear Offline
PandaBear  Offline
Silicon Valley
Even wear is the key, if you have alignment problem or suspension problem or not rotate them they will wear out faster.
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
Re: Michelin tires wore out rapidly [Re: llmercll] #4643630
01/23/18 05:21 AM
01/23/18 05:21 AM
North Carolina
rooflessVW Online content
rooflessVW  Online Content
North Carolina
Tread warranty =/= tread life.
What's the difference between $800 every 90l miles and $360 every 40k miles? To me it seems like you're still on top.
"Zed's dead baby, Zed's dead."
Re: Michelin tires wore out rapidly [Re: llmercll] #4643632
01/23/18 05:24 AM
01/23/18 05:24 AM
War Eagle
toneydoc Offline
toneydoc  Offline
War Eagle
Go and get a new set at 55% off and call it your lucky day to get the new rubber under warranty
1994 Jeep 161k Castrol Synblend 10w30
2014 Camry 36k Havoline 5w20
2018 Jeep Cherokee 3k FactFill
2014 HD Ultra 42k Mobil1 15w50
2012 Rav4 39k Mobil 1 0w20
Page 1 of 5 1 2 5
