Inside the Fuel Tank / EVAP system
by StevieC. 09/22/18 10:31 PM
Toyota Pink + RMI-25 10 years
by burla. 09/22/18 10:27 PM
Cartridge filter?
by Camprunner. 09/22/18 10:23 PM
Should have changed it?
by parshisa. 09/22/18 10:14 PM
Meijer QSUD Full Syn 10w30 $8.11 5qt jug
by Spartanfool. 09/22/18 08:40 PM
Whats in your beef burger
by CourierDriver. 09/22/18 08:28 PM
Headlight brightness fluctuates on 1987 Golf
by vavavroom. 09/22/18 07:56 PM
"New" Beater
by SilverGt. 09/22/18 07:22 PM
Eschewing computer controls
by buck91. 09/22/18 06:41 PM
Leak/drip left front 13 Ram 4x4?
by irv. 09/22/18 06:22 PM
5w20 oil choices
by 53' Stude. 09/22/18 06:05 PM
site security
by RF Overlord. 09/22/18 06:02 PM
Richmond Raceway
by Warstud. 09/22/18 06:01 PM
Redline D6 ATF substituting for Toyota WS
by Patrick0525. 09/22/18 05:29 PM
XG3614 Cut Open 13,400kms (8,375mi)
by mcwilly. 09/22/18 05:25 PM
Torn Purolators: they DO TEAR!
by 53' Stude. 09/22/18 05:07 PM
transmission fluid and filter exchange
by Dennisistheman. 09/22/18 04:53 PM
Why people should change oil+filter!
by 53' Stude. 09/22/18 04:50 PM
Household lubricants (general purpose) differences
by 92saturnsl2. 09/22/18 04:35 PM
HondaTech250, SandCruzer, sbgti96, cosmoblau, Sarrge
66044 Registered Users
78 registered members (4WD, 77GrandPrix, 53' Stude, alphadog, ABomb369, 7 invisible), 1,134 guests, and 30 spiders.
Topics290,863
Posts4,851,529
Members66,044
Most Online3,590
Jan 24th, 2017
Kitchen sink basket assembly recommendations? #4643295
01/22/18 08:05 PM
01/22/18 08:05 PM
St. Louis
MONKEYMAN Offline OP
St. Louis
Garbage disposal is leaking water out the bottom and it has always back-flowed garbage water into the broken dishwasher. This is a rental property where my job is located. The landlord may be doing the work, but if history repeats itself it could be a long wait. I am volunteering my time to switch things out if approved. At this point I am in Boy Scout mode: Be Prepared.
It is hard to know what basket assembly will work. Kinda like using conventional, synthetic, etc. grin
I have ruled out the $48 one from the local plumbing supply. I may be donating parts.
I almost bought a Peerless one from Wal-Mart for around $10.00. Menards has a table of basket assemblies with different finish and price. Seems $10 gets you low consumer quality. At $20 or more start seeing better materials, but does this matter? The sink will be used 3 times a day pretty much 7 days a week so I also want something that will be problem free down the road.
Will buy at Wal-Mart, Menards, Home Depot, or Lowes after get the go ahead from my boss. Any recommendations? Thanks!
Truth alone triumphs, not untruth.
2017 Elantra SE
Re: Kitchen sink basket assembly recommendations? [Re: MONKEYMAN] #4643335
01/22/18 08:31 PM
01/22/18 08:31 PM
North Carolina
spasm3 Online content
spasm3  Online Content
North Carolina
I have this one, it came with my sink. Its 304 stainless but has plastic ring, its also china made.
https://www.amazon.com/Kitchen-Sink-Stra...basket+assembly
If i had to replace it, this one looks a bit better than mine, stainless ring.
https://www.amazon.com/Strainer-Inchic-A...basket+assembly
13 elantra 70k 5w30 QSUD
03 chevy avalanche79k synpwr 10w30
01 saturnsc1 185k synpwr rebuilt
17 mazda cx-5 5600 miles m1 0w30
Re: Kitchen sink basket assembly recommendations? [Re: MONKEYMAN] #4643336
01/22/18 08:31 PM
01/22/18 08:31 PM
Ceciltucky Maryland
Oldtom Offline
Oldtom  Offline
Ceciltucky Maryland
A garbage disposal in a rental? What foul heresey is this? :-) Seriously tho, most rentals do not have garbage disposals because tenants will put anything down them and whine when the disposal jams or clogs up. One tenant poured a can of Drano into the disposal when it clogged. Drano loves to dissolve aluminum disposal bodies:-) I remove garbage disposals whenever found. Could you remove the disposal and reconnect with plastic pipe and flexible Fernco fittings? ( assuming you can get permission from the property owner) This might be easier.
Re: Kitchen sink basket assembly recommendations? [Re: Oldtom] #4643344
01/22/18 08:44 PM
01/22/18 08:44 PM
St. Louis
St. Louis
Basically it was a guys house. He moved out and made it a rental. He always says "it worked fine when I lived there", You would not believe the things that I removed from that garbage disposal.
All I need is the basket/strainer assembly. Bought a branch tailpiece for broken dishwasher to connect and another adapter so can center the p-trap. I am confident about switching things out, just not sure about basket/stainer assembly. I am thinking one like this:
Premium Brass Basket Assembly
2017 Elantra SE
Re: Kitchen sink basket assembly recommendations? [Re: spasm3] #4643350
01/22/18 08:48 PM
01/22/18 08:48 PM
St. Louis
St. Louis
Thanks, but will not do Amazon. I have a meeting at house Wednesday. If I have the blessing of landlord and my supervisor I will just buy locally and install Thursday. If landlord actually does his job I will return what I bought.
2017 Elantra SE
Re: Kitchen sink basket assembly recommendations? [Re: MONKEYMAN] #4643353
01/22/18 08:51 PM
01/22/18 08:51 PM
Ceciltucky Maryland
Oldtom Offline
Oldtom  Offline
Ceciltucky Maryland
This should work. I suggest using clear silicone seal rather than plumbers putty to seal the strainer into the sink. Silicone is horribly messy but almost eliminates leaks. The Fernco fittings I mentioned are a Godsend is anything is misaligned, as they are soft rubber and flex easily. Could you post pix of what you are trying to do?
Re: Kitchen sink basket assembly recommendations? [Re: MONKEYMAN] #4643361
01/22/18 08:56 PM
01/22/18 08:56 PM
Nowthen, MN
KD0AXS Offline
KD0AXS  Offline
Nowthen, MN
I got some commercial grade ones from Lowe's when we got a new sink with our granite countertops. IIRC they were about 15 bucks a piece and are definitely better quality than the cheap ones.
Re: Kitchen sink basket assembly recommendations? [Re: MONKEYMAN] #4643372
01/22/18 09:05 PM
01/22/18 09:05 PM
St. Louis
St. Louis
I will be turning off breaker, removing the leaking Badger, cap off wires, install basket/strainer assembly then get things centred. Those pipes on right are not leaking. Just kept bucket there so was going to re-use them:
Interesting your comment about Silicone. I have used it for years in other waterproofing applications. All the videos I watched said to use plumber's putty.
2017 Elantra SE
Re: Kitchen sink basket assembly recommendations? [Re: KD0AXS] #4643384
01/22/18 09:15 PM
01/22/18 09:15 PM
St. Louis
St. Louis
I did not spend as much time looking at Lowe's. Menards was the best. They had a big table with all kinds of assemblies to compare. Lowe's was not as easy for me to find things.
2017 Elantra SE
Re: Kitchen sink basket assembly recommendations? [Re: MONKEYMAN] #4643422
01/22/18 09:42 PM
01/22/18 09:42 PM
Chicago IL
ChiTDI Offline
ChiTDI  Offline
Chicago IL
I use Moen, because they don't wear out.
That said, the rubber o-ring set into the base of the basket strainer wears out regularly, and allows the sink to leak very slowly and might be a consideration for your original problem.
Re: Kitchen sink basket assembly recommendations? [Re: ChiTDI] #4643442
01/22/18 09:54 PM
01/22/18 09:54 PM
St. Louis
St. Louis
I did read some reviews of Moen at Home Depot. Must have been lower cost one since reviews not favourable. I am seeing price you pay, not necessarily Brand is setting them apart.
The water comes out of the bottom of the garbage disposal by the reset switch. It is an internal leak. There are a lot of videos on YouTube showing them rusting out and leaking.
2017 Elantra SE
Re: Kitchen sink basket assembly recommendations? [Re: MONKEYMAN] #4643480
01/22/18 10:37 PM
01/22/18 10:37 PM
Ceciltucky Maryland
Oldtom Offline
Oldtom  Offline
Ceciltucky Maryland
Disposals tend to corrode where the body attaches to the strainer. Possibly soak all the joints with a good penetrant a few days before? I would use Kroil or PB blaster rather than milder stuff like WD40. WD40 never worked for me. The disposal may need a good whack with a hammer to jar it loose. No problem if you break it as it is scrap anyway.
Re: Kitchen sink basket assembly recommendations? [Re: Oldtom] #4643495
01/22/18 11:06 PM
01/22/18 11:06 PM
St. Louis
St. Louis
Three weeks ago came to work on Sunday and was told bathroom and kitchen drain running slow. I carry tools in car just in case. Removing a toothpaste cap, soap, and hair fixed the bathroom drain. Fortunately, someone put a screen in the drain to prevent future problems.
When I checked the kitchen drain there was a puddle of water underneath. I started removing pipes to check for clogs. Water was coming out to dishwasher onto kitchen floor from the garbage disposal. Water supply was turned off to dishwasher. The garbage disposal literally fell into my when I checked for clogs it was so loose. I tightened it, ran some ice through garbage disposal and it drained fine. The p-trap and other drain pipes very clean. If you notice in the picture the hose to the right is the gross dishwasher drain hose stained with garbage. I ran dishwasher for hours to get rid of the strong odor. So, removing garage disposal will not be hard. It also has the InSinkErator mount. Just three screws and a ring to remove.
I am pushing the strainer changout since the garbage water coming out the dishwasher has been going on for years. It will take care of multiple issues at once.
Thanks again for all the ideas!
2017 Elantra SE
Re: Kitchen sink basket assembly recommendations? [Re: MONKEYMAN] #4643762
01/23/18 09:13 AM
01/23/18 09:13 AM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
I'd probably just replace his nasty badger with a wasteking 8000 if he would pay for it.
These go as low as high $70's on sale
https://www.amazon.com/Waste-King-Continuous-Garbage-Disposal/dp/B000DZGN7Q
TONS better than nasty grade badgers.
They also sell an adapter to use the badger mounting.
Re: Kitchen sink basket assembly recommendations? [Re: Rand] #4643918
01/23/18 11:03 AM
01/23/18 11:03 AM
St. Louis
St. Louis
Not sure that would solve the garbage water back flowing into the broken dishwasher. Also, all kinds of non food items end up in the garbage disposal. It is a liability having a garbage disposal at this point.
2017 Elantra SE
