Shell Rotella Grease
by WMW0505. 12/12/18 02:27 PM
Need to add attic ladder in stairwell
by Klutch9. 12/12/18 12:51 PM
Mystik JT-8 15w40, 2015 RAM EcoDiesel, 4,995 mi
by SavagePatch. 12/12/18 12:45 PM
Fram Tough Guard Air Filters at Rock Auto
by Snagglefoot. 12/12/18 12:42 PM
Electrical contact cleaner
by CELICA_XX. 12/12/18 12:32 PM
5w-30 in 277k mile chevy 350 tbi
by dogememe. 12/12/18 12:22 PM
voltage test for coolant condition
by NissanMaxima. 12/12/18 12:17 PM
paying Premiun for the name(infiniti/nissan
by 2008wrx. 12/12/18 11:25 AM
POE oil (R-410a)
by WyrTwister. 12/12/18 09:44 AM
Any Volvo Owners, need some help!
by LazyDog. 12/12/18 09:34 AM
NOACK & Sheer
by WyrTwister. 12/12/18 09:34 AM
Rotary help. 2010 series 2 RX8
by TinyVoices. 12/12/18 08:32 AM
Can you mathematically estimate top speed?
by KCJeep. 12/12/18 08:06 AM
2019 GM 6.2 AFM
by XL1200RFan. 12/12/18 07:32 AM
Dodge Challenger R/T Tips and Tricks?
by LoneRanger. 12/12/18 06:02 AM
MIL vehicle suggestion $8000
by madRiver. 12/12/18 06:00 AM
Toyota 2TR-FE 2.7 questions
by Doublehaul. 12/12/18 12:32 AM
Anybody used Eurolub?
by FordCapriDriver. 12/12/18 12:18 AM
jefe_de_estado, CM613, Geardaddies, 01ws666, ariefnrst
66660 Registered Users
116 registered members (AMC, aquariuscsm, 77GrandPrix, 28oz, 17 invisible), 1,858 guests, and 36 spiders.
Topics294,986
Posts4,925,432
Members66,660
Most Online2,553
Oct 27th, 2018
Page 1 of 3 1 2 3
Lubing your Ratchets? #4643170
01/22/18 04:41 PM
01/22/18 04:41 PM
VA
maverickfhs Offline OP
VA
So while in a quest to find use for one of the Super Lube grease which I have, ended up here :
Two of my ratchets 3/8 and 1/4 are sticking slightly and they are stanley made. I soaked them in ATF cup for almost 24 hrs and they are better, maybe need some greasing?
How often do you guys lube/grease ratchets and is ATF enough? Is greasing/lubing needed or an overkill?
Thank you thumbsup
2006 Civic EX 202K/AT
2006 Acura TSX 180K/AT
Re: Lubing your Ratchets? [Re: maverickfhs] #4643191
01/22/18 05:03 PM
01/22/18 05:03 PM
Cedarbrae, Ontario
xxch4osxx Offline
xxch4osxx  Offline
Cedarbrae, Ontario
I have never lubed any of my ratchets and I have had a couple of them for 20 years or more.
2015 RAM SXT Crew Cab 5.7 with 6 speed tranny.
2008 Mazda 3 GS Sport Hatchback 5sp MT (Girlfriend's car)
Re: Lubing your Ratchets? [Re: maverickfhs] #4643197
01/22/18 05:15 PM
01/22/18 05:15 PM
Ohio
beast3300 Offline
beast3300  Offline
Ohio
Nope. Never lubed them either unless you count brake fluid and water.
'03 Regal GS L67: PPUP 5w30/FU3980
'99 Grand Prix L36: R.I.P.
'07 LaCrosse L26: QS HM 5w30/TG3387A
ASE L1 MT
Re: Lubing your Ratchets? [Re: maverickfhs] #4643224
01/22/18 05:47 PM
01/22/18 05:47 PM
Lyndhurst NJ
Audios Offline
Audios  Offline
Lyndhurst NJ
The old timer I used to work with at an antique repair shop used to soak his ratchets overnight in clean motor out every once in a while, upside down so he only needed a few ounces. All of my snap ons say do not lubricate.
2002 VW Golf TDI-Mobil 1 5/40 TDT
2007 Mercedes GL320 CDI Fuchs 5/40 GT Pro XTL
2005 BMW M3 BMW Twin Power 10/60
2003 BMW M5-Fuchs 5/40
1998 BMW M3/4/5 Fuchs 5/40
Re: Lubing your Ratchets? [Re: maverickfhs] #4643233
01/22/18 06:06 PM
01/22/18 06:06 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
I lube all mine. fine tooth ones get oil. Coarse ones get grease.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Lubing your Ratchets? [Re: maverickfhs] #4643247
01/22/18 06:21 PM
01/22/18 06:21 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
I've found that white lithium grease works well ... not too thin, not too thick.
Re: Lubing your Ratchets? [Re: maverickfhs] #4643278
01/22/18 06:55 PM
01/22/18 06:55 PM
North Carolina
rooflessVW Online content
rooflessVW  Online Content
North Carolina
I only lube them if they get wet. Valvoline moly grease, a nice light coat.
"Zed's dead baby, Zed's dead."
Re: Lubing your Ratchets? [Re: maverickfhs] #4643299
01/22/18 07:07 PM
01/22/18 07:07 PM
Katy, Republic of Texas
blupupher Offline
blupupher  Offline
Does getting them coated in oil or atf when using them count?
2012 xB: QSUD 0w-20/CQ Blue/5k
2010 Santa Fe: PP 0w-20/P1/8k
2007 Vue: VSP 5w-30/EcoGard/OLM
2004 F150: GTX HM 5w-20/TG2/4k
2002 F150: GTX HM 5w-20/EcoGard/1yr
1994 VT1100c: Peak 15w-40/PSL/5k
Re: Lubing your Ratchets? [Re: maverickfhs] #4643317
01/22/18 07:18 PM
01/22/18 07:18 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
I lube mine. Have only one snap-On ratchet. It gets lubed just like the others. Fine tooth and about 30 odd years of use smile
Re: Lubing your Ratchets? [Re: maverickfhs] #4643368
01/22/18 08:04 PM
01/22/18 08:04 PM
Missouri
cb_13 Offline
cb_13  Offline
Missouri
I use to pack the heads of mine with Motorcraft dielectric grease/brake caliper grease if they were serviceable. I used mostly non serviceable ratchets after my first few years as a tech.
Re: Lubing your Ratchets? [Re: maverickfhs] #4643382
01/22/18 08:14 PM
01/22/18 08:14 PM
San Antonio, TX
das_peikko Offline
das_peikko  Offline
San Antonio, TX
I use the Superlube on Snap-on ratchets mainly because it's the only lube I've used that doesn't swell the seals up. I've had to buy rebuild kits just for the seals after subjecting them to alternative lubes that cause them to swell. With non-sealed ratchets, I prefer the Permatex engine assembly lube.
Re: Lubing your Ratchets? [Re: maverickfhs] #4643385
01/22/18 08:18 PM
01/22/18 08:18 PM
out there
spasm3 Offline
spasm3  Offline
out there
Originally Posted By: Trav
I have been putting the ratchet heads in a small cut down jug of ATF every weekend for decades, it keeps them clean and lubricates them well. Just let them sit on a couple of paper towels when you remove them and wipe them off, that's it.
The only one I don't put in there is the Snap-On dual 80 with a sealed head. Some manual transmissions use ATF in place of MTF and it manages to keep the gears and internals properly lubed.
I am going to try this. I have craftsman and blackhawk ratchts.
13 elantra 72k 5w30 QSUD
03 chevy avalanche 80k synpwr 5w30
17 mazda cx-5 7300 miles m1 0w30
Re: Lubing your Ratchets? [Re: maverickfhs] #4643402
01/22/18 08:31 PM
01/22/18 08:31 PM
MI
doitmyself Offline
doitmyself  Offline
MI
Google "the red lube of love", crackmeup Merk's favorite.
Re: Lubing your Ratchets? [Re: doitmyself] #4643411
01/22/18 08:37 PM
01/22/18 08:37 PM
San Antonio, TX
das_peikko Offline
das_peikko  Offline
San Antonio, TX
Who's Merk? Or maybe I should ask, what is a Merk?
Re: Lubing your Ratchets? [Re: maverickfhs] #4643424
01/22/18 08:42 PM
01/22/18 08:42 PM
Maryland
malibuguy79 Offline
malibuguy79  Offline
Maryland
I usually put a drop or 2 of airtool oil in my ratchets and ratcheting wrecnhes maybe 2wice a year. Always a little smoother after
Greg...the exhaust guy
I have a 10 Yaris, 97 Tercel 1nzfe swap coming, 82 Malibu 1uzfe swap in progress, 84 Bonneville street/strip car
She has 18 Fit and 01 Forester
Page 1 of 3 1 2 3
