Originally Posted By: dnewton3
...For comparison, consider this ...
Motorcraft 5/20 Blend - 2015 3.7l TiVTC. (4220Mi)
here's another UOA, shorter OCI at 4k miles, and the Fe is at 8ppm. So, the exact same wear rate exists (2.x ppm/1k miles).
And the engine here has a very low fuel content, so you cannot blame fuel here, can you? This engine isn’t even DI. ...
Results on that unit actually track more closely with hours than miles. Number in parenthesis are running hours/idle hours for the OCI and the percentage is the oil life indicated by a vehicle health report.
01/21/2016 - 4978 miles, 289hrs running, 191hrs idle 51%
03/16/2016- 10,042 miles, 645hrs running, 445hrs idle (356/254) 3% (not reset @ 1st change)
05/16/2016 - 14,954 miles, 891hrs running, 596hrs idle (246/151) 51%
06/27/2016 - 20,270 miles, 1070 hrs running, 681hrs idle (179/85) 41%
11/07/2016 - 24,991 miles, 1292 hrs running, 805 hrs idle (222/124) 0% (not reset @20,270)
02/07/2017 - 30,165 miles, 1467 hrs running, 878 hrs idle (175/73) Forgot to run
04/28/2017 - 34, 934 miles, 1757 hrs running, 1070 hrs idle (290/192) 52%
08/04/2017 - 40,355 miles, 2184 hrs running, 1387 hrs idle (427/317) 39%
11/09/2017 - 44,575 miles, 2301 hrs running, 1416 hrs idle (117/29) 58%
The flashpoint might leave one to question the accuracy of the fuel content as well...
