2005 Chevy Silverado 5.3 vortex
by MSpeer. 12/17/18 12:01 PM
Comma X-Tech 5w30 oil, any good?
by BobGoblin. 12/17/18 11:40 AM
Modern Engine's Grenading?
by Nickdfresh. 12/17/18 11:15 AM
Magnetic Smartphone Holders
by willbur. 12/17/18 11:06 AM
1991 Caprice 5.0l hard starting in the AM
by WyrTwister. 12/17/18 10:55 AM
Question about new Peak OEM coolants
by PD001. 12/17/18 10:21 AM
Rev X
by Big_3_Only. 12/17/18 10:04 AM
Modern engines put less contaminants in the oil?
by WyrTwister. 12/17/18 08:12 AM
Gear whine
by odotb. 12/17/18 07:38 AM
Honda Pilot Oil specs US vs Overseas
by parshisa. 12/17/18 06:23 AM
Advisory on Roku TV's
by LoneRanger. 12/17/18 05:44 AM
Chevy Commercial Parody
by 02SE. 12/17/18 02:37 AM
Fluctuating Tachometer Fixed!
by jerseyguy123. 12/17/18 02:10 AM
2015 MB GLA250: OEM oil vs Mobil1 Formula M
by SlavaB. 12/17/18 12:39 AM
Shotgun Ammo
by user52165. 12/16/18 10:24 PM
Bought a Model 3 for wifey
by JeffKeryk. 12/16/18 09:01 PM
harvey_01, Gordon_Walter, MikeSheng, stantaur, Brandon9797
66703 Registered Users
103 registered members (aba4430, 4WD, 99Eclipse, AdditiveOCD, 8 invisible), 2,088 guests, and 47 spiders.
Topics295,186
Posts4,929,407
Members66,703
Most Online2,553
Oct 27th, 2018
1995 chevy ck1500 dome light wont turn on #4642875
01/22/18 12:16 PM
01/22/18 12:16 PM
Midwest
volk06 Offline OP
volk06  Offline OP
Midwest
Hi all,
Working on a family members chevy 1500. The dome light does not turn on at all. Replaced the fuse and dome light bulb and it still does not turn on. When you open the door, all the other interior lights turn and the push button lights on each side of the dome light work. The dome light override push button on the dash works and was in the out position and the other interior lights work, so that is not the problem. Door jamb switches are good as the other lights turn on and off with it. Before replacing the whole assembly, does anyone else have any ideas? Not really an electrical or chevy person.
Thanks
2011 F-150 Ecoboost
2012 Focus S
2001 Taurus
Re: 1995 chevy ck1500 dome light wont turn on [Re: volk06] #4642924
01/22/18 01:06 PM
01/22/18 01:06 PM
Ontario Niagara region
Drosselmier Offline
Drosselmier  Offline
Corroded socket or bad lamp. Can you get test leads into the socket? Seems like you have power to the socket.
Re: 1995 chevy ck1500 dome light wont turn on [Re: volk06] #4642925
01/22/18 01:06 PM
01/22/18 01:06 PM
Guilford, CT
exranger06 Offline
exranger06  Offline
Guilford, CT
Here's a wiring diagram.
Looks like you could have a break in the wire anywhere from the dome light to splice 242, or from the light to splice 209. See if you have power or ground at the light socket to narrow it down. If you have power, you probably have a break in the ground wire. If you have ground but no power, you have a break in the power wire.
2006 Ford Ranger Sport
1992 Honda Accord EX
2004 Honda CR-V LX
1994 Ford Bronco XLT (project)
2011 Cadillac Escalade ESV (wife's)
Re: 1995 chevy ck1500 dome light wont turn on [Re: volk06] #4642932
01/22/18 01:12 PM
01/22/18 01:12 PM
Massachusetts
VeryNoisyPoet Offline
Massachusetts
Are the push button lights supposed to come on with the door open as well?
EDIT: just saw the diagram, so it appears to be the case.
If the courtesy lights come on with the Dome Lamp Defeat (override switch), and only the dome light refuses to work, then the problem is somewhere in the circuit between S242 (where the wires branch off from) and S209 (where the wires come together just before the Headlamp and Panel Dimmer Switch). This includes the socket and the connections inside the dome lamp assembly itself.
1998 V70 GLT / 195k miles [10w-30 Valvoline Syn w/ Maxlife Tech + Mann W917 filter]
"Use yah blinkah!"
"Be nice. The alternative involves an air horn and 7000 lumens of high beam."
Re: 1995 chevy ck1500 dome light wont turn on [Re: volk06] #4642968
01/22/18 01:38 PM
01/22/18 01:38 PM
USA
mk378 Offline
mk378  Offline
USA
First measure voltage across the bulb with the switch on, if there is voltage but no light, your new bulb is DOA. If you are using a LED bulb, most of them work only when plugged in one way so try reversing it.
If no voltage at the bulb, next check the wires going to the socket, voltage there means the socket is bad.
The orange wire should be live all the time. The various switches connect the white wire to ground to turn the light on. The footwell lights and the ceiling light are all wired in parallel, they should all go on or off at the same time.
Re: 1995 chevy ck1500 dome light wont turn on [Re: VeryNoisyPoet] #4642972
01/22/18 01:39 PM
01/22/18 01:39 PM
Midwest
volk06 Offline OP
volk06  Offline OP
Midwest
If I remember correctly, the push button on each side of the dome light only come on if you actually push the button. If they came on when the door was open, the dome light not working would be moot. When you push the button, those lights do work.
2011 F-150 Ecoboost
2012 Focus S
2001 Taurus
Re: 1995 chevy ck1500 dome light wont turn on [Re: volk06] #4642977
01/22/18 01:42 PM
01/22/18 01:42 PM
Midwest
volk06 Offline OP
volk06  Offline OP
Midwest
Thanks for all the responses so far. I will have to do some more checking the next time the vehicle is at my house. Looks like I'll have to buy a cheap multi-meter as well.
2011 F-150 Ecoboost
2012 Focus S
2001 Taurus
Re: 1995 chevy ck1500 dome light wont turn on [Re: volk06] #4643251
01/22/18 06:27 PM
01/22/18 06:27 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
Get a flashlight. It's a 1995 truck.
2015 Ford F250 w/Powerstroke
Re: 1995 chevy ck1500 dome light wont turn on [Re: Donald] #4643365
01/22/18 07:58 PM
01/22/18 07:58 PM
Fort Worth, Texas
clinebarger Offline
clinebarger  Offline
Fort Worth, Texas
So what? I've owned 70 year old vehicles that every bulb & switch worked.
2001 Chevy Camaro L92/4L80E
Re: 1995 chevy ck1500 dome light wont turn on [Re: Donald] #4643462
01/22/18 09:19 PM
01/22/18 09:19 PM
Midwest
volk06 Offline OP
volk06  Offline OP
Midwest
This vehicle is for an older family member who would like to be able to see when getting in his truck. Take your arrogance somewhere else as itís not needed or helpful.
2011 F-150 Ecoboost
2012 Focus S
2001 Taurus
Re: 1995 chevy ck1500 dome light wont turn on [Re: volk06] #4666442
02/15/18 06:30 AM
02/15/18 06:30 AM
dayton oh
kc8adu Offline
kc8adu  Offline
dayton oh
every gm dome i have dealt with has an always live orange wire and a white to the door switches which completes the circuit to ground.
corrosion in the bulb clips and wire crimps most common.
Re: 1995 chevy ck1500 dome light wont turn on [Re: volk06] #4666901
02/15/18 02:48 PM
02/15/18 02:48 PM
PA
volvos_rock Offline
volvos_rock  Offline
PA
Including my two 98s, the door switches were always the suspects, even when they appeared fine.
Volvo: 09 S80, 07 V50
Mercedes-Benz: 16 Metris
Chevrolet: 98 K1500, 98 K3500
Pontiac: 65 Lemans convt
Re: 1995 chevy ck1500 dome light wont turn on [Re: volk06] #4669980
02/18/18 04:48 PM
02/18/18 04:48 PM
Central Virginia
Silverado12 Offline
Silverado12  Offline
Central Virginia
That and check all grounds.
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
18 Mustang GT 5.0 auto
07 Harley Dyna Street Bob 96 c.i. 6 sp.
00 Mustang GT auto
