Ford Pickup Front Wheel Bearings 2WD
by benjamming. 12/14/18 10:52 PM
GMC oil fill tube
by Redright9. 12/14/18 10:24 PM
Where do I buy Toto toilets? That has them!
by Vern_in_IL. 12/14/18 10:04 PM
Best filter cutter for the price?
by DONWATERS. 12/14/18 09:38 PM
5W-40 vs 10W-30 for a 2018 Audi A4
by jcr1293. 12/14/18 09:25 PM
Gave up on quadrajet electric choke today...
by leroyd92. 12/14/18 08:54 PM
2015 Odyssey - Which synthetic ATF?
by AngryScientist. 12/14/18 07:56 PM
Hyundai extended my warranty
by ernied. 12/14/18 07:33 PM
2016 Traverse 6350mi Schaeffers 9000 5W30
by chevman4life. 12/14/18 07:21 PM
Oil filter for Canadian winter
by Popsy. 12/14/18 06:11 PM
12-14-18 only! Irwin vise @ Menards. $99.99
by Kruse. 12/14/18 06:01 PM
10" Subwoofer - $6.52 Each
by Greg L. 12/14/18 05:31 PM
Finding 507.00 spec oil
by sloinker. 12/14/18 05:31 PM
New Tires for the Old Chevy!
by dogememe. 12/14/18 05:09 PM
Back to Basics II
by MolaKule. 12/14/18 04:31 PM
"SG(+)" 15w40 or better oil 1987 BBC 454
by F239141. 12/14/18 03:52 PM
All Mazda 3’s have bad OCV’s?
by buster. 12/14/18 03:44 PM
NEKGuy, Deltafaatl, wsalopek, jcr1293, maxwellk
66684 Registered Users
36 registered members (crinkles, dishdude, Blkstanger, CKN, ammowaster, 1 invisible), 934 guests, and 42 spiders.
Topics295,090
Posts4,927,627
Members66,684
Most Online2,553
Oct 27th, 2018
A slide/rail wear question #4642847
01/22/18 11:49 AM
01/22/18 11:49 AM
Ontario, Canada
newbe46 Offline OP
newbe46  Offline OP
Ontario, Canada
I'm pretty sure this has been discussed at length since the beginning of time. Just before I dive into the see of debate on Google I'd like your opinions on firearms maintenance.
The question is, should I be worried if the finishing/coating on the slide where it meets the frame has worn to show the bare metal?
2003 E46 M3 Convertible
2004 Odyssey EX-L
2004 Impreza TS Wagon
Re: A slide/rail wear question [Re: newbe46] #4642872
01/22/18 12:16 PM
01/22/18 12:16 PM
Texas
2009Edge Offline
2009Edge  Offline
Texas
Worry all you want, it won't solve anything. grin
Re: A slide/rail wear question [Re: 2009Edge] #4642952
01/22/18 01:27 PM
01/22/18 01:27 PM
OR, USA
bsmithwins Offline
bsmithwins  Offline
OR, USA
Guns are tools and tools get worn. If you use it enough it will get worn out, eventually.
That said, even SIG Sauer pistols, which have steel running on the aluminum rails, have a lifetime of 10s of thousands of rounds. By that point youll have spent many multiples of the pistol's cost on ammo to run through it.
Lube is good, what specific type is less important than using enough. What exact type Id use would depend on the use. For a gun thats carried exposed to the cold in winter, Id use a thinner gun oil. Arizona in the summer, Id probably use a gun grease.
BSW
Re: A slide/rail wear question [Re: newbe46] #4643033
01/22/18 02:37 PM
01/22/18 02:37 PM
Where the wind comes sweepin'
Reddy45 Offline
Reddy45  Offline
Nope not an issue. There aren't too many coatings in existence (if any) that can put up with that level of abrasion.
I do, however, grease my slide rails, separately from using oil on every other part. The grease I use is called Shooter's Choice and it comes in a plastic syringe. Seems to do a good job and sticks around.
Re: A slide/rail wear question [Re: newbe46] #4643074
01/22/18 03:02 PM
01/22/18 03:02 PM
Ontario, Canada
newbe46 Offline OP
newbe46  Offline OP
Ontario, Canada
Thanks for the replies.
2004 Odyssey EX-L
