Synthetic motor oil in a gun
by Yuk. 03/26/19 01:07 AM
air suspension on a towed trailer?
by columnshift. 03/25/19 11:57 PM
AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
29 registered members (Brad_C, bbhero, c502cid, 5 invisible), 531 guests, and 59 spiders.
Topics286,442
Posts4,908,265
Members67,622
Most Online2,967
Mar 10th, 2019
Brake Pad Codes #4642745
01/22/18 11:16 AM
01/22/18 11:16 AM
wv
krismoriah72 Offline OP
wv
I have installed hundreds of sets of brakes over the years and never paid any attention to Brake Pad Codes. This past week I have tried to understand the codes and how they translate to the buying experience when you are looking for brake pads for a vehicle.
According to the DOT pad codes http://faculty.ccbcmd.edu/~smacadof/DOTPadCodes.htm
"So EE pads have only marginally more torque than no pads at all! Therefore FF pads are usually considered the minimum for a high-performance pad."
According to an explanation of this same website by an 'expert'.. Making Sense of DOT Brake Pad Codes https://www.youtube.com/watch?v=MJ2OJptdaTM
He explains that GG pads are "Pretty Hardcore Race Pads"
So with those tools in hand because you cannot find any information online I went to auto parts stores to see the pads and read the codes.
The application is a 1/2 Ton and some 3/4 ton chevrolet pickup/tahoe/suburban which is a very common vehicle.
Wagner Severe Duty SD- DOT Code EE- as stated above "marginally more torque than no pads at all" From Wagners Decription of these pads "Formulated for extreme heat, frequent stopping and heavy loads, these brake pads feature exceptional pad strength and longer pad life."
Wagner Thermoquiet Ceramic- DOT Code GG- As stated above they are 'pretty hardcore race pads' The decription of these pads mostly talk about low dusting.
So in summary- from the explanations of the codes EE is like having no pads at all and FF would be a good choice for a daily driver with GG being for racing vehicles.
Wagner Severe Duty Pads- for fleet and municipality vehicles/ Police Pursuit- EE Code.
Wagner Thermoquiet Ceramic- for daily drivers and those looking for low dust- GG Code.
I have various other codes from NAPA and Advance but just to keep it less confusing I kept it to Wagner for the sake of this query. Due to the variation on house brand sources.
Are the codes nonsensical? Do the codes even matter? Or do you just go by the picture on the box?
Re: Brake Pad Codes [Re: krismoriah72] #4642854
01/22/18 01:00 PM
01/22/18 01:00 PM
NoVA
Jimzz Offline
Jimzz  Offline
NoVA
The codes are almost worthless now. They are self regulated so the pad maker can put on their what they like.
Let alone they are also outdated as the ranges they give for each ranking are so wide even if the pad makers were honest it does not tell you much anymore.
yup
Re: Brake Pad Codes [Re: krismoriah72] #4642955
01/22/18 02:28 PM
01/22/18 02:28 PM
Baltimore, Maryland, USA
zzyzzx Offline
zzyzzx  Offline
I don't even look at the codes. Last time I just bought Monroe semi-matallics and so fer they are working out just fine.
Re: Brake Pad Codes [Re: krismoriah72] #4643122
01/22/18 04:42 PM
01/22/18 04:42 PM
California
nthach Offline
nthach  Offline
California
I don't think codes are that meaningful. Trust the OEM specs or what's in the box.
