Good Purchase?
by FordBroncoVWJeta. 03/19/19 11:33 AM
not sure what spark plugs to buy now
by MrTruckDriver. 03/19/19 11:33 AM
Tires on a Lease Return
by clarkflower. 03/19/19 11:25 AM
Auto-Rx now available on Amazon
by LarryD. 03/19/19 11:14 AM
Best place to advertise used car for sale?
by Ed_Flecko. 03/19/19 10:51 AM
A little help with a 2010 Santa Fe
by nicholas. 03/19/19 10:50 AM
Lawn Mower Battery - What's Up with That?
by Astro_Guy. 03/19/19 10:34 AM
This makes me sick
by SLO_Town. 03/19/19 10:32 AM
Slanderous Fram Orange Can Review
by doitmyself. 03/19/19 08:39 AM
MRV of PP EURO 0W40 an anomaly?
by 21Rouge. 03/19/19 08:39 AM
The Beater is Even Uglier Now!
by Delta. 03/19/19 08:28 AM
Oil viscosities at 200 to 225 F
by Snagglefoot. 03/19/19 07:35 AM
What would you do...
by Bailes1992. 03/19/19 05:28 AM
'65 Mini.
by Silk. 03/19/19 02:08 AM
Our trash guy is getting on my nerves.
by Chris142. 03/19/19 01:20 AM
Ecogard trans filter
by pda1122. 03/19/19 12:11 AM
4.3 vortec issues
by mobilaltima. 03/18/19 09:17 PM
Recommendation for filter for Alfa Romeo 4C?
by phaphaphooey. 03/18/19 09:17 PM
tbann, LisaMC, chops, drsoils, Gbear
67554 Registered Users
105 registered members (77GrandPrix, AandPDan, AdditiveOCD, 28oz, 11 invisible), 2,169 guests, and 66 spiders.
Topics286,063
Posts4,901,778
Members67,554
Most Online2,967
Mar 10th, 2019
2002 Silverado 5.3 Slow start, starter or wires? #4642677
01/22/18 10:12 AM
01/22/18 10:12 AM
CA
Gito Offline OP
Gito  Offline OP
CA
Own a 2002 Chevy Silverado with 340k miles.
Been noticing a slow crank before the truck starts. At first I thought it was the battery but it was tested and its good.
Then I thought it might be the starter but since the truck has been starting fine each time and hasn't missed I thought I better look elsewhere.
Again, its a weak crank (weak start) but starts each time.
Have not checked the alternator. I figure the battery would have been dead by now if the alternator was the culprit (need to check that)
Wires? starter? battery? alternator?
Any advice is greatly appreciated
Re: 2002 Silverado 5.3 Slow start, starter or wires? [Re: Gito] #4642683
01/22/18 10:17 AM
01/22/18 10:17 AM
Storrs, Connecticut
jeepman3071 Offline
jeepman3071  Offline
Storrs, Connecticut
Have you load tested the battery? I've seen some batteries that seem to be putting out adequate voltage until load testing them. Check all wire connections and make sure they are shiny clean and tight.
If all of the above tests fine your starter might be going out. The starter in my Jeep just died a month ago. It was cranking slower and slower until one day it barely turned over. At one point my oil filter housing adapter gasket was leaking all over the starter, which I'm sure is what led to it's death.
2000 Jeep Cherokee 4.0L (181k) - Pennzoil 10w30, Napa Gold 1516, Magnefine trans filter
2009 BMW 328i (38k) - Castrol Edge Euro 0w40, MANN HU816X
Re: 2002 Silverado 5.3 Slow start, starter or wires? [Re: Gito] #4642687
01/22/18 10:19 AM
01/22/18 10:19 AM
South Carolina
pcoxe Offline
pcoxe  Offline
South Carolina
Check the battery terminals for corrosion, or just clean them up anyway. A small amount of resistance can drop the voltage.
Re: 2002 Silverado 5.3 Slow start, starter or wires? [Re: Gito] #4642689
01/22/18 10:20 AM
01/22/18 10:20 AM
wv
krismoriah72 Offline
wv
Either put a multimeter on your current battery or jump it with jumper cables or a jump box to rule out the battery.. My guess is that its a warning sign of your starter.
Re: 2002 Silverado 5.3 Slow start, starter or wires? [Re: pcoxe] #4642694
01/22/18 10:25 AM
01/22/18 10:25 AM
Michigan
64bawagon Offline
64bawagon  Offline
Michigan
This
64 Chevy wagon, 10 Jeep Wrangler, 18 Silverado 1/2 ton
Re: 2002 Silverado 5.3 Slow start, starter or wires? [Re: Gito] #4642701
01/22/18 10:30 AM
01/22/18 10:30 AM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
you need to diagnose the problem,,check all the listed parts you mentioned then if they are fine check some more. It sounds like new vehicle time.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: 2002 Silverado 5.3 Slow start, starter or wires? [Re: Gito] #4642727
01/22/18 10:56 AM
01/22/18 10:56 AM
CA
Gito Offline OP
Gito  Offline OP
CA
Father in law also drives a Silverado. Swapped out batteries a few minutes ago and my truck has same symptoms. Battery not the issue.
Re: 2002 Silverado 5.3 Slow start, starter or wires? [Re: Gito] #4642731
01/22/18 10:59 AM
01/22/18 10:59 AM
CA
Gito Offline OP
Gito  Offline OP
CA
Going to clean the contacts and report back.
Re: 2002 Silverado 5.3 Slow start, starter or wires? [Re: Gito] #4642752
01/22/18 11:28 AM
01/22/18 11:28 AM
California
VeryNoisyPoet Offline
California
If battery passes a load test and battery terminals are clean and tight, the problem is elsewhere. Test the wiring between battery, starter, and block. You will need a helper and a digital multimeter for this.
Pull the fuel pump fuse while engine is idling to bleed off the fuel rail pressure. Now the engine will crank without starting but without dumping in raw fuel. Put a multimeter on the 2 volt range. Attach one meter lead to the battery positive terminal. Attach the other meter lead to the starter positive terminal post. Use the points of the probes to dig in through any dirt or corrosion to get a solid connection.
Now have your helper crank the engine for 5 seconds and watch the multimeter reading. You should see under 1 volt, preferably under 0.5 volt.
Next connect one meter lead to the starter housing, and the other to the engine block. Again dig in the points of the probes to get a good connection. Have your helper crank again for 5 seconds. There should be very little voltage drop here, under 0.1 volt.
Now check between engine block and battery negative terminal. Dig in probe points, crank for 5 sec, watch the meter. Should be less than 0.5 volts here.
If any of those tests returns a high voltage drop, there is a bad connection that is starving your starter of voltage. Solutions could be as simple as cleaning terminals at starter, at battery, and at the engine block negative connection.
Could be as invasive as cleaning between starter and block or replacing internally corroded starter positive cable or engine block negative cable.
But if those tests come back okay, and the engine still cranks sluggish, maybe there is a problem with the starter motor itself.
1998 V70 GLT / 202k miles [10w-30 Valvoline Syn w/ Maxlife Tech + Mann W917 filter]
"Use yah blinkah!"
"Be nice. The alternative involves an air horn and 7000 lumens of high beam."
Re: 2002 Silverado 5.3 Slow start, starter or wires? [Re: pcoxe] #4642758
01/22/18 11:33 AM
01/22/18 11:33 AM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
Time for new cables. The crimp ends now have crevice corrosion and I'll bet the ground point on the engine has never been touched ...
New ground cable (mostly needed) with the crimps soldered too while the wire is fresh. I'd go up a size. But that's up to you... I'd also add a >#8 fine stranded wire from Bat (-) clamp bolt to radiator support and one to alternator mount. Crimped and soldered terminals.
Remember that all the current going though a circuit has to return via ground path, but with no available voltage to drive it. So ground is mostly overlooked and is more in need of attention.
Should spin right up smile
Re: 2002 Silverado 5.3 Slow start, starter or wires? [Re: Gito] #4642792
01/22/18 12:02 PM
01/22/18 12:02 PM
San Antonio, Texas
sasilverbullet Offline
San Antonio, Texas
What everybody said so far, once you have battery, cables, starter, connections all verified, with that many miles on the engine it might be time for a rebuild. Over the years I've noticed the ones that are ready for a rebuild will start to turn over slowly.
Hope that's not your case...
03 Porsche 911 Liqui Moly Leichtlauf High Tech 5w-40 & Mahle filter
14 Honda Accord 4dr EX-L 4cyl-M1 0W-20 & WIX XP
02 Chevy 5.7L van-GTX HM 10W-40 & WIX filter
Re: 2002 Silverado 5.3 Slow start, starter or wires? [Re: Gito] #4642800
01/22/18 12:06 PM
01/22/18 12:06 PM
North Carolina
Rat407 Online content
Rat407  Online Content
North Carolina
After cleaning up all the electrical connections and vehicle grounds, the next step is to check fuel pressure at the fuel rail. You can get a gauge to use from Auto Zone. Mine didn't want to start and it turned out my fuel pump was going and the fuel pressure was low, 45psi and it is supposed to be 50spi.
What was happening is it wouldn't start on the first crank of the key but the second bump it fired right up.
Now if fires right up every time.
2002 Silverado 5.3 0w-20 AMSOIL
Re: 2002 Silverado 5.3 Slow start, starter or wires? [Re: Gito] #4642874
01/22/18 01:16 PM
01/22/18 01:16 PM
Michigan
64bawagon Offline
64bawagon  Offline
Michigan
It could also be a starter on its way out. A weak, worn out starter would have the symptom
Re: 2002 Silverado 5.3 Slow start, starter or wires? [Re: Gito] #4642878
01/22/18 01:21 PM
01/22/18 01:21 PM
KS
DerbyDave Offline
DerbyDave  Offline
KS
I had a Taurus that had similar symptoms. The starter was going out, I took it to OReilly's and had them hook up their electrical test equipment. The starter was drawing way more current than it should have been. I replaced the started and all was good again.
1997 Ford Taurus
2005 Buick Terraza
2007 Honda Ridgeline
1986 Suzuki Cavalcade
1986 Suzuki Intruder
Re: 2002 Silverado 5.3 Slow start, starter or wires? [Re: Gito] #4642885
01/22/18 01:32 PM
01/22/18 01:32 PM
Idaho
RonRonnster Offline
RonRonnster  Offline
Idaho
FWIW I've had a couple different SBC starters turn over really slowly but test out fine on the bench at the auto parts store. The first time, I chased it around everywhere - battery, terminals, cables, etc. Finally put a new starter in (even though it tested fine on the bench) and problem solved. The second time it happened, I purchased the new starter right away after the battery and cables checked out. Problem solved. My theory is that the starter tests fine on a bench with no real load. Something to consider, anyway.
- 2007 GMC Yukon XL Denali - 6.2L / 81k mi.
- 1998 Chev K1500 4x4 - 5.7L / 155k mi.
