2019 GM 6.2 AFM
by XL1200RFan. 12/12/18 07:32 AM
Dodge Challenger R/T Tips and Tricks?
by LoneRanger. 12/12/18 06:02 AM
MIL vehicle suggestion $8000
by madRiver. 12/12/18 06:00 AM
Toyota 2TR-FE 2.7 questions
by Doublehaul. 12/12/18 12:32 AM
Anybody used Eurolub?
by FordCapriDriver. 12/12/18 12:18 AM
Micro-Green Cut Open
by David1. 12/11/18 11:45 PM
Witch way does this valve work?
by Dylan1303. 12/11/18 11:42 PM
Santa came early..
by leoblack9. 12/11/18 11:22 PM
dropped a zip tie in my prius trans
by eljefino. 12/11/18 09:54 PM
2 Cello's - Some talented fellows right here.
by StevieC. 12/11/18 09:49 PM
Something different for sure - Punjabi Celtic
by StevieC. 12/11/18 09:40 PM
Honda eu200i hiccuping @ low idle - fixed
by Jmoney7269. 12/11/18 09:34 PM
Your dealer is here - Humor
by StevieC. 12/11/18 08:46 PM
1994 Honda Civic LX Main Relay-solder
by Gito. 12/11/18 08:43 PM
Winter/Summer Fuel Economy
by RayCJ. 12/11/18 08:33 PM
0w20 oils - NOACK
by superangrypenguin. 12/11/18 08:19 PM
Liqui Moly Special Tec AA 5w20 API SN
by Johnny248. 12/11/18 08:15 PM
Buy a brand new 1966-1977 Ford Bronco
by StevieC. 12/11/18 07:50 PM
ariefnrst, tcoffin014, Schm1d, EagleC, Dinka
66655 Registered Users
77 registered members (2004tdigls, Astro14, bigal51, aba4430, Alfred_B, AndyB, 5 invisible), 1,463 guests, and 28 spiders.
Topics294,967
Posts4,925,033
Members66,655
Most Online2,553
Oct 27th, 2018
DEXOS1 Gen 2 : Best For GDI Of All Makes ? #4642543
01/22/18 06:26 AM
01/22/18 06:26 AM
GA.
ChrisD46 Offline OP
ChrisD46  Offline OP
GA.
While DEXOS1 Gen2 is a GM oil spec - what are your thoughts that DEXOS1 Gen 2 would be the best US oil for all makes of GDI engines which use 0W20/30 or 5W20/30 ?
2017 Hyundai Sonata 2.4L GDI 4 cylinder
2010 Hyundai Elantra 2.0L 4 cylinder
2007 Kia Sedona 3.8L 6 cylinder
Re: DEXOS1 Gen 2 : Best For GDI Of All Makes ? [Re: ChrisD46] #4642548
01/22/18 06:33 AM
01/22/18 06:33 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
I prefer an A3/B4 oil, Mobil 1 0w40 would be fine where you are.
Re: DEXOS1 Gen 2 : Best For GDI Of All Makes ? [Re: Trav] #4642557
01/22/18 06:45 AM
01/22/18 06:45 AM
North Carolina
rooflessVW Offline
rooflessVW  Offline
North Carolina
+1
"Zed's dead baby, Zed's dead."
Re: DEXOS1 Gen 2 : Best For GDI Of All Makes ? [Re: ChrisD46] #4642569
01/22/18 07:10 AM
01/22/18 07:10 AM
Kendall, FL
wemay Offline
wemay  Offline
Kendall, FL
All GDi Turbo.
It's either A3/B4 or d1G2 for me.
18 Sportage LX: M1AP 5W-20 + M1-104A
13 SFS 2.0T: PP 10W-30 + XG9688
Re: DEXOS1 Gen 2 : Best For GDI Of All Makes ? [Re: ChrisD46] #4642570
01/22/18 07:11 AM
01/22/18 07:11 AM
SE British Columbia, Canada
Snagglefoot Online content
Snagglefoot  Online Content
Sorry but I'm not a high vis guy. Yes, I now use Dexos on my Ford as well as my Chev. I believe Dexos truly is a cut above.
I also made a table for the high vis guys.
If the manufacturer says 30 weight, use 40
If the manufacturer says 20 weight, use 30
Hope that helps. SF
If you want the job done right......do it yourself.
Re: DEXOS1 Gen 2 : Best For GDI Of All Makes ? [Re: Snagglefoot] #4642593
01/22/18 07:56 AM
01/22/18 07:56 AM
Iowa
Nyquist Offline
Nyquist  Offline
Iowa
I generally stick with the specified viscosity. That being said, dexos1 Gen2 has some added tests that aren't in API SN or ILSAC GF5 tests that also include a timing chain wear test if I recall. I trust dexos1 Gen2 enough that I drained the oil out on our Cruze very early just to get the new stuff in the engine.
2015 Chevy Traverse 3.6L (LLT) Mobil 1 5w30 w/ Fram Ultra
2017 Chevy Cruze Hatchback 1.4L (LE2) Mobil 1 5w30 w/ Wix
Re: DEXOS1 Gen 2 : Best For GDI Of All Makes ? [Re: ChrisD46] #4642595
01/22/18 07:57 AM
01/22/18 07:57 AM
MN
oil_film_movies Offline
MN
New GM ad campaign: "dexos1 Gen2: Not Just for Breakfast Anymore"
dexos1 tests are run after all the usual SN, GF-5 tests have been run, so you can already see its a 'generic' spec.
Then, dexos1-unique tests pull some ACEA tests in (European), so you can see its also a Euro spec to some degree, using Euro engines for tests.
After that, other tests are run which further validate the oil for more types of seals, LSPI in GM engines, chain wear, oxidation tests, .... but its all applicable to any non-GM engine.
For all American, Japanese, British, & Korean makes anyway. Germans do their own thing, although the full-syn versions of dexos1 Gen2 would probably work fine in BMW's too since BMW went HTHS<3.0 recently in almost all their engines. BMW, VW, and Mercedes have their own specs, and should be followed though.
Re: DEXOS1 Gen 2 : Best For GDI Of All Makes ? [Re: ChrisD46] #4642783
01/22/18 10:59 AM
01/22/18 10:59 AM
New York
pbm Offline
pbm  Offline
New York
I believe that the original 'dexos' spec'd oil would work fine in a non-turbo GDI engine.
A small (1.4L, 1.5L, 1.6L etc....) turbo GDI probably benefits from gen2 dexos oil.....unfortunately these engines seem to be the 'future'....
'Journalism is Dead'
Re: DEXOS1 Gen 2 : Best For GDI Of All Makes ? [Re: pbm] #4642806
01/22/18 11:11 AM
01/22/18 11:11 AM
St. Charles County, Missouri
csandste Offline
csandste  Offline
Or a turbo without GDI. If it had both, then I would go for Dexos 1 gen 2.
2017 Kia Soul Plus-- Valvoline MaxLife Blend 5-20, 52,000 miles.
Re: DEXOS1 Gen 2 : Best For GDI Of All Makes ? [Re: ChrisD46] #4642830
01/22/18 11:29 AM
01/22/18 11:29 AM
Mahzurrah!
KCJeep Offline
KCJeep  Offline
Mahzurrah!
Do all Dexos 1 Gen 2 oils have low calcium? Or do they have low calcium at all?
2018 VW Passat GT VR6 - 1k - New FF
12 KIA Sedona 93k - PP HM 10w30
09 Ford Focus 132k - Supertech FS HM 5w30
00 Chev Lumina 203k - Supertech FS HM 5w30
04 Jeep Grand Cherokee gone but not forgotten.
Re: DEXOS1 Gen 2 : Best For GDI Of All Makes ? [Re: KCJeep] #4642887
01/22/18 12:37 PM
01/22/18 12:37 PM
MN
MN
QSUD, PP, Canadian AC-Delco, U.S. AC-Delco, and all dexos1 M1 oils do have Ca<1200ppm or so. (In the past, Ca ranged from maybe 1800 to 2800 ppm. Except for dexos1 M1 which has been low-Ca for 4 years now.)
Na+Ca is supposed to be really bad for LSPI, so I'm wondering if the old Valvoline Synthetic Na+Ca formula will survive to be dexos1 Gen2. Waiting for an oil analysis to be posted here.
Re: DEXOS1 Gen 2 : Best For GDI Of All Makes ? [Re: oil_film_movies] #4642902
01/22/18 12:46 PM
01/22/18 12:46 PM
Texas, Mentone for work, Galve...
Bryanccfshr Offline
Bryanccfshr  Offline
I wouldn’t run it in my BMW
2018 Trd Pro 4Runner M1 0w40
2018 Tacoma off-road Castrol 5w30 Magnatec
Re: DEXOS1 Gen 2 : Best For GDI Of All Makes ? [Re: Bryanccfshr] #4642934
01/22/18 01:13 PM
01/22/18 01:13 PM
And far enough. The Europeans sure seem to like 40 weight oil. Not sure why the divergence.
Re: DEXOS1 Gen 2 : Best For GDI Of All Makes ? [Re: Snagglefoot] #4642949
01/22/18 01:26 PM
01/22/18 01:26 PM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
They like a minimum HTHS.
Or at least they used to.
1994 BMW 530i, 238K
1996 Honda Accord, 266K
1999 Toyota Sienna, 407K
2000 Toyota ECHO, 280K
Re: DEXOS1 Gen 2 : Best For GDI Of All Makes ? [Re: kschachn] #4642981
01/22/18 01:42 PM
01/22/18 01:42 PM
Bryanccfshr Offline
Bryanccfshr  Offline
I am not familiar on if gm goes to the extent of designing and installing Crankcase turbo blow by baffles into their blocks.
