Honda ATF DW1 bottle stamp decoding
by parshisa
06/25/18 12:03 PM
How to lower throttle sensitivity?
by NICAT
06/25/18 11:41 AM
That's some service! (New Central AC...)
by xBa380
06/25/18 11:13 AM
Valvoline 2 Cycle TC-W3 Marine Oil - 6qt - $20
by Jimzz
06/25/18 10:45 AM
Plumbing/Bldg Experts: Cause of Wet Slab?
by LoneRanger
06/25/18 10:13 AM
How to CONFIRM the Country of Manufacture
by Ed_Flecko
06/25/18 09:58 AM
Replacing trans oil seal
by redhat
06/25/18 09:50 AM
VW diesels sitting in huge lots waiting......
by ZZman
06/25/18 09:09 AM
DTD/DT Independence Day Promos
by Sayjac
06/25/18 08:39 AM
It's AMSOILŪ, not Amsoil
by Rat407
06/25/18 06:39 AM
VW Passat 2007
by madRiver
06/25/18 06:18 AM
Review: CVJ Remanufactured CV Axles
by The Critic
06/25/18 03:40 AM
Towing without 85w140?
by OilFilters
06/25/18 03:07 AM
2015 VW GTI autobahn oil questions
by Skyalbo
06/24/18 11:28 PM
Corrosion in the garage - salt or humidity?
by Kurtatron
06/24/18 11:13 PM
Darn dogs
by AZjeff
06/24/18 10:21 PM
New GC?
by Bullwinkle007
06/24/18 10:04 PM
The guy with the plexiglass head on you tube
by andyd
06/24/18 09:21 PM
'07 Pacifica Timing Belt Replacement success
by 92saturnsl2
06/24/18 09:10 PM
SAE 90 v 85/140
by Knuckle078
06/24/18 09:10 PM
dhy808, ROD_Z, lozpxs, danthemanx07, FunktasticLucky
65319 Registered Users
82 registered (2015_PSD, 4WD, 69Torino, 77GrandPrix, 853okg, 6 invisible), 1631 Guests and 39 Spiders online.
65319 Members
67 Forums
285968 Topics
Page 1 of 2 1 2 >
#4642224 - 01/21/18 06:36 PM 57.000 miles Nissan Sentra, basic maintenance
sirgerman Offline
Loc: Salt Lake City Utah
I just got a 2012 Sentra with 57000 miles manual, I am going to do the basic maintenance.
1-spark plugs
2-serpentine belt
3-air filter
4-cabin filter
5-transmission fluid
6-coolant
anything else ?
Edited by sirgerman (01/21/18 06:39 PM)
#4642233 - 01/21/18 06:39 PM Re: 57.000 miles Nissan Sentra, basic maintenance [Re: sirgerman]
JohnnyJohnson Online   content
Loc: Wet side WA
Full synthetic oil and filter.
2004 Toyota Corolla 121829
Out: QSUD 5W-30 Purolator One 5030
In: Valvoline ML 5w-30 TG4967 117530 2-8-18
2006 Duramax 74047
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73752 4-22-18
#4642238 - 01/21/18 06:43 PM Re: 57.000 miles Nissan Sentra, basic maintenance [Re: JohnnyJohnson]
sirgerman Offline
that it ? anything else ? the car does not have a fuel filter is that normal ?
#4642263 - 01/21/18 07:06 PM Re: 57.000 miles Nissan Sentra, basic maintenance [Re: sirgerman]
czbrian Offline
Loc: Houston, TX
Are spark plugs actually due by 57K? Did Nissan not use iridium plugs?
#4642265 - 01/21/18 07:07 PM Re: 57.000 miles Nissan Sentra, basic maintenance [Re: sirgerman]
WobblyElvis Online   content
Loc: Toronto Canada
Most cars just have a lifetime filter in the fuel tank.
Take the wheels off and check the brakes, suspension joints and brake fluid level.
#4642271 - 01/21/18 07:11 PM Re: 57.000 miles Nissan Sentra, basic maintenance [Re: sirgerman]
Starman2112 Offline
Loc: East Tennessee
Brake and PS fluids. Spark plugs should be good.
Edited by Starman2112 (01/21/18 07:12 PM)
2010 Toyota Camry LE 2.5L, Mobil 1 AFE 0W-20, OEM filter
1998 Nissan Frontier XE 2.4L, Castrol GTX HM 5W-30, M1 filter
#4642278 - 01/21/18 07:17 PM Re: 57.000 miles Nissan Sentra, basic maintenance [Re: sirgerman]
Marco620 Offline
Loc: Deplorable Kansan,HK fan!
Tire Balance / Rotation
2015 Civic 162k mi.0w20 Redline/Archoil,HPS SRI,Yokohama/Moog links Borla Exhaust/Vibrant Resonator/Tein Suspension
Go Nashville Predators!
#4642294 - 01/21/18 07:36 PM Re: 57.000 miles Nissan Sentra, basic maintenance [Re: czbrian]
sirgerman Offline
the previous owner never changed spark plugs
#4642312 - 01/21/18 08:05 PM Re: 57.000 miles Nissan Sentra, basic maintenance [Re: sirgerman]
Ducked Offline
Loc: Taiwan
Rust proofing. Spray with veg oil and/or motor oil/diesel costs next to nothing and may buy you quite a lot of time.
#4642326 - 01/21/18 08:22 PM Re: 57.000 miles Nissan Sentra, basic maintenance [Re: sirgerman]
sirgerman Offline
I called the dealership and they want it $55 for a qt of MTF, I am not buying that, it has to be 75w85 gear oil gl4, I cant find anywhere, I was thinking about using gm synchromesh or https://www.maperformance.com/products/m...8YaAlk2EALw_wcB
any other substitute that is cheaper ? how much do I need 2 qt ?
#4642335 - 01/21/18 08:30 PM Re: 57.000 miles Nissan Sentra, basic maintenance [Re: sirgerman]
Linctex Offline
Loc: Waco, TX
It really doesn't need it yet.
Spark plugs will still be fine.
#4642363 - 01/21/18 09:00 PM Re: 57.000 miles Nissan Sentra, basic maintenance [Re: sirgerman]
FermeLaPorte Offline
Loc: Texas (south)
I got a2014 Nissan Versa with a manual. 56,500 miles.
USE SYNTHETIC OIL and FRAM ULTRA OR MOBIL 1 filter. Believe me, these Nissan engines, exactly at 5,000 miles, they thin the oil out. So 5,000 mile OCIs or 4 months is a must.
I would change the transmission oil now.
Always Mobil 1
2014 1.6L Nissan Versa Sedan, 5 spd, 5k OCI.
2011 3.5L Chevrolet Impala, Automatic, 5k OCI.
#4642373 - 01/21/18 09:10 PM Re: 57.000 miles Nissan Sentra, basic maintenance [Re: FermeLaPorte]
sirgerman Offline
what do you use in your transmission, is the 6 speed ?
#4642383 - 01/21/18 09:22 PM Re: 57.000 miles Nissan Sentra, basic maintenance [Re: sirgerman]
czbrian Offline
Loc: Houston, TX
Take a look at the owners manual / service and maintenance guide. Spark plugs are good for 105K miles per Nissan since they are iridium plugs. Changing now would be a waste.
#4642422 - 01/21/18 10:52 PM Re: 57.000 miles Nissan Sentra, basic maintenance [Re: Ducked]
maxdustington Offline
Loc: Toronna
If corrosion is an issue where the OP lives, I am sure there are oil spray shops they can visit. If not, the OP can travel somewhere to get it done.
I love the third world solutions you offer, they are often quite creative but often not the ideal solution for north america.
EDIT: On the topic of corrosion, clean out behind the wheels behind/under the fenderwell liner. Debris packed in there will rust your front fenders like crazy
Edited by maxdustington (01/21/18 10:55 PM)
03 Jetta AWP/09A 200k kms
Edge 0W40 + Mann 719/30
Page 1 of 2 1 2 >
