2007 Corolla - P0441 and P0455 codes
by Bama. 03/22/19 08:44 AM
Oldmoparguy1
by cjcride. 03/22/19 08:23 AM
Check engine light
by rtrdad. 03/22/19 08:21 AM
Super Tech 5W30 Synthetic With GDI Engine ?
by ChrisD46. 03/22/19 07:00 AM
Venol A.M.G brand
by headoff93. 03/22/19 05:51 AM
Anyone use this oil?
by lawnguy. 03/22/19 05:47 AM
Amalie Elixir Full Synthetic ?
by lawnguy. 03/22/19 02:23 AM
All 2's tomorrow or Saturday
by Marco620. 03/22/19 01:28 AM
Mobil 1 0W-16
by The Critic. 03/22/19 01:06 AM
2007 Escape - TCC solenoid?
by Burks21. 03/21/19 11:52 PM
Ac Delco oil on Rockauto
by WiskyBadger. 03/21/19 11:09 PM
Old Laptop - Keeps Freezing - Help!
by reemoe2. 03/21/19 09:52 PM
Cinnamon Cake
by StevieC. 03/21/19 09:43 PM
AMALIE OILS
by kstanf150. 03/21/19 09:41 PM
oem filters
by mobilaltima. 03/21/19 09:34 PM
Magna1 10W30
by mobilaltima. 03/21/19 09:32 PM
Found triple threat
by deven. 03/21/19 09:26 PM
Chrysler Valvetrain week??
by clinebarger. 03/21/19 08:50 PM
Lisle funnel for radiator drain & fill
by paulri. 03/21/19 07:45 PM
Anton93, FrancescoO, russrie, scottjeffrey, Mowata
67582 Registered Users
109 registered members (Aero540T, 1978elcamino, Alfred_B, 64bawagon, 69GTX, 13 invisible), 1,746 guests, and 57 spiders.
Topics286,228
Posts4,904,695
Members67,582
Most Online2,967
Mar 10th, 2019
Acura Transmission?? #4641952
01/21/18 02:42 PM
01/21/18 02:42 PM
Chester County/Pa.
Dobbie Offline OP
Dobbie  Offline OP
Chester County/Pa.
Got the Acura in signature from my Father acouple weeks ago. He said that at 90,000 miles the local garage drained 3 quarts of Honda fluid & added 3 new quarts of Honda automatic tranny fluid. Then again at 100,000 miles he did the same regiment but they added a bottle of Lube Guard Red on top of the 3 new quarts of Honda automatic tranny fluid. Car shifts smooth at 112,000 miles. Is this transmission going to be ok with his regiment so far? Is Lube Guard Red a quality additive? Trying to learn on here.
Re: Acura Transmission?? [Re: Dobbie] #4641966
01/21/18 02:54 PM
01/21/18 02:54 PM
North Carolina
rooflessVW Online content
rooflessVW  Online Content
North Carolina
Lubegard is good stuff. I would do a drain + fill with the next 3 OCIs to get a baseline, then back to a d+f every 30k.
"Zed's dead baby, Zed's dead."
Re: Acura Transmission?? [Re: Dobbie] #4641971
01/21/18 03:00 PM
01/21/18 03:00 PM
MIchigan
Warstud Offline
Warstud  Offline
MIchigan
Should be good for another 50K.
Re: Acura Transmission?? [Re: Dobbie] #4641988
01/21/18 03:23 PM
01/21/18 03:23 PM
midwest
JamesBond Offline
JamesBond  Offline
midwest
If you're doing the work yourself, buy a case of honda fluid and a bag of washers and drain and fill the trans every oil change.
Re: Acura Transmission?? [Re: Dobbie] #4642001
01/21/18 03:40 PM
01/21/18 03:40 PM
Georgia
Charlie2015 Offline
Charlie2015  Offline
Georgia
LG red is top quality. I would highly recommend doing the drain and fill procedure at least every 30k miles and use some LG red.
1998 Honda Accord EX 2.3L Auto (Sold) 214k mi
2009 Scion tC Manual (Daily Driver) 165k mi
Re: Acura Transmission?? [Re: Dobbie] #4642948
01/22/18 02:25 PM
01/22/18 02:25 PM
SC
pjhalifax Offline
pjhalifax  Offline
SC
That's pretty much what I did with my RDX. Bought it at 88k and I've done 3 drain-and-fills since then to (I hope) keep things smooth for a long time. Also threw some LG red in there.
2000 SAAB 9-3 / 143K
2010 SAAB 9-3 / 58K
2008 Acura RDX / 116K
Re: Acura Transmission?? [Re: JamesBond] #4642980
01/22/18 02:42 PM
01/22/18 02:42 PM
Valencia, CA
Richie Offline
Richie  Offline
Valencia, CA
My friend owns an independent Honda/Acura repair shop and he recommends changing the auto trans fluid in all Hondas and Acuras every 20-30K miles. he said none of them have a filter and is cheap insurance to change more often.
Re: Acura Transmission?? [Re: Dobbie] #4643260
01/22/18 07:34 PM
01/22/18 07:34 PM
Austin, TX
MaximaGuy Offline
MaximaGuy  Offline
Austin, TX
Honda and Acura transmissions are known to be weak for their legendary dependability.
Though they have fixed it, it is paramount to replace the fluids every 30K, your mechanic is wise and conservative to still with OEM fluid. No one goes wrong by throwing Lubegard Red into it... Every transmission loves that secret sauce.
2018 MB GLE350
2011 Lexus ES350
2006 Toyota Highlander 4WD
Re: Acura Transmission?? [Re: Dobbie] #4643261
01/22/18 07:35 PM
01/22/18 07:35 PM
West Michigan
Balrog006 Offline
Balrog006  Offline
West Michigan
The MDX and CRV in my sig have had the standard drain and fill every 30K since the original 50K interval and are now both well over 200K with zero history of tranny problems and none indicated currently via observation and UOA’s.
19 Ridgeline RTL-E >1K factory fill, A01
08 CRV 275K+ VSyn w/ML, A01
04 JD L130 740H, Mobil S 5w30
13 JD 2032r 325H, JD Plus 50 ii 15w40
M1Delvac 5w40 in OPE
Re: Acura Transmission?? [Re: Balrog006] #4649662
01/29/18 12:10 AM
01/29/18 12:10 AM
Athens, GA
ctechbob Offline
ctechbob  Offline
Athens, GA
By 2006/2008 the V6 trans problems were pretty much solved for the most part. My plan of attack when I bought my 130k TL Type S was a complete 3X drain and fill when I first got it, and then 1x D/F with every oil change after for the next handful of changes and then every other oil change after that.
I do 1oz of LG Red per Qt of fluid out/in.
I don't change the washer every change though, and no leaks. If they start to seep, I change the washer, otherwise I don't.
My 03 Accord V6 gets pretty much the same deal, every other oil change, but its the '[censored]' transmission, so I fully expect to have to replace it again (it was replaced at 110k), if I keep the car much longer (220k on it now)
FWIW I was speaking with a pretty highly regarded Honda trans guy in these parts and he recommended for the V6's, every 10k do a drain and fill, lines up pretty well with what I was already doing.
Also, if you do any reading around the net, you will see people talking about replacing the pressure switches. I'm still undecided on if it is a good plan or not. I've done mine, they're easy and not terribly expensive, but I don't have a lot of hard data to back up the claims.
2008 Acura TL Type S - 154k
2003 Honda Accord V6 - 207k
2000 Honda Accord I4 - 321k
Current Oil - Milesyn SXR5W30
Current Filter - Partsmaster 61334
