ProMotive PH 2500 CUT OPEN
by car51
32 minutes 24 seconds ago
go green or Dexcool?
by umungus1122
36 minutes 34 seconds ago
Latest info on ExxonMobil synthetic base stocks
by Gokhan
37 minutes 56 seconds ago
Pennzoil Platinum 5w30 - $3.21/qt Amazon
by SnowmanCO
49 minutes 46 seconds ago
What Is Dexos Oil?
by mx5miata
59 minutes 58 seconds ago
Hail damage means newer vehicle time!
by ZZman
Today at 03:39 PM
Trouble with Grease Gun
by tc1446
Today at 02:30 PM
Toyota brand conventional (TGMO)
by Jaha24k
Today at 01:45 PM
Any synthetic oil rebates currently or soon?
by 07Piloteer
Today at 01:32 PM
2018 Hyundai elantra motor oil
by kapama
Today at 01:00 PM
SN Plus on shelves
by 03s
Today at 12:23 PM
Group 90 Battery - 45 vs 60aH rating
by The Critic
Today at 12:19 PM
Tire on Church 15 Passenger Van
by Gebo
Today at 11:58 AM
Battery Disconnect Switch?
by Pike51
Today at 11:35 AM
03 Maxima Cam sensor questions
by LeakySeals
Today at 11:09 AM
Wood Fairing?? Yes, and it's beautiful!
by webfors
Today at 11:08 AM
2006 Prius
by Kira
Today at 11:06 AM
Amsoil XL 5w30, 10K OCI, 2006 Expeditition
by meborder
Today at 10:18 AM
Mouse Visiting Car
by Ifixyawata
Today at 10:07 AM
Hit a shopping cart at 30mph
by LeakySeals
Today at 10:00 AM
Ilia, nmac9, Theraven, battleman13, Shassis
65278 Registered Users
90 registered (9050lx, 28oz, 92saturnsl2, 1JZ_E46, AndyB, 330indy, 6 invisible), 1627 Guests and 40 Spiders online.
65278 Members
67 Forums
285661 Topics
Page 1 of 2 1 2 >
#4641862 - 01/21/18 11:48 AM Intermittent oil pressure warning Audi A4
dlundblad Offline
Loc: Indiana
Good Sunday afternoon BITOG.
2004 Audi A4. 3.0 V6. ~178k.
The oil pressure warning comes on intermittently. The oil level is correct. I am hoping it's either a faulty oil pressure sensor or faulty bypass in the filter, but research has lead me to believe the oil pickup screen may be plugged up with junk.
Long story short, it was purchased as a daily driver to keep the miles off a beloved vehicle, but an exhaust cam lob was gone and the engine ended up getting replaced with a junkyard engine back at ~120k. VW502 oil and German Mann filters have always been used since the transplant.
03 Jeep WJ 4.0 199k Castrol Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 177k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 145k Rotella T5 10w30 Fram TG3980
#4641868 - 01/21/18 11:54 AM Re: Intermittent oil pressure warning Audi A4 [Re: dlundblad]
rooflessVW Online   content
Loc: North Carolina
Pop a sensor in it. They're $15 or so if I recall correctly.
"Zed's dead baby, Zed's dead."
#4641871 - 01/21/18 11:55 AM Re: Intermittent oil pressure warning Audi A4 [Re: rooflessVW]
dlundblad Offline
Loc: Indiana
Yes sir.
Looks like it goes right above the oil filter housing.
#4641974 - 01/21/18 02:07 PM Re: Intermittent oil pressure warning Audi A4 [Re: dlundblad]
VeryNoisyPoet Offline
Loc: Massachusetts
Is there any pattern to when the warning comes on? Such as less frequent when cold (higher oil viscosity and higher pressures), but more frequent when sitting in a roasting hot traffic jam, or flickering at idle after getting off a long highway run (oil at operating viscosity and thus lower pressures)?
Does blipping the throttle to raise the RPMs off idle make the warning stop?
1998 V70 GLT / 187k miles
"Use yah blinkah!"
"Be nice. The alternative involves an air horn and 7000 lumens of high beam."
#4642000 - 01/21/18 02:39 PM Re: Intermittent oil pressure warning Audi A4 [Re: dlundblad]
FowVay Offline
Loc: Southeastern USA
If the problem isn't sensor related then you might have a worn oil pump drive chain. At the age and mileage I wouldn't be surprised.
Quaker State across the board.
#4642050 - 01/21/18 03:37 PM Re: Intermittent oil pressure warning Audi A4 [Re: VeryNoisyPoet]
dlundblad Offline
Loc: Indiana
From what I understand, it's when the car at full temperature and is shifting through gears during stop and go traffic. No issues on highway driving.
#4642097 - 01/21/18 04:27 PM Re: Intermittent oil pressure warning Audi A4 [Re: dlundblad]
CT8 Online   content
Loc: Idaho
At idle when the oil is hot?
"Don't let your preconceived notions get in the way of facts."
Geoff Metcalf
#4642108 - 01/21/18 04:41 PM Re: Intermittent oil pressure warning Audi A4 [Re: dlundblad]
das_peikko Offline
Loc: San Antonio, TX
Since the oil level is sloshing back and forth inside the pan while driving in traffic; and since the oil level is steady on the highway; that leads me to suspect the oil level is too low and you have the wrong length dipstick.
#4642152 - 01/21/18 05:35 PM Re: Intermittent oil pressure warning Audi A4 [Re: dlundblad]
incognito_2u Offline
Loc: Long Island, N.Y.
From past experience, Drop oil pan and clean sludge off oil pick-up screen........Audiís extended oil change intervals of the early 2000ís are to thank for that. laugh
This is coming from a previous owner of a 2003 A4,
Edited by incognito_2u (01/21/18 05:37 PM)
2006 Jeep Commander 3.7 V6 -108k (PUP/XG3600)
2006 Toyota Corolla 1.8 VVTi -76k (PPHM/XG3600)
1999 Toyota Corolla 1.8 -77k (PUP/XG4386)
#4642246 - 01/21/18 06:49 PM Re: Intermittent oil pressure warning Audi A4 [Re: dlundblad]
dlundblad Offline
Loc: Indiana
Looks like these don't use a fiber gasket and just use this stuff.
https://www.fcpeuro.com/products/audi-vw-oil-pan-sealing-compound-50ml-d176501a1
Would I be asking for trouble by using a Permatex equivalent?
#4642249 - 01/21/18 06:52 PM Re: Intermittent oil pressure warning Audi A4 [Re: das_peikko]
dlundblad Offline
Loc: Indiana
Good observation, but it's had this dipstick for the last 60k miles.
I will say it is hard to read since it's black plastic, but I've confirmed the level many times after a fresh 7 quart oil change as well.
#4642669 - 01/22/18 09:06 AM Re: Intermittent oil pressure warning Audi A4 [Re: dlundblad]
Loc: Massachusetts
So, on acceleration or deceleration, but not at idle?
What about immediately after exiting the highway and coming to a stop at idle?
Permatex Ultra Black is very similar, but I would recommend going for the OEM specified material just to be safe, unless someone else here has good experience with a substitute.
"Use yah blinkah!"
#4642688 - 01/22/18 09:20 AM Re: Intermittent oil pressure warning Audi A4 [Re: dlundblad]
jeepman3071 Offline
Loc: Storrs, Connecticut
Might be worth pulling the fill cap to see what the engine looks like inside. A co-worker's A4 had the same issue with a 1.8T engine, and it ended up being pretty sludged inside from PO neglect. The oil light would flicker at hot idle, and putting a gauge on it revealed the engine only had a couple PSI at idle. It scorched the turbo soon after and he sold the car.
2000 Jeep Cherokee 4.0L (179k) - Pennzoil 10w30, Napa Gold 1516, Magnefine trans filter
2009 BMW 328i (32k) - Castrol Edge Euro 0w40, MANN HU816X
#4647863 - 01/27/18 10:09 AM Re: Intermittent oil pressure warning Audi A4 [Re: dlundblad]
dlundblad Offline
Loc: Indiana
The oil pressure wire is frayed. Not too bad, but wire is exposed.
I couldn't get to the oil pressure sensor so I gave up and removed the pan. Took 15 mins if that.. The engine was spotless. I also removed the oil pump chain cover. The chain was tight and once again, everything was spotless. I fiddled with the sensor connector for about 30 mins, sacrificed one of my picks to shorten it up since room was tight.. there was no way. Finally gave my Autozone clearance Dorman electrical connector disconnect tool a try and it came off with the first attempt.
I used the hook shaped tool.
https://www.summitracing.com/parts/rnb-8...BSABEgKMpPD_BwE
#4647867 - 01/27/18 10:14 AM Re: Intermittent oil pressure warning Audi A4 [Re: dlundblad]
dlundblad Offline
Loc: Indiana
That wire is at a bit of a harsh angle and it was pretty tight. The disconnect tab was also perfectly aligned with that bump in the engine block, which made seeing and getting to it that much harder.
Edited by dlundblad (01/27/18 10:16 AM)
Page 1 of 2 1 2 >
