Magnetic Out, ST in at Wally Auto Care Center.
by csandste. 03/21/19 02:26 PM
One license plate in a Two-Plate State
by bunnspecial. 03/21/19 02:07 PM
TPMS Units Honda
by Chester11. 03/21/19 01:58 PM
Another brake question
by supton. 03/21/19 01:54 PM
BOUGHT WRONG OIL FILTER
by IBelieveinlube. 03/21/19 01:47 PM
miscible ester, using is as oil additive ?
by pep808. 03/21/19 01:23 PM
LT Oil Temps
by StillLearning. 03/21/19 12:44 PM
What kind of lug nut is this?
by LeakySeals. 03/21/19 12:38 PM
Need help finding a riding mower with $1,500 budget
by MetalSlug. 03/21/19 11:55 AM
Volvo 2.0 Turbo
by Ddub. 03/21/19 11:43 AM
Got a busted crankshaft!
by Chris142. 03/21/19 11:18 AM
Bad Motorcraft Plug?
by tmorris1. 03/21/19 10:47 AM
SAE 20 non-detergent oil
by fleetwood62. 03/21/19 10:39 AM
PSF3 in older Kia?
by Jetsfan421. 03/21/19 09:48 AM
USB WiFi adapter recommendations?
by Quattro Pete. 03/21/19 09:44 AM
m1,ep and valvoline.
by avi1777. 03/21/19 09:39 AM
Caliper recommendation?
by supton. 03/21/19 09:08 AM
Honda st1300 LED light
by Zuraxus. 03/21/19 08:26 AM
Paperboy, Flinch, AlanGonzales, Jrealstreeter, DarkFrontier
67576 Registered Users
114 registered members (1leater, 2K2AcuraTL, aircooled, ammolab, 240_Ed, 12 invisible), 2,039 guests, and 178 spiders.
Topics286,196
Posts4,903,982
Members67,576
Most Online2,967
Mar 10th, 2019
What Causes Poor Shifting In Motorcycling? #4641782
01/21/18 11:22 AM
01/21/18 11:22 AM
805, Ca
Analyzer Offline OP
Analyzer  Offline OP
805, Ca
Kevin Cameron delves into this subject in Cycle World magazine in the link below and also includes a video from their YouTube channel as well. It is very informative and takes oil viscosity out of the equation showing the mechanical/engineering reasoning behind it.
Kevin Cameron on Causes of Poor Motorcycle Shifting
2007 Yamaha FZ1
1986 Yamaha FZX700 Fazer
1997 Suzuki RM250
2016 Mazda 3 Sport
1992 Ford Explorer Eddie Bauer 4x4
Re: What Causes Poor Shifting In Motorcycling? [Re: Analyzer] #4641851
01/21/18 12:37 PM
01/21/18 12:37 PM
MURICA
maverickfhs Offline
maverickfhs  Offline
MURICA
Thanks for sharing, I like that guy and video thumbsup
2006 Civic EX 205K/AT
2006 Acura TSX 187K/AT
2007 Accord VP 151K/AT
Re: What Causes Poor Shifting In Motorcycling? [Re: Analyzer] #4641910
01/21/18 01:50 PM
01/21/18 01:50 PM
Where the wind comes sweepin'
Reddy45 Offline
Reddy45  Offline
That's just one aspect right? No mention of the shift star or the movement of the forks. Clutch cable tension would also matter.
Re: What Causes Poor Shifting In Motorcycling? [Re: Analyzer] #4641965
01/21/18 02:53 PM
01/21/18 02:53 PM
Saskatchewan, Canada
Johnny2Bad Offline
Johnny2Bad  Offline
A properly setup sequential transmission is a thing of beauty, a poorly setup one is a thing of pain.
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
Re: What Causes Poor Shifting In Motorcycling? [Re: Analyzer] #4641972
01/21/18 03:03 PM
01/21/18 03:03 PM
Katy, Republic of Texas
blupupher Offline
blupupher  Offline
Interesting, did not understand 1/3 of what he said, and found the background music annoying.
2018 Hyundai Santa Fe: Delo XLE 10w-30, OEM filter, 3k
2012 Scion xB: QSUD 0w-20, CQ Blue, 5k
2002 Ford F150: Magnatec 5w-20, Bosch D+, 1yr
1994 Honda VT1100: Peak 15w-40, PSL, 1yr
Re: What Causes Poor Shifting In Motorcycling? [Re: Analyzer] #4641989
01/21/18 03:23 PM
01/21/18 03:23 PM
nj
lego Offline
lego  Offline
nj
I get a lot of false neutrals on older Ducati if I I do not shift with authority.
Re: What Causes Poor Shifting In Motorcycling? [Re: Analyzer] #4642016
01/21/18 03:59 PM
01/21/18 03:59 PM
Deplorable in apple valley, ca
Chris142 Online content
Chris142  Online Content
I can't find neutral in my z400
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: What Causes Poor Shifting In Motorcycling? [Re: Analyzer] #4642036
01/21/18 04:27 PM
01/21/18 04:27 PM
Deep in the heart of Jersey
BigCahuna Offline
BigCahuna  Offline
I don't think that guys "one problem causes all" answer is doing anyone any favors. There was no mention of a worn out, or badly adjusted clutch as being a culprit. Or primary oils being too heavy or thin. Matching engine speed to a given shift point will allow you to shift smoothly without using the clutch.Heavy oil in cold weather causes drag on the clutch plates, and can cause you bike to bang into gear or lurch forward. If your bike uses the same oil for the motor and transmission, as it gets older and shears out of grade, that can cause it to be hard finding neutral. Of course bent or damaged shift dogs or shafts can cause hard shifting,but most of the time the answer is alot simpler to remedy the tearing the motor or trans apart.,,
Re: What Causes Poor Shifting In Motorcycling? [Re: Analyzer] #4642085
01/21/18 05:07 PM
01/21/18 05:07 PM
The Canyons
02SE Offline
02SE  Offline
The Canyons
I respect Kevin Cameron, but that is an incomplete article. There are numerous contributors to smooth or notchy shifting. Since this is an oil forum, I've had various oils affect shifting smoothness in shared-sump Motorcycles, too many times to count, when the oil was the only change made.
Re: What Causes Poor Shifting In Motorcycling? [Re: Analyzer] #4642426
01/21/18 11:56 PM
01/21/18 11:56 PM
New Zealand
Silk Offline
Silk  Offline
New Zealand
He mentioned the Burman gearbox, a better example would be the Triumph gearboxes. The 4 speed had fine dogs, he called them splines, but the Burman had fine dogs like the Triumph gears shown here. They weren't a great shifting box, and false neutrals caused by a shift plate rather than a smaller diameter shift drum.
When Triumph made the 5 speed, they used a wider dog as shown here, you can also see the staggered height dog.
1987 BMW R65 - Aegis SAE30
2005 Nissan Expert - 5W-40 Castrol Magnatec diesel.
1996 Volvo T5 - Penrite HPR15 - 15W-60. Ryco syntec filter.
Re: What Causes Poor Shifting In Motorcycling? [Re: Analyzer] #4642509
01/22/18 04:55 AM
01/22/18 04:55 AM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
Anyone recognize the 3 cylinder engine in the video? Old Kawasaki 2-stroke?
Proper shift lever position and clutch adjustment are important for good shifting operation. The oil used can also make a noticable difference.
Re: What Causes Poor Shifting In Motorcycling? [Re: Analyzer] #4642565
01/22/18 08:02 AM
01/22/18 08:02 AM
Nowhere NM
Smoky14 Online content
Smoky14  Online Content
Nowhere NM
I think Kevin was confining his remarks to things mechanical. Having hand massaged a few race boxes in my day, I found it to be a good basic informational video. Hand lapping and under cutting the dogs can take days if done properly.
Try rebuilding that crankshaft if you think transmissions are difficult.
Smoky
99 Acura 2.3CL 5speed MT
12 Ford Fusion 2.5S 6speed MT
05 Suzuki Bandit 1200.
Re: What Causes Poor Shifting In Motorcycling? [Re: ZeeOSix] #4642944
01/22/18 02:23 PM
01/22/18 02:23 PM
The Canyons
02SE Offline
02SE  Offline
The Canyons
He says it's an H1 in his opening statement.
