Heavy Snow Predicted for Northeast Sat/Sun
by Donald. 01/17/19 08:34 PM
Pennzoil Ultra Plat 5w30 1.4L T Chevy Cruze 10k
by SubieBlue. 01/17/19 08:03 PM
Coated rotors
by supton. 01/17/19 07:51 PM
Good samaritan
by JLTD. 01/17/19 07:15 PM
Doing suspension work. Need alignment?
by HawkeyeScott. 01/17/19 05:45 PM
100mg CBD Cannabis Gel
by Al. 01/17/19 05:36 PM
Electric Car "Green Test"
by redbone3. 01/17/19 05:06 PM
Want to try a uoa
by Dylan1303. 01/17/19 04:56 PM
Happy Birthday, Betty White!
by eljefino. 01/17/19 04:20 PM
Fram Ultra for Ecoboost 2.7
by Purpfox. 01/17/19 04:10 PM
Idle Speed / 1998 Olds 88
by Mark72. 01/17/19 03:28 PM
Heat blanket for your oil filter!
by MrWideTires. 01/17/19 03:24 PM
Proper oil viscosities.
by Bullwinkle007. 01/17/19 03:20 PM
44$ for 5 gals of home heating oil treatment!
by Audios. 01/17/19 03:05 PM
Good job Hyundai!!!
by Andy636. 01/17/19 02:43 PM
PP 0W-20 vs PP HM 0W-20 - Difference in VI
by The Critic. 01/17/19 02:34 PM
Dickerson888, Frisky, polarisman340, jfradella, Bigyetti83
66964 Registered Users
124 registered members (4WD, advocate, 69Torino, AdditiveOCD, 2015_PSD, 10 invisible), 1,720 guests, and 49 spiders.
Topics296,750
Posts4,958,214
Members66,964
Most Online2,577
Jan 14th, 2019
Page 1 of 3 1 2 3
High mileage synthetic oils in new engine #4641686
01/21/18 08:49 AM
01/21/18 08:49 AM
Tennessee, United States
ZraHamilton Offline OP
At walmart, pennzoil platinum and PP HM are the same price. Also, valvoline synpower and synpower with maxlife are the same price. Valvoline says that you can use their synthetic maxlife oil in a new engine, and it would help prevent high mileage problems before they occur. They also say that their synpower with maxlife is their top-tier oil, with a stronger additive package than regular synpower. It has more detergents/dispersants/antioxidants, more anti-wear/friction modifiers, and seal conditioners. It even contains an ashless anti-wear/friction modifier which is most likely an ester.
Is there any reason not to use PP HM or synpower maxlife in a new engine? For the same price, wouldn't they be an upgrade over their regular synthetic oils?
Re: High mileage synthetic oils in new engine [Re: ZraHamilton] #4641691
01/21/18 08:56 AM
01/21/18 08:56 AM
In the shop
53' Stude Offline
53' Stude  Offline
In the shop
I used tons of Maxlife blend in the Bonnevile. Works great for me. My work used nothing but Maxlife blend for years in new stuff without issues
09' Camry LE
ST 5w30 and TG 4386(filter on for second 5k run)
Re: High mileage synthetic oils in new engine [Re: ZraHamilton] #4641698
01/21/18 09:00 AM
01/21/18 09:00 AM
Kansas
ejes Offline
ejes  Offline
Kansas
This topic has been discussed a lot here; some would say beat to death. You'll find many debates if you search for it. That said, I'm in the camp of using it in new engines and I have had no ill effects. As such, I can't say it has done anything better either. My UOA's are just fine, so I keep using it. (VMLFS) I can say that I've seen Maxlife FS and Maxlife blend help (not eliminate) in older vehicles I've purchased used with weeping seals, however.
Re: High mileage synthetic oils in new engine [Re: ZraHamilton] #4641724
01/21/18 09:28 AM
01/21/18 09:28 AM
St. Charles County, Missouri
csandste Online content
csandste  Online Content
I've used Maxlife blend in a '14 Encore that I got two years ago with 50K, it now has 95K. Other than the fact that it no longer meets Dexos 1 gen 2 specs (not much chance of LSPI in the base engine, and I'm out of warranty), I would recommend it highly. I would have no problem with Maxlife Syn in a brand new car or Maxlife blend in a new non GM car.
2017 Kia Soul Plus-- VWB 5-30, 54,000 miles.
Re: High mileage synthetic oils in new engine [Re: ZraHamilton] #4641725
01/21/18 09:30 AM
01/21/18 09:30 AM
Upper midwest
Mainia Online happy
Mainia  Online Happy
Upper midwest
Added note: 2005 Honda Civic 98,000 leaking oil on driveway kinda bad. Put Pennzoil full synthetic high mileage oil in.. 3 -5 days later no oil for a full oil change time on the driveway. Change oil to Mobil 1 high mileage, leaking started back up in 4 days, but to a lesser degree. Guess who uses more Ester or swelling agents?
I am a maintenance guy at work, we had a low speed gearbox with seal leaks. Seals not available only a rebuilt $7,000-10,000 gearbox. Added more Mobil XP gear oil and some Pennzoil full synthetic high millage oil since it is low speed, About 10%. No more seal leaks.
Re: High mileage synthetic oils in new engine [Re: Mainia] #4641742
01/21/18 09:43 AM
01/21/18 09:43 AM
Texas (south)
FermeLaPorte Offline
Texas (south)
The Pennzoil created sludge and Mobil cleaned it out, Mainia
Always Mobil 1
2014 1.6L Nissan Versa Sedan, 5 spd, 5k OCI.
2011 3.5L Chevrolet Impala, Automatic, 5k OCI.
Re: High mileage synthetic oils in new engine [Re: csandste] #4641750
01/21/18 09:49 AM
01/21/18 09:49 AM
MN
oil_film_movies Offline
MN
True you have to use the full-synhetic MaxLife to get dexos1 Gen2, good point. .... I'd recommend full syn in everything because dexos1 Gen2 is the highest standard in ILSAC oils these days.
The critical main issue here is seal conditioning and what that means. Seal conditioners are plasticizers to keep them flexible, and SN & dexos1 tests ensure they don't swell the seals too much, testing on many possible seal materials, making them suitable for brand new seals as well as old seals.
Re: High mileage synthetic oils in new engine [Re: oil_film_movies] #4641783
01/21/18 10:23 AM
01/21/18 10:23 AM
Kendall, FL
wemay Offline
wemay  Offline
Kendall, FL
+2
18 Sportage 2.4L AWD:
Now: M1AP 5/20 + M1
Next: VME 5/30
13 Santa Fe Sport 2.0T:
Now: PPEuroL 5/30 + OEM
Next: PUP 5/30
Re: High mileage synthetic oils in new engine [Re: ZraHamilton] #4641785
01/21/18 10:24 AM
01/21/18 10:24 AM
Oklahoma
tomcruise Offline
tomcruise  Offline
Oklahoma
I've been using Valvoline Maxlife Synthetic since my truck has had ~4k miles. It has 55k on it now without any problems.
It got an oil change yesterday with more Maxlife.
2016 Ford F150 Xlt 2.7L
Pennzoil Platinum Euro L 0w40
Motorcraft FL2062
Re: High mileage synthetic oils in new engine [Re: tomcruise] #4641790
01/21/18 10:29 AM
01/21/18 10:29 AM
MN
MN
tomcruise, {BTW, u were great in "American Made" & looking forward to the next Mission Impossible....} That'll work fine. I'm still in the camp that thinks you don't need or really should use a MaxLife before 75k or 5 years though. Doesn't hurt, but really not necessary at all until its older.
Re: High mileage synthetic oils in new engine [Re: FermeLaPorte] #4641796
01/21/18 10:38 AM
01/21/18 10:38 AM
Upper midwest
Mainia Online happy
Mainia  Online Happy
Upper midwest
The motor is very clean. I sent a camera inside the valve cover after buying it at 95,000 miles. Zero varnish.
Re: High mileage synthetic oils in new engine [Re: oil_film_movies] #4641807
01/21/18 10:57 AM
01/21/18 10:57 AM
Pa, USA
NH73 Online content
NH73  Online Content
Pa, USA
If it cost the same, why not? That kinda is the question.
2017 Toyota RAV4 Hybrid
2004 Ford Explorer Sport Trac
2012 Gravely ZT XL 48 w/ Kawasaki FR730
Re: High mileage synthetic oils in new engine [Re: ZraHamilton] #4641808
01/21/18 10:57 AM
01/21/18 10:57 AM
Pa, USA
NH73 Online content
NH73  Online Content
Pa, USA
If it meets the what the manufacturer requires, I don't see a problem.
Re: High mileage synthetic oils in new engine [Re: ZraHamilton] #4641835
01/21/18 11:25 AM
01/21/18 11:25 AM
Oklahoma
tomcruise Offline
tomcruise  Offline
Oklahoma
The only reason I started using it was because Walmart was out of regular synpower. I did a UOA and liked the results so I figured I'd just keep on with what works.
Motorcraft FL2062
Re: High mileage synthetic oils in new engine [Re: ZraHamilton] #4641837
01/21/18 11:26 AM
01/21/18 11:26 AM
MIchigan
Warstud Offline
Warstud  Offline
MIchigan
I think since it has seal conditioners it should be alright. But if it has seal swellers then I'd only use it if it leaks.
Page 1 of 3 1 2 3
