What would you do...
by Bailes1992. 03/19/19 05:28 AM
'65 Mini.
by Silk. 03/19/19 02:08 AM
Our trash guy is getting on my nerves.
by Chris142. 03/19/19 01:20 AM
Ecogard trans filter
by pda1122. 03/19/19 12:11 AM
4.3 vortec issues
by mobilaltima. 03/18/19 09:17 PM
Recommendation for filter for Alfa Romeo 4C?
by phaphaphooey. 03/18/19 09:17 PM
What's the new wonder elixir?
by Yuk. 03/18/19 08:32 PM
Direct Injection Engines
by Al. 03/18/19 08:31 PM
Which mobil 1 for 19 versa?
by jahwarrior1423. 03/18/19 08:07 PM
RIP Dick Dale
by Donald. 03/18/19 08:06 PM
Found some rust on the roof of my car
by DreamerGT. 03/18/19 07:37 PM
What coolant would you run in a 1997 Dodge Ram?
by zfasts03. 03/18/19 07:11 PM
Is 10k miles too long for tire rotations?
by Nicasio. 03/18/19 06:47 PM
S-Oil Seven $14.88 on Amazon
by Nickdfresh. 03/18/19 06:41 PM
Power Steering Fluid - 07 Tahoe
by Plimbob. 03/18/19 06:38 PM
drsoils, Gbear, MadMikesMech, Indyfordfan, toplscuda
67551 Registered Users
49 registered members (Bailes1992, 87sammy, billt460, alcyon, Black_Thunder, bcossa2001, 4 invisible), 669 guests, and 52 spiders.
Topics286,049
Posts4,901,492
Members67,551
Most Online2,967
Mar 10th, 2019
New to me 2009 Silverado fluid change #4641421
01/20/18 10:45 PM
01/20/18 10:45 PM
SE Ohio
MuzzleFlash40 Offline OP
SE Ohio
Picked up an 09 Silverado 4x4 with the 4.8 as a spare vehicle for snow, etc. It has 97k on it and I will only put around 5k or so a year.
I'm going to change out all the fluids.
Power steering - Maxlife
Front and Rear Axles - Mobil 1 75w90 $10 a quart on amazon
Trans - First i'll suck out the pan and do a fill, wait a few thousand then do a pan drop and filter change
Transfer case - drain and fill
Both the trans and transfer case call for DEX6. I found on amazon a case of regular mobil for $80. Walmart has their quarts of Supertech DEX6 for $4.26.
Will the supertech do as well as the mobil (not mobil1)?
18 Sonata SEL 2.4-14k
Syntec 5w30 & OEM
16 Santa Fe Sport AWD 2.4-69k
PP 5w30 & OEM
09 Silverado LT 4x4 4.8-105k
ST HM 5w30 & Fram
Re: New to me 2009 Silverado fluid change [Re: MuzzleFlash40] #4641428
01/20/18 10:54 PM
01/20/18 10:54 PM
WI
HoosierJeeper Offline
WI
If the Supertech Dex6 is like Supertech ATF+4, then it's as good as the dealer or any other brand. It has to be an exact formulation to get the approval. I'd run it if that's the case.
15 Jeep KL Limited V6: Formula Shell 5W20
07 LR3 SE V8: Maxlife 5W30
05 Jeep KJ Limited: PHM 5W30
96 Jeep XJ Country: STP HM 5W30 (winter)
Re: New to me 2009 Silverado fluid change [Re: MuzzleFlash40] #4641465
01/20/18 11:42 PM
01/20/18 11:42 PM
USA
slacktide_bitog Offline
USA
The Super Tech Dexron VI is officially licensed and formally approved by GM, so it is perfectly ok to use it in your transmission with no problems smile
If your transmission doesn't have a drain plug, consider an aftermarket pan like Dorman that has one. It will make future ATF changes much easier.
Re: New to me 2009 Silverado fluid change [Re: MuzzleFlash40] #4641527
01/21/18 01:30 AM
01/21/18 01:30 AM
socal
barkingspider Offline
socal
Super tech Dex 6 is good for your trans. Use it without hesitation . Maxlife in the power steering?
06 Cadillac Escalade Ext
17 Cadillac ATS (wife)
05 Toyota Camry (daughter)
11 GMC Canyon off-road (daily)
Re: New to me 2009 Silverado fluid change [Re: MuzzleFlash40] #4641541
01/21/18 02:33 AM
01/21/18 02:33 AM
ohio
xtell Offline
xtell  Offline
ohio
Supertech Dexron VI is a good trans oil. Working good in my GM transmissions. Very smooth shifts versus the Pennzoil Dexron III I had in there.
Re: New to me 2009 Silverado fluid change [Re: MuzzleFlash40] #4641596
01/21/18 07:41 AM
01/21/18 07:41 AM
Formerly Ryan00TJ member 143
Ryan02SS Offline
Ryan02SS  Offline
Everything looks good. Buy a $10 drain plug kit and install it in your trans pan while it's off. Makes it much easier for future changes. Maxlife has a power steering version too. I am running it in mine.
08 Sierra 5.3L M1 EP 5W30 Wix
06 Velocity VR1 496HO Mobil Delvac 15W40 Wix
03 VW Passat 1.8T M1 0W-40 Wix
16 Land Rover LR4 Castrol Prof Edge E0W20
Re: New to me 2009 Silverado fluid change [Re: MuzzleFlash40] #4641636
01/21/18 08:59 AM
01/21/18 08:59 AM
Cincinnati
donnyj08 Offline
donnyj08  Offline
Cincinnati
You can also use Maxlife LV ATF as well that will cost about the same as supertech when bought by the gallon.
In my 08 i change the transfer case once a year. Differentials every 40k with synpower 75w90 or castrol synthetic 75w90. ATF pan drop happened at 25k. I flushed via the trans cooler line at 60k and replaced all trans fluis with maxlife LV FS ATF.
Oil changes every 5-7k with on sale Synthetics.
Congrats on the truck! Do you have the 4L60E trans or the 6L80? I believe the service life on the trans filter is 100k max on a 4L60E. If i were you i would drop and clean the pan, replace the filter and refill. After that i would replace the fluid via the trans cooler line so all 12 quarts are fresh.
2008 Silverado Z71 LT 90k Maxlife FS 5w30
2010 Ford Escape 172k QSUD 5w20
2016 Yamaha XSR900 12k, Rotella 15w40 Yamaha Filter.
Re: New to me 2009 Silverado fluid change [Re: MuzzleFlash40] #4641643
01/21/18 09:12 AM
01/21/18 09:12 AM
SE British Columbia, Canada
Snagglefoot Online content
Snagglefoot  Online Content
Dexron VI is Dexron VI. LV is LV. Not a fan of one size fits all.
Read the PI sheet on the Maxlife website and decide for yourself.
If you want the job done right......do it yourself.
Re: New to me 2009 Silverado fluid change [Re: donnyj08] #4641653
01/21/18 09:22 AM
01/21/18 09:22 AM
San Rafael, CA
dogememe Online content
dogememe  Online Content
San Rafael, CA
Originally Posted By: donnyj08
I'm pretty sure all 4.8s came with the 4L60E until like what, 2011? 2012? idk...
2010 Ford Escape 2.5 ~94K Miles: Royal Purple 5W-30 + Wix 51348
2008 Ford Crown Vic P71 4.6 ~167K Miles: AMSOIL SS 0W-30 + Wix 51372
1995 Chevy Silverado 5.7 ~277K Miles: Delo 10W-30 + ACDelco PF52
Re: New to me 2009 Silverado fluid change [Re: MuzzleFlash40] #4641660
01/21/18 09:31 AM
01/21/18 09:31 AM
The last year for the 4.8 was 2013 and I believe it still had a 4L60 E at that time.
Re: New to me 2009 Silverado fluid change [Re: MuzzleFlash40] #4642390
01/21/18 10:34 PM
01/21/18 10:34 PM
SE Ohio
SE Ohio
Thanks guys, yes it has the 4L60E.
While grabbing some wiper blades at Advance I seen they had the Carquest DEX6 that is labeled a full syn for 2 for 10. So I picked up a case. The Castrol next to it was labeled as a blend for $7. So I figured $5 a quart was a pretty good deal.
Syntec 5w30 & OEM
PP 5w30 & OEM
ST HM 5w30 & Fram
Re: New to me 2009 Silverado fluid change [Re: MuzzleFlash40] #4642598
01/22/18 09:00 AM
01/22/18 09:00 AM
Southeast
meep Offline
meep  Offline
Southeast
as a preventative, google to see if this truck has the inline oil filter just under the pressure sensor. On the motors that do, this thing will get gummed up around 100k and start throwing low pressure codes and creating a little valve tap.
https://www.amazon.com/General-Motors-12...T7MCF7FVQXS75BD
-m
2018 F150
2015 crv (wifey!)
