Originally Posted By: car51
Originally Posted By: fdcg27
The average ST user probably doesn't drive anything new enough to need 0W-20 while the average more prosperous fellow driving something that calls for 0W-20 probably wouldn't use ST.
OTOH, there are house brand 0W-20s out there, so I'm sure that Walmart will join the party.
They're probably gathering bids from suppliers for this grade even now.
I beg your pardon
I know quite a few people with newer vehicles that use ST fluids.
Not everyone is stuck on using "name brand" oils anyways
You may beg as you wish.
I don't use ST in anything simply because it's a cheaply formulated oil, which is the reason that it lacks that most expensive and most desirable add, moly.
If one wants a cheap store brand oil, there are better and cheaper options from RK and Meijer and their oils actually do contain a small slug of moly.
I don't know anyone who actually uses ST. Not even Walmart uses it in their TLEs.
