M1 0-40, 1.8k, 2006 STi, E85
SWFL
this was my first full OCI with full E85. i run E85 24/7, current ethanol content around 80%. ran it short to get a base line. this OCI had more than the normal amount of WOT 4th gear pulls. in the process of remote tuning, and try to diag a boost issues that only arises at full boost and high RPM. i'm guessing that's where some of the higher wear numbers are coming from. i was bit nervous when i drained the oil, because it smelled of straight up ethanol. but everything looks to be in order. i'm going to go out to 3K per their recommendation. (400whp).
COmments:
A full run on E85 didn't affect the oils physical properties to any noticeable extent. The viscosity is well within range for 0/40 and the insolubles level shows a low amount of oxidized solids built up in the oil. E85 use shouldn't directly impact wear metals, but the increased power could lead to wear. Metals are a little higher than we've seen in the past after a shorter oil run, but nothing inceased enough suspect poor wear or a problem, either. The TBN is very strong thanks to the short run, Give 3000 miles a try for the next run.
Code:
Oil Type: M10-40
Make up oil used: 0
Miles unit: 35,850 30.667k 24.879k
Mileage oil: 1,850 3395 3417
Date: 1/18 7/16 5/17 AVG(5/17) AVG (1/18)
Aluminum 5 2 3 4 4
Chromium 1 1 1 2 1
Iron 8 6 7 20 9
Copper 13 6 6 10 8
Lead 1 1 1 1 2
Tin 0 1 0 0 1
Molybdenum 89 66 60 77 74
Nickel 0 1 0 0 0
Manganese 0 0 0 0 2
Silver 0 0 0 0 1
Titanium 0 0 0 0 1
Potassium 4 0 1 1 3
Boron 194 201 49 136 51
Silicon 8 30 11 18 10
Sodium 5 6 4 4 29
Calcium 2814 2750 1098 2083 1839
Magnesium 18 24 585 387 433
Phosphorus 954 848 583 777 848
Zinc 1093 937 717 944 1007
Barium 0 0 0 0 0
SUS@ 210F 70.1 62.5 57.2 63-76
cSt @100C 12.99 10.93 9.42 11.1-14.8
Flashpoint 430 395 385 >375
Fuel %
Antifreeze % 0 0 0 0
Water % 0 0 0 0
Insolubles % .2 .2 .2
TBN 8.8 7 >1
i noticed the unverisal averages changed since my last UOA, so i threw them in there. is that normal in just an eight month period? some of them fell by half.
Originally Posted By: chado_skins
400whp
400 rwhp?
How are you keeping it alive?
Originally Posted By: FermeLaPorte
try 15w40 hdeo
If you are changing it often, I'd have to agree with this suggestion.
Originally Posted By: Linctex
400 rwhp?
awhp. lots of fuel and air
Originally Posted By: CT8
400 Hp WOT produces quite the load on the engine etc..
true. the car is my daily, and the engine is completely stock. i'm not sure how long it'll live at this power level, but i'm prepared if it decides to give up the ghost.
Originally Posted By: bigt61
#'s look good. Your 3k OCI plan sounds reasonable if you're sticking with E85.
yes i have e85 readily available here, so i'll be running full time. i can live with 3k mile oil changes.
for anyone that runs that short of an OCI, do you change the filter every time? i'm running a fram ultra synthetic, wondering if i could change the filter every other OCI?
Knowing the EJ commonly fails in 2 ways, Piston and Rod bearing. The increase in copper concerns me, but I'm no professional.
yes i believe the stock bearings are made of copper, and this was also a thought of mine. i'm going to keep an eye on things and see what happens wear wise. ringlands are the biggest weak link in the 2.5 i believe, but i believe that's related mostly to knock. the stock pistons just don't like it. ethanol should take care of that, it's virtually knock proof and the car is custom tuned and i monitor the snot out of it daily. the oil seems to be doing it's job, so i don't really see a need to change at this point, as was mentioned i just may be at the threshold of where this stock engine just doesn't like this much power.
By "remote tuning" I presume this is the same as e-tuning? From the benefit of others, this would consist of the tuner sending a tune over email, you installing in the car, datalogging, and sending the datalog back to the tuner. You're probably right that this is where the wear came from. How many times do you estimate that you did this?
Be careful extending your OCI's based on good uoa's or advice here on bitog. I did that and it was very expensive (turbo failure). Didn't this model year have the turbo and AVCS banjo bolt screens? Are you still running them? And play it safe by changing the oil filter. On a stock STI of this model year, Subaru recommends 3,750 mile OCI on a stock car due to the screens.
yes remote tuning is the same as E tuning, datalog, revise, flash datalog. the final number of revisions is over 20, but not all of them were on this OCI. probably the last 5-7 i'd guess. but in the course of this last OCI, i was also chasing a boost issue that only happened at WOT at higher RPM, so in order to trouble shoot i was constantly in that part of the power band. i'm going to try and tame it down this OCI and see if copper comes back down.
yes this model has the turbo filter screen, i already removed that and upgraded the turbo oil feed line.
I've always thought that e-tuning was a headache. Maybe because there are so many good dyno/street tuners in this area.
I'd probably go with something more robust if your wear numbers don't come down. Not that you need a 0W in SWFL anyway.
i've done dyno tunes in the past, and i prefer e tuning. unless you're spending ungodly amounts of money for dyno time to dial in the perfect timing map for every RPM range, chances are you get three pulls and done. this map was actually less than a dyno tune, and it's a flex fuel tune. and the way it's tuned is exactly how it's driven on the street, not a simulated environment like the dyno. if i run into an issue, like i did with holding boost, on a dyno unless you can fix it FAST (usually with texa$) your SOL. on the etune he'll give me a chance to fix it, and continue tuning. he hasn't asked for extra money throughout the whole process. i still think the dyno has it's place, but i'm really liking my e tune from eric minehart.
when i first moved down here about a year ago i considered dropping the 0W and going with a 10, but if it works it works. i like the idea that the oil is nice and thin at startup, and comes to temp faster than an oil of a high weight would, whether it actually does anything wear wise is probably debatable.
Actually, a slightly thicker oil will come to temperature faster. And the "0W" is really only "thinner" at the pumpability limit range, which is what the "W" ratings are there for.
For example, M1 10W30 High Mileage is around the same viscosity as your 0W40 at your sort of stating temperatures, and is likely to be a more shear stable product across the board.
interesting, i always just assumed a thinner oil will come to temp faster than a thicker oil. all else equal.
A thinner oil will flow faster but a thicker oil will typically heat up more quickly due to friction.
See comments from Shannow and Molakule in this thread:
https://bobistheoilguy.com/forums/ubbthreads.php/topics/2917469/all/Thick_vs_Thin_Oil_Qu
An engine oil pump delivery flow rate is typically a function of pump rotation rpm.
No, it isn't a function of viscosity grade of fluid, neither is it a function of operating viscosity.
