EU Subaru 2.5 FB engine oil
by IMPALA08. 09/20/18 08:16 AM
02 Focus head replacement
by Eric Smith. 09/20/18 08:08 AM
A5/B5 or A3/B3
by ka9mnx. 09/20/18 07:53 AM
2018 Mazda 3 2.5 Castrol or Mazda Moly
by mazdamonky. 09/20/18 07:44 AM
What fuel are you running?
by Matagonka. 09/20/18 07:25 AM
Be careful what you wish for...
by Shannow. 09/20/18 04:40 AM
Debating repowering my tower.
by Colt45ws. 09/20/18 01:10 AM
Oil filter for GM 8.1l V8?
by KenO. 09/19/18 11:10 PM
Help! No high beam
by wolf_06. 09/19/18 11:02 PM
Heading for divorce
by barkingspider. 09/19/18 11:02 PM
Oil recommendation: 1991 Nissan D21 truck
by RDY4WAR. 09/19/18 10:04 PM
Cold starting and CCS etc.
by CT8. 09/19/18 10:03 PM
Whine->Dead car(electrical)
by madRiver. 09/19/18 09:59 PM
Differential Allen Drain Bolt Buggered
by Gebo. 09/19/18 09:41 PM
Pick my oil. 25k miles a year
by Serge. 09/19/18 09:41 PM
Ok to use in Kubota? Pennsoil 0w-40
by racinjason. 09/19/18 09:35 PM
Road Hugger GTP A/S Tires
by Bud_One. 09/19/18 09:16 PM
Gravity Bleeding Clutch?hel
by Spetz. 09/19/18 09:10 PM
Drunken Watch?
by StevieC. 09/19/18 09:01 PM
New Forum Member New Truck Owner
by FarmerDude. 09/19/18 08:35 PM
FarmerDude, Bman90, Alday714, Joephoto, tlelectric
66021 Registered Users
90 registered members (BAJA_05, barkingspider, ABomb369, 2004tdigls, 9 invisible), 1,460 guests, and 41 spiders.
Topics290,704
Posts4,848,638
Members66,021
Most Online3,590
Jan 24th, 2017
Cleaning EGR and PCV Valve? #4640479
01/19/18 10:00 PM
01/19/18 10:00 PM
VA
maverickfhs Offline OP
VA
So wanted to ask a question about cleaning EGR valve and/or PCV valve for my 2006 Civic EX with AT and 198K.
Question is, should I clean EGR and/or PCV valves? Just as a maintenance item.
I don't have any CEL or anything on the dash or wait until something shows up and then clean it? Thank you thumbsup
2006 Civic EX 202K/AT
2006 Acura TSX 180K/AT
Re: Cleaning EGR and PCV Valve? [Re: maverickfhs] #4640481
01/19/18 10:07 PM
01/19/18 10:07 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I use a little Berryman's B-12 spray down my PCV occasionally. (every 15-20K or so?)
(from the "top down" - - On the F150 4.6, removing it destroys it)
I think it is the original one (154,00 miles)
Re: Cleaning EGR and PCV Valve? [Re: maverickfhs] #4640482
01/19/18 10:07 PM
01/19/18 10:07 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Cleaning the EGR is a LOT more involved and not really an "easy" clean & lube item
Re: Cleaning EGR and PCV Valve? [Re: maverickfhs] #4640483
01/19/18 10:10 PM
01/19/18 10:10 PM
Wet side WA
JohnnyJohnson Offline
Wet side WA
Why would you clean it? You can likely get a new one for $4 to $8 dollars that will last you 30K or more miles and not be maybe fixed?
2004 Corolla 124705
Out: VML 5w-30 TG4967 OCI 5007 Miles
In: EDGE EP 5W-30 Bosch 3311 122537 7-18-18
2006 Duramax 74277
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 74705 4-22-18
Re: Cleaning EGR and PCV Valve? [Re: Linctex] #4640490
01/19/18 10:17 PM
01/19/18 10:17 PM
VA
VA
So you just remove the rubber hose and spray it from top of the valve and will drip inside the engine, would it have any impact?
Re: Cleaning EGR and PCV Valve? [Re: maverickfhs] #4640556
01/20/18 12:36 AM
01/20/18 12:36 AM
San Antonio, TX
das_peikko Offline
das_peikko  Offline
San Antonio, TX
I put the PCV valve in a jar of mineral spirits and shake it up.
Re: Cleaning EGR and PCV Valve? [Re: maverickfhs] #4640570
01/20/18 01:07 AM
01/20/18 01:07 AM
USA
thrace Offline
thrace  Offline
USA
In some Hondas, cleaning EGR passages is more important than cleaning EGR valve. In some Honda V6 engines, cleaning EGR passages is a good maintenance item. Your mileage may vary. At somewhere above 100 thousand miles can prevent incorrect EGR flow problems.
Re: Cleaning EGR and PCV Valve? [Re: maverickfhs] #4640625
01/20/18 05:39 AM
01/20/18 05:39 AM
Manchester, England
Olas Offline
Olas  Offline
Manchester, England
Block off EGR and vent PVC directly into the exhaust stream with a moroso extractor kit
Cable ties should hold it
Re: Cleaning EGR and PCV Valve? [Re: maverickfhs] #4640708
01/20/18 09:46 AM
01/20/18 09:46 AM
VA
Gebo Online content
Gebo  Online Content
VA
I'd just buy a PCV. Very cheap.
I'd clean the EGR. Very expensive. Scotty Kilmer just had a YouTUbe on that exact subject.
'98 LEX LS400 280K
'00 LEX GS300 195K
'02 4Runner 225K
'05 Lex LS430 85K
'06 Toyota Highlander 145K
'09 Lex IS350 85K
'07 Lex GX470 58K
Re: Cleaning EGR and PCV Valve? [Re: maverickfhs] #4640710
01/20/18 09:48 AM
01/20/18 09:48 AM
CA
spackard Offline
spackard  Offline
CA
+1 on the EGR passage cleaning.
I've had a clean EGR valve but a clogged passage. Seems downstream of the valve, closer to the intake, black, oily stuff condenses out of the exhaust stream and starts reducing the diameter of the passage.
Re: Cleaning EGR and PCV Valve? [Re: maverickfhs] #4640820
01/20/18 11:17 AM
01/20/18 11:17 AM
Buffalo, NY
JTK Offline
JTK  Offline
Buffalo, NY
I've cleaned EGR plumbing on engines prone to EGR passage plugging, by using O2 sensor and catalytic converter safe intake/carb cleaner and spraying it in there with the EGR valve removed and the vehicle idling. Smoke billows out the exhaust, but it gets the job done. Same with the vac side of PCV systems.
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
Re: Cleaning EGR and PCV Valve? [Re: maverickfhs] #4640856
01/20/18 11:54 AM
01/20/18 11:54 AM
OH
SatinSilver Offline
SatinSilver  Offline
OH
Get a new oem pcv valve for around $12 or so. www.collegehillshondaparts.com . Usually the internal spring breaks around the 60k mark. Hopefully the car doesn't still have the original one in there.
Re: Cleaning EGR and PCV Valve? [Re: maverickfhs] #4641056
01/20/18 03:21 PM
01/20/18 03:21 PM
VA
VA
I actually cleaned both of them as a preventative, let's see if there are any ill effects of it.
Re: Cleaning EGR and PCV Valve? [Re: maverickfhs] #4641127
01/20/18 05:12 PM
01/20/18 05:12 PM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
You likely accomplished nothing. Cleaning a five dollar part and you could have easily checked for proper EGR flow without taking anything apart.
The "thinking" man's friend.
Re: Cleaning EGR and PCV Valve? [Re: maverickfhs] #4641139
01/20/18 05:28 PM
01/20/18 05:28 PM
VA
VA
Oh well, I spent some time with the car and at least not worried it'll fail because of no maintenance.
Worst case, I'll replace them if any issues.
