Supertech VS Redline - Project Farm
by StevieC. 03/18/19 03:01 PM
How to fix swollen deckwood
by RazorsEdge. 03/18/19 01:52 PM
Which is more important: Oil or Filter?
by RDY4WAR. 03/18/19 01:45 PM
Dishonest car dealership?
by aquariuscsm. 03/18/19 01:21 PM
Phillips 66 Shield Choice $1.99 @ Orscheln
by Pat in Speedway. 03/18/19 12:41 PM
Barely there back seats
by y_p_w. 03/18/19 11:47 AM
should i be afraid of the DCT ?
by WhyMe. 03/18/19 11:28 AM
Friction modifiers
by Truckedup. 03/18/19 10:57 AM
Sometimes, choices are made for you!
by addyguy. 03/18/19 10:30 AM
I Hope This Amuses You Guys Like It Did Me
by NYEngineer. 03/18/19 10:27 AM
New Exmark Lazer Z / Oil ?
by johnD2. 03/18/19 10:13 AM
First welder recommendation
by Astro14. 03/18/19 09:55 AM
Amsoil Burning
by ridgerunner. 03/18/19 09:38 AM
2007 Sonata Pinging + DTCs
by F24Sonata. 03/18/19 09:31 AM
Nissan Maxima 2009 synthetic oil choices
by mahanddeem. 03/18/19 09:23 AM
Best coated rotors
by JMHC. 03/18/19 09:11 AM
Brake Bleeder Question
by maverickfhs. 03/18/19 08:57 AM
Ring alarm system, any good?
by Redright9. 03/18/19 08:18 AM
Indyfordfan, toplscuda, swrve, TomRx, Ozdave
67548 Registered Users
109 registered members (1978elcamino, ABerns, Agnosto, 2015_PSD, 18 invisible), 2,405 guests, and 63 spiders.
Topics286,019
Posts4,900,954
Members67,548
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
s2000 oil choices 0w30 5w30 10w30 full synth? #4640422
01/19/18 08:49 PM
01/19/18 08:49 PM
WA
fuzzysig Offline OP
fuzzysig  Offline OP
WA
i have read some posts here and seems like theres one guy that actually tested the 0w30 in his s2000
and if i go on any other forum and ask people look at me funny like i asked a forbidden question... OEM FTW BRUH. honda knows better. if honda blah blah etc... no real answers.
so far ive seen aftermarked transmission fluid perform better in the j series transmissions
and b series transmissions.
and personally seen benefits of using 0w30 instead of 5w30 in few cars with rod knock( that actually went away after switching to 0w30 synth)
but in the case of s2000 it seems more complicated.
many say that honda did it for a specific reason
others say i think here that at the time s2000 was released they didnt have a better option in 5w30 so they went with the 10w30 due to the quality of oil
but now theres teh full synth 0w30 it seems like amsoil is true synthetic
and some mobil1 are also true synth but then i read that some later mobil1 is not true synth anymore and actually a blend of some [censored] i forgot what it was..
this one they sell at walmart is it still full synthetic or also a blend?
Re: s2000 oil choices 0w30 5w30 10w30 full synth? [Re: fuzzysig] #4640442
01/19/18 09:12 PM
01/19/18 09:12 PM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
Where you been the past two years?
This is a good post for your return.
1994 BMW 530i, 241K
1996 Honda Accord, 267K
1999 Toyota Sienna, 409K
2000 Toyota ECHO, 280K
Re: s2000 oil choices 0w30 5w30 10w30 full synth? [Re: fuzzysig] #4640445
01/19/18 09:16 PM
01/19/18 09:16 PM
WA
fuzzysig Offline OP
fuzzysig  Offline OP
WA
lol i donno. busy with driving boring [censored] sedans that cant break 15seconds
Re: s2000 oil choices 0w30 5w30 10w30 full synth? [Re: fuzzysig] #4640449
01/19/18 09:21 PM
01/19/18 09:21 PM
WA
fuzzysig Offline OP
fuzzysig  Offline OP
WA
then theres another thing i see on forums is that true?
Quote:
The issue with some off the shelf 0W30's is that they're designed more for energy conservation at any temp. So they'll likely be on the "light" side of 30 when warmed up.
5W30 is kind of the same way. They're all usually designed on the thin side of 30.
Castrol Edge 0W30 is one exception, though. If you can find it at your autoparts store...use that. Its actually synthetic, and it retains viscosity at operating temp better than Edge 10W30. Amazon sells it as well
im stressing out because its cold and i see alot of people saying the s2000 motor is very picky when it comes to oil and that many of them blow up because of incorrect oil used(which im assuming incorrect weight like 10w-40 or something).
but i dont know if they are just parroting eachother or actually speaking from experience
Re: s2000 oil choices 0w30 5w30 10w30 full synth? [Re: fuzzysig] #4640485
01/19/18 10:11 PM
01/19/18 10:11 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Rod Rounds runs an S2000 ( with a huge Baldwin filter)
https://bobistheoilguy.com/forums/ubbthreads.php/ubb/userposts/id/17296
Re: s2000 oil choices 0w30 5w30 10w30 full synth? [Re: fuzzysig] #4640507
01/19/18 10:35 PM
01/19/18 10:35 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
https://bobistheoilguy.com/forums/ubbthreads.php/topics/4539409/
Re: s2000 oil choices 0w30 5w30 10w30 full synth? [Re: fuzzysig] #4640510
01/19/18 10:42 PM
01/19/18 10:42 PM
Wet side WA
JohnnyJohnson Online content
JohnnyJohnson  Online Content
Wet side WA
If you live on the Wet Side in Washington you can run your car on 5w-30 or 10w-30 all year and you will never have a problem. On the dry side 5w-30 will be good all year. Life is too short to worry about non problems.
2004 Corolla 129820
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 74725
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: s2000 oil choices 0w30 5w30 10w30 full synth? [Re: fuzzysig] #4640512
01/19/18 10:49 PM
01/19/18 10:49 PM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
The s2000 is flat tappet yes?
Id consider an a3/b4 oil
2010 Ford Fusion SE 3.0L V6, 181 miles M1 HM 10w-30
Re: s2000 oil choices 0w30 5w30 10w30 full synth? [Re: fuzzysig] #4640517
01/19/18 10:57 PM
01/19/18 10:57 PM
TX
robertcope Offline
robertcope  Offline
TX
People run all kinds of things in the S2000. Most enthusiasts seem to stick to a 10W-30. I run Red Line 10W-30 in my NSX and S2000. I've also run M1 0W-40. My S2K has 189K miles on it and still runs strong.
No doubt s2ki.com will have more data specific to the S2000.
Re: s2000 oil choices 0w30 5w30 10w30 full synth? [Re: fuzzysig] #4640524
01/19/18 11:09 PM
01/19/18 11:09 PM
New England, USA
wings&wheels Offline
New England, USA
Great car, enjoy it. I was sent to California for a few years and lived in corporate housing where you couldn't do any major car work, so I bought an early S2000 to enjoy...drove it all over the state. It was probably the best all around and easiest to live with fun car I've had.
I used Redline 5w-40 as that is an allowed weight and, if I remember, it was the recommended eight outside of North America. Given the output of that engine, I felt more comfortable with a heavier oil. Honda lists only 10w-30 and 5w-40 in the US owners manual (at least the 2001 manual I still have), so I would certainly not go lower w/ 0w or 5w-30.
'05 Lotus Elise S/C
'85 Land Rover 90 diesel
'74 Triumph TR6
'74 BMW 2002
'72 Land Rover Series III 88"
'99 Porsche 996 (Wife's)
'01 Porsche Boxster S (mostly Wife's...)
Piper Pa28-236
Re: s2000 oil choices 0w30 5w30 10w30 full synth? [Re: fuzzysig] #4640582
01/20/18 01:21 AM
01/20/18 01:21 AM
USA
slacktide_bitog Offline
USA
For the S200, I'd use Castrol Edge 0w30 or perhaps a synthetic HDEO like Rotella T6 5w30 or Delo 400 LE 5w30
But any synthetic 0/5/10w30 will give you no problems smile
The oil you pictured at Walmart is a full synthetic thumbsup
Re: s2000 oil choices 0w30 5w30 10w30 full synth? [Re: fuzzysig] #4640603
01/20/18 03:21 AM
01/20/18 03:21 AM
North Carolina
rooflessVW Online content
rooflessVW  Online Content
North Carolina
I think a 15W-30 would kick [censored] in the S2000.
"Zed's dead baby, Zed's dead."
Re: s2000 oil choices 0w30 5w30 10w30 full synth? [Re: fuzzysig] #4640668
01/20/18 08:32 AM
01/20/18 08:32 AM
Tennessee, United States
ZraHamilton Offline
ZraHamilton  Offline
Oils shearing is not that big of a problem in oils of today. The viscosity index improver polymers are extremely shear resistant. Also, base oils are becoming better with higher viscosity indexes, so less VIIs are needed. 0W-30 and 5W-30 oils are higher quality than a 10W-30. For your S2000, I would use a synthetic 5W-30 that meets a Honda and an ACEA specification. Mobil 1 0W-30 is also excellent in the cold.
Re: s2000 oil choices 0w30 5w30 10w30 full synth? [Re: fuzzysig] #4640670
01/20/18 08:35 AM
01/20/18 08:35 AM
Jupiter, Florida
Cujet Offline
Cujet  Offline
Jupiter, Florida
I live in South Florida and have a 2004, turbocharged S2000. (Inline Pro stage one kit) I clearly get the best results with M1, 15W-50. I purchased the car with the turbo already installed and the initial oil was 10W-30 Amsoil, which clearly did not hold up all that well to the abuse. I'm sorry I don't have the UOA results handy, but they were not great. The 15W-50 is far better.
As far as M1 not being "full synthetic" forget ALL about that nonsense and remember it's a product very well engineered for a particular task. M1, 10W-30 has a LOWER pour point than the other synthetics, and has excellent HTHS.
FWIW, I get the best UOA results with M1, 10W-30 in my small fleet of Ford F150's. (4.6L, 5.4L and 3.5EB)
Re: s2000 oil choices 0w30 5w30 10w30 full synth? [Re: fuzzysig] #4640680
01/20/18 08:50 AM
01/20/18 08:50 AM
ZraHamilton Offline
ZraHamilton  Offline
15W-50 would be too thick for a stock application. With a turbo, there are higher temperatures and pressures, so that oil is great. For a stock S2000, though, any 0W/5W/10W-30 that meets the specifications will work fine.
Page 1 of 3 1 2 3
