First Time Hyundai Owner - Coolant Confusion
by tony1679. 09/25/18 05:16 AM
European Formula: Supertech and Mobil 1
by Snagglefoot. 09/25/18 02:19 AM
KFE brake pads?
by deoxy4. 09/25/18 01:16 AM
GM Marine Engine wont start
by Gito. 09/24/18 11:59 PM
New TV bad picture some channels part2
by raaizin. 09/24/18 10:46 PM
Another Bad PCM on a Buick 3.8L!
by clinebarger. 09/24/18 10:17 PM
Funny pictures thread
by JLTD. 09/24/18 08:40 PM
Redline 15w40: Low or Mid Saps?
by SavagePatch. 09/24/18 06:59 PM
What are these cables to?
by 99Eclipse. 09/24/18 06:44 PM
Help with parasitic draw?
by buck91. 09/24/18 05:57 PM
Costco Car Buying Program
by dkryan. 09/24/18 05:39 PM
Glass Scrub?
by buck91. 09/24/18 05:03 PM
Loosing coolant from somewhere
by NICAT. 09/24/18 03:47 PM
2010 or so Ford Fusion Sport thoughts?
by ZZman. 09/24/18 03:35 PM
My boss killed his jeep.
by Chris142. 09/24/18 02:40 PM
Moly question about walmart oils
by jayjr1105. 09/24/18 02:33 PM
Questions About 9011 Bulbs
by knerml. 09/24/18 02:23 PM
fortim, albert001, LG_Electronics, TCam, OzFrog
66063 Registered Users
46 registered members (AndyB, 87sammy, Bailes1992, 77GrandPrix, 2015_PSD, 2013ecof150, 6 invisible), 811 guests, and 32 spiders.
Topics290,968
Posts4,853,530
Members66,063
Most Online3,590
Jan 24th, 2017
Mobil 1 0W30 or 5W30 dilema #4640346
01/19/18 07:44 PM
01/19/18 07:44 PM
Oklahoma
RRLJR Offline OP
RRLJR  Offline OP
Oklahoma
I have a Nissan Altima and Frontier, both with the 2.5L engine. I am looking at the Mobil 1 0W30afe and 5W30 for my oil. I want an oil to use year round and want the best oil for immediate start up flow, especially in winter. The lowest temperature I see is around 10 degrees Fahrenheit. I can not find any real information about whether the 0W30 would flow faster in the low temperatures I get versus the 5W30. I see both weights are very close at 40 and 100 degrees celsius. I can find no real reliable information for temperatures such as 32 degrees or even 0 degrees Fahrenheit in relation to the two weights and viscosity. It would seem the 0W30 would flow faster the lower the temperature gets, but I do not know if there is much difference or how much there is at the coldest temperatures I see in my area.
I would appreciate any information and suggestions I can get to make a good decision. Thanks.
Re: Mobil 1 0W30 or 5W30 dilema [Re: RRLJR] #4640357
01/19/18 07:55 PM
01/19/18 07:55 PM
Rio Rancho, NM
Pajero Offline
Pajero  Offline
Rio Rancho, NM
First Question, What does the owners manual state? O is better for flow. But, I'm no expert.
Respectfully,
Pajero!
Always remember "Planned obsolescence."
1994 Montero SR 3.5 DOHC, 133,xxx
Fram Ultra/ Snorkel with Pre-filter
K-9-Co-pilot
Re: Mobil 1 0W30 or 5W30 dilema [Re: RRLJR] #4640364
01/19/18 08:02 PM
01/19/18 08:02 PM
South Texas
Insertcoolname Offline
South Texas
It probably only asks for 5w30 conventional
I used the 0w30 when i lived in the capital.
Lots of short trips and i needed something
I felt confident idling for an hour in traffic
Cold startups were always quick and quiet
Much more quiet than others i have used.
5w30 and 10w30
Conventional, semi syn, and other full syns
I liked it. Give it a try.
It says it meets all warranty requiremens for 5w30
And 10w30
Although the fuel savings was too small to calculate
04 Camry 2az-fe 2.4L 204k QS HiMi 10w30
Supertech white can filter
Re: Mobil 1 0W30 or 5W30 dilema [Re: RRLJR] #4640369
01/19/18 08:07 PM
01/19/18 08:07 PM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
"Flow" is not your concern. There is a difference in pumpability at very low temperatures, but it will be quite a bit below 0F. For my old BMW that sat outside in northern Wisconsin a 0W rated oil was not a bad idea, but a 5W rated oil is still perfectly pumpable at the -25F it sometimes saw. Once you get below that then a 0W rated oil starts to matter more.
1994 BMW 530i, 228K
1996 Honda Accord, 263K
1999 Toyota Sienna, 400K
2000 Toyota ECHO, 271K
Re: Mobil 1 0W30 or 5W30 dilema [Re: RRLJR] #4640383
01/19/18 08:21 PM
01/19/18 08:21 PM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
This is probably the most discussed issue in the forum. Check out “ Mobil1 5W-30 vs 0W30 AFE by ZraHamilton dated 01/15/2018.
At the warmer temps I have the following Dynamic viscosities:
So, at 0 C (32 F) in mPas (mega Pascal seconds)
0W-30. 475
5W-40. 753
15 40. 1328
Sorry, couldn’t find 5W-30.
Realistically you wouldn’t notice much difference at 10 F ( -12 C) between 0-30 and 5-30. However if you still want to check it, take one liter of each and put them in your freezer. A freezer is usually -20 C. Do yourself a pour test. It’s not a dramatic difference but you’ll see the 0-30 pours easier. I run 5-30 year round and am totally comfortable doing starts down to -20 C.
SF
If you want the job done right......do it yourself.
Re: Mobil 1 0W30 or 5W30 dilema [Re: RRLJR] #4640386
01/19/18 08:22 PM
01/19/18 08:22 PM
Alabama
maintenanceMan Offline
Alabama
Not much between either I would say. OW is slightly thinner cold weight. Pick which is cheapest is what I would do.
Re: Mobil 1 0W30 or 5W30 dilema [Re: RRLJR] #4640389
01/19/18 08:29 PM
01/19/18 08:29 PM
Wet side WA
JohnnyJohnson Offline
Wet side WA
Have you ever used 5w-30 in Oklahoma winters before. If so what is the negative result observed you are now trying to fix?
2004 Corolla 124831
Out: VML 5w-30 TG4967 OCI 5007 Miles
In: EDGE EP 5W-30 Bosch 3311 122537 7-18-18
2006 Duramax 74277
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 74705 4-22-18
Re: Mobil 1 0W30 or 5W30 dilema [Re: RRLJR] #4640390
01/19/18 08:29 PM
01/19/18 08:29 PM
San Antonio, TX
das_peikko Offline
das_peikko  Offline
San Antonio, TX
A 5W-30 blend would probably work well and stands a good chance of running quieter too.
Re: Mobil 1 0W30 or 5W30 dilema [Re: RRLJR] #4640403
01/19/18 08:39 PM
01/19/18 08:39 PM
North Texas
ARB1977 Offline
ARB1977  Offline
North Texas
AFE is a good oil.
2015 Tacoma 4.0L 60K (as of 02/23/18)
AMSOIL SS 0W30 / Toyota filter
2018 CRV 1.5L (as of 05/11/18)
Factory fill / Honda filter
Re: Mobil 1 0W30 or 5W30 dilema [Re: RRLJR] #4640413
01/19/18 08:47 PM
01/19/18 08:47 PM
OH
fdcg27 Online content
fdcg27  Online Content
OH
It would be equally valid to ask which was the better oil at the same bucks, which they are.
I'd personally use the AFE 0W-30 always in a 5W-30 application.
No real downside to it, so why not?
17 Forester 18K VME 0W-20
12 Accord LX 92K PP 5W-20
09 Forester 95K M1HM 10W-30
01 Focus ZX3 118K PP 5W-20
96 Accord LX 104K T5 10W-30
95 318i
Re: Mobil 1 0W30 or 5W30 dilema [Re: fdcg27] #4640435
01/19/18 09:01 PM
01/19/18 09:01 PM
Wet side WA
Wet side WA
The fact is why and its harder to find on sale than a number of other 5w oils you could make a choice from.
2004 Corolla 124831
2006 Duramax 74277
Re: Mobil 1 0W30 or 5W30 dilema [Re: RRLJR] #4640455
01/19/18 09:26 PM
01/19/18 09:26 PM
Texas (south)
FermeLaPorte Offline
Texas (south)
I also have a Nissan. One year OCIs don't work on Nissans. The engines thin the oil out by 5,000. That's why that's what is recommended in the owners manual.
Always Mobil 1
2014 1.6L Nissan Versa Sedan, 5 spd, 5k OCI.
2011 3.5L Chevrolet Impala, Automatic, 5k OCI.
Re: Mobil 1 0W30 or 5W30 dilema [Re: RRLJR] #4640470
01/19/18 09:47 PM
01/19/18 09:47 PM
Texas, Mentone for work, Galve...
Bryanccfshr Offline
Bryanccfshr  Offline
If you want to go a full year on Mobil 1 I would recomend the 0w40. It has higher levels of detergents to last longer and they will start just fine in Oklahoma.
2018 Trd Pro 4Runner M1 0w40
2018 Tacoma off-road Castrol 5w30 Magnatec
Re: Mobil 1 0W30 or 5W30 dilema [Re: RRLJR] #4640493
01/19/18 10:20 PM
01/19/18 10:20 PM
Idaho
CT8 Offline
CT8  Offline
Idaho
Both oils exceed the cold starting need. Pick one and drive the car instead of worrying about the wrong thing.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Mobil 1 0W30 or 5W30 dilema [Re: CT8] #4640525
01/19/18 11:09 PM
01/19/18 11:09 PM
Iowa
Nyquist Offline
Nyquist  Offline
Iowa
I run Mobil 1 or Pennzoil Platinum 5w30 in my vehicles in Iowa. We just saw temperatures of -16F. I had zero concerns about the 5w30, and both vehicles started and ran just fine even at those temps.
2015 Chevy Traverse 3.6L (LLT) Mobil 1 5w30 w/ Fram Ultra
2017 Chevy Cruze Hatchback 1.4L (LE2) Mobil 1 5w30 w/ Wix
