VW Passat R36 504 00/ 507 00 oil
by antik. 03/23/19 04:43 AM
Oil for 2015 Ford Explorer
by oilnut12. 03/23/19 12:48 AM
Blains farm and fleet citgo syn
by BTLew81. 03/22/19 10:48 PM
2003 Duramax 208, XXX miles Rotella T4
by TurboJW. 03/22/19 08:11 PM
Turn signals on the freeway?
by das_peikko. 03/22/19 08:05 PM
Running Boards Restored
by kstanf150. 03/22/19 07:38 PM
QSUD at Canadian Tire
by Snagglefoot. 03/22/19 07:29 PM
Camry vs Accord vs ???
by Joe1. 03/22/19 07:26 PM
Fire up
by Matagonka. 03/22/19 07:16 PM
Mobil-1 AFE Discounted at Sam's Club
by ekpolk. 03/22/19 06:20 PM
Test drove a Tesla Model 3
by y_p_w. 03/22/19 05:54 PM
Did i make a mistake? Hilux 3.0 d4dhello
by Anton93. 03/22/19 05:52 PM
WM Valvoline Full Syn Modern Eng Clearance
by Spartanfool. 03/22/19 04:22 PM
Need Moly basic training
by Bill_W. 03/22/19 04:03 PM
P0420 code goes away in warmer weather
by 2010Civic. 03/22/19 03:54 PM
Customer declined new belt
by Chris142. 03/22/19 03:13 PM
How to deep clean back of wheels?
by qdeezie. 03/22/19 02:51 PM
RK oil sale T4 15w40
by 1978elcamino. 03/22/19 01:57 PM
duradick, Harold1031, Skendread, NGK, Thomas1
67589 Registered Users
36 registered members (BobFout, AurionX2, 4WD, CB900F2, bubbatime, Burks21, 5 invisible), 647 guests, and 58 spiders.
Topics286,267
Posts4,905,527
Members67,589
Most Online2,967
Mar 10th, 2019
Tankless Water Heaters - Any Suggestions? #4640044
01/19/18 03:29 PM
01/19/18 03:29 PM
Central NY
Miller88 Offline OP
Miller88  Offline OP
Central NY
So a week after the house flooded, in an unrelated incident, the water heater decided it was time to expire. It's a gas water heater, makes luke warm water but not as hot as it should be.
The water heater is in its "own" room. It is installed in the corner of the kitchen and has a wall of 3/8'' plywood around it. This takes up some valuable cabinet space.
The existing tank heater is vented through the wall pretty high up. I've taken measurements and I should be able to reuse the existing vent.
I have decided that I can go tankless to reclaim some space in the kitchen.
For usage - 2 people, 1 bathroom, kitchen and a dishwasher. I've heard that they don't always play nicely with dishwashers but I know there are some workarounds with that.
Thanks!
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Tankless Water Heaters - Any Suggestions? [Re: Miller88] #4640050
01/19/18 03:35 PM
01/19/18 03:35 PM
5600 feet elevation, Arizona
double vanos Offline
First Iíve heard of them not getting along with dish washers. Care to expound on that as I was thinking about getting one too...
Sabine Schmitz is the Queen of the 'Ring; Svetlana Kapanina is the Queen of the SKIES...
Re: Tankless Water Heaters - Any Suggestions? [Re: Miller88] #4640062
01/19/18 03:46 PM
01/19/18 03:46 PM
Central NY
Miller88 Offline OP
Miller88  Offline OP
Central NY
From what I was reading online, a lot of the HE dishwashers don't draw enough water for a long enough time for the tankless to kick on.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Tankless Water Heaters - Any Suggestions? [Re: Miller88] #4640065
01/19/18 03:53 PM
01/19/18 03:53 PM
Ca.
UncleDave Offline
UncleDave  Offline
Ca.
Make sure you have the current - or gas line for a tankless before you try switching.
UD
Uncle Dave
Cat 3126/2 MB3500/Titan/RX400H/17 Ridgeline
700HP V10/ 725HP BBC/ Raptor 700/ KFX450/ YZ250/Onan 8K/ Cat3011C
Re: Tankless Water Heaters - Any Suggestions? [Re: Miller88] #4640077
01/19/18 03:59 PM
01/19/18 03:59 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
I guess no basement?
2015 Ford F250 w/Powerstroke
Re: Tankless Water Heaters - Any Suggestions? [Re: Miller88] #4640082
01/19/18 04:02 PM
01/19/18 04:02 PM
Ca.
UncleDave Offline
UncleDave  Offline
Ca.
My dishwasher only has a cold fill and uses it's own heating element - so it depends on the dishwasher.
Uncle Dave
Re: Tankless Water Heaters - Any Suggestions? [Re: double vanos] #4640086
01/19/18 04:04 PM
01/19/18 04:04 PM
Somewhere
itguy08 Offline
itguy08  Offline
Somewhere
A friend went from tanked to tankless. The one thing they said they noticed was that hot water took a longer time to reach the faucets. Which makes sense as the tankless has to sense water movement, fire up the boiler and then heat the water all the while cold water is flowing throughout the system.
With a dishwasher using a gallon or 2 per fill, I guess it could lead to lower temps if the dishwasher also does not heat the water.
Re: Tankless Water Heaters - Any Suggestions? [Re: Miller88] #4640091
01/19/18 04:08 PM
01/19/18 04:08 PM
Thanks for the heads up Miller88!
Re: Tankless Water Heaters - Any Suggestions? [Re: Miller88] #4640100
01/19/18 04:16 PM
01/19/18 04:16 PM
Ca.
UncleDave Offline
UncleDave  Offline
Ca.
A recirculating pump will help latency.
Some guys run a real low speed one the guys have one on a switch.
UD
Uncle Dave
Re: Tankless Water Heaters - Any Suggestions? [Re: Miller88] #4640110
01/19/18 04:23 PM
01/19/18 04:23 PM
North Carolina
Rat407 Offline
Rat407  Offline
North Carolina
We like our Rani tankless. We can take two showers at the same time and do laundry with no issues. Our kitchen is at the opposite side of the house so when we remodeled we installed a Chilipepper under the sink. When we want hot water we push a button I installed under the sink and it circulates the water until it reaches temp and then shuts off. Works great and no water wasted down the drain. So when we go to use the dishwasher we just turn on the pump.
Chilpepper
2002 Silverado 5.3 0w-20 AMSOILģ
Re: Tankless Water Heaters - Any Suggestions? [Re: Miller88] #4640125
01/19/18 04:36 PM
01/19/18 04:36 PM
Canuck living in California
KrisZ Offline
KrisZ  Offline
The existing vent will likely not be sufficient and you need to run a separate air intake. And if you're going to go with a 200,000 BTU unit, the gas line will have to be upgraded to 3/4 inch. A 100k BTU will be fine on the existing 1/2 inch pipe, but during winter it may not be enough to run a dishwasher and take a shower at the same time. Or run multiple appliances.
All of that can quite costly unless you can do a lot of the work yourself and do your research.
Re: Tankless Water Heaters - Any Suggestions? [Re: UncleDave] #4640132
01/19/18 04:43 PM
01/19/18 04:43 PM
New England
Virtus_Probi Offline
New England
My understanding is that this is the standard configuration....
2014 Forester XT, 95000 miles
Last Change;
M1 0W30 AFE d1G2
Tokyo Roki 15208AA170 filter
Re: Tankless Water Heaters - Any Suggestions? [Re: Miller88] #4640135
01/19/18 04:49 PM
01/19/18 04:49 PM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
I had a house with 2 water heaters I was planning to move the water 1 heater outside but on the Saturday when the water heater quit working the Renai store was closed so I went to Home Despot and replaced the tank water heater in about half an hour and that was that.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Tankless Water Heaters - Any Suggestions? [Re: Miller88] #4640139
01/19/18 04:52 PM
01/19/18 04:52 PM
Alberta, Canada
Smokescreen Offline
Smokescreen  Offline
Alberta, Canada
Do tankless systems still have to purge sedimentary/other deposits?
13 Civic Si 2.4L- 69Kkms(43Kmi)-PP,Wix
05 LeSabre 3.8L-210Kkms(134Kmi)-PP,Wix
03 Sierra 2500 6.0L-204Kkms(127Kmi)-PP,Wix
All with mpg > EPA
Re: Tankless Water Heaters - Any Suggestions? [Re: Virtus_Probi] #4640145
01/19/18 04:59 PM
01/19/18 04:59 PM
Somewhere
itguy08 Offline
itguy08  Offline
Somewhere
Maybe on newer ones but the older ones were hot water fill.
