Update password ?
by meadows
06/17/18 11:59 PM
Delayed Sleep Phase Disorder
by Reddy45
06/17/18 11:56 PM
Nissan DLR put 0w20 in car that specs 5w30. worry?
by CrAlt
06/17/18 10:40 PM
revive Nicd battery
by Donald
06/17/18 10:27 PM
Need help finding an apartment for friend
by RazorsEdge
06/17/18 10:07 PM
ceratec with redline 5w30?
by 08z06
06/17/18 09:53 PM
does your COMCAST modem have weak wifi??
by edwardh1
06/17/18 09:50 PM
I hate stuck thermostats
by jakewells
06/17/18 09:49 PM
Mag1 75w90
by SavagePatch
06/17/18 09:32 PM
Old batteries at HD
by bbhero
06/17/18 09:27 PM
Buying a CPO Toyota - still get inspected?
by Parlay_Slow
06/17/18 09:08 PM
Water Pump Paper Gasket With RTV? Longevity?
by nobb
06/17/18 08:22 PM
Who makes Briggs & Stratton oil?
by spk2000
06/17/18 08:13 PM
Shure stylus replacement
by aquariuscsm
06/17/18 07:54 PM
Any 'crazy UCL overdose' fans out there?
by addyguy
06/17/18 07:11 PM
Source for Castrol Edge Supercar 5w50 oil?
by Rainier42
06/17/18 06:50 PM
Cherry vs orange hand cleaner
by JHZR2
06/17/18 06:27 PM
Why buy low mileage tires?
by HowAboutThis
06/17/18 05:49 PM
Mercury 35-8M0065104 cut open w/ oil change pics
by dlundblad
06/17/18 05:37 PM
2019 Honda’s miniMOTOs (125cc)
by DuckRyder
06/17/18 05:18 PM
mostdecent, T1TN, Piper58, dunlop0078, Truth_Syrup
65258 Registered Users
31 registered (bubbatime, AVB, bbhero, bdcardinal, Bryanccfshr, askani79705, 5 invisible), 973 Guests and 36 Spiders online.
65258 Members
67 Forums
285502 Topics
Page 1 of 2 1 2 >
#4640001 - 01/19/18 01:58 PM 2008 Civic LX Sedan not starting
maverickfhs Offline
Loc: VA
It's automatic and has 155K miles, battery is ~2 months old from Costco - interstate one.
Resting voltage of battery is 12.6-12.65V. It was running fine until past weekend and was parked for almost 4-5 days.
Today I went to start and it's not starting. While cranking battery light on the ODO stays on. Could it be an alternator or a starter? It does have fuel.
Thank you for any of your help.
2006 Civic EX 200K/AT
2006 Acura TSX 177K/AT
#4640033 - 01/19/18 02:24 PM Re: 2008 Civic LX Sedan not starting [Re: maverickfhs]
LeakySeals Offline
Loc: Hudson, NH
If it starts with a jump and the voltage is less than 14 (running), probably the alternator. If it won't jump, probably the starter
06 Escalade 6.0L AWD 160k. M1 5w30 Fram TG
03 Maxima 3.5L 149k ST HM 10w30
#4640038 - 01/19/18 02:26 PM Re: 2008 Civic LX Sedan not starting [Re: maverickfhs]
HoosierJeeper Offline
Loc: WI
Try jumping it and if that doesn't work, it's probably the starter perhaps. Any noises like the starter trying to engage/spin?
15 Jeep KL Limited V6: Formula Shell 5W20
07 LR3 SE V8: Maxlife 5W30
05 Jeep KJ Limited: PHM 5W30
96 Jeep XJ Country: STP HM 5W30 (winter)
#4640040 - 01/19/18 02:28 PM Re: 2008 Civic LX Sedan not starting [Re: maverickfhs]
maverickfhs Offline
Loc: VA
I'll try to jump it in a bit. It does make a noise when I try to crank, but it's not a powerful one, like maybe starter sound is missing from it?
#4640041 - 01/19/18 02:29 PM Re: 2008 Civic LX Sedan not starting [Re: maverickfhs]
dishdude Offline
Loc: Phoenix
Turn the headlights on and retest the voltage.
2018 Challenger SRT
#4640045 - 01/19/18 02:30 PM Re: 2008 Civic LX Sedan not starting [Re: maverickfhs]
maverickfhs Offline
Loc: VA
I'll go ahead and do it. How much should be the voltage while cranking or with headlights on?
#4640055 - 01/19/18 02:37 PM Re: 2008 Civic LX Sedan not starting [Re: maverickfhs]
maverickfhs Offline
Loc: VA
P.S: What could be symptoms of bad fuel pump?
#4640057 - 01/19/18 02:40 PM Re: 2008 Civic LX Sedan not starting [Re: maverickfhs]
dishdude Offline
Loc: Phoenix
Around the same voltage for at least a few minutes. If it drops significantly the battery is shot.
2018 Challenger SRT
#4640058 - 01/19/18 02:40 PM Re: 2008 Civic LX Sedan not starting [Re: maverickfhs]
dishdude Offline
Loc: Phoenix
Edited by dishdude (01/19/18 02:41 PM)
2018 Challenger SRT
#4640074 - 01/19/18 02:58 PM Re: 2008 Civic LX Sedan not starting [Re: maverickfhs]
exranger06 Offline
Loc: Guilford, CT
Is it cranking normally and just not starting? If so, the battery and the starter are fine and you're likely just missing spark or fuel. If it's not cranking normally, then you probably have a battery or starter problem.
2006 Ford Ranger Sport
1992 Honda Accord EX
2004 Honda CR-V LX
1994 Ford Bronco XLT (project)
2011 Cadillac Escalade ESV (wife's)
#4640079 - 01/19/18 03:00 PM Re: 2008 Civic LX Sedan not starting [Re: maverickfhs]
maverickfhs Offline
Loc: VA
I don't think it's cracking normally since sound of cranking is kind of faint.
Fuel is there, almost 1/4 of the tank and will check on spark too.
#4640111 - 01/19/18 03:24 PM Re: 2008 Civic LX Sedan not starting [Re: exranger06]
maverickfhs Offline
Loc: VA
It's cracking but with a weak crank, I guess?
#4640112 - 01/19/18 03:25 PM Re: 2008 Civic LX Sedan not starting [Re: dishdude]
maverickfhs Offline
Loc: VA
So I turned headlights on and measured battery resting voltage, it was showing 12.05V. Then started to drop, say in 5-10 secs was dropping by 0.01V.
Is this normal?
#4640157 - 01/19/18 04:06 PM Re: 2008 Civic LX Sedan not starting [Re: maverickfhs]
LeakySeals Offline
Loc: Hudson, NH
Can you start it with a jump? If so what is the voltage (while running) at the battery posts?
#4640160 - 01/19/18 04:07 PM Re: 2008 Civic LX Sedan not starting [Re: maverickfhs]
maverickfhs Offline
Loc: VA
I have not tried with a jump yet, going to do it in next 1 hour.
Page 1 of 2 1 2 >
