White or milky cloud in engine oil when cold
by OilUzer. 01/20/19 02:08 AM
Karma Kruiser!
by ekpolk. 01/20/19 01:36 AM
2018 Mazda 3 SkyActive 2.0
by wolf_06. 01/20/19 12:41 AM
Kendall nitro 70
by Bullwinkle007. 01/19/19 11:11 PM
Dexron HP
by Snagglefoot. 01/19/19 11:11 PM
Ruger American 22 Mag
by TiredTrucker. 01/19/19 11:06 PM
Prestone Dex Cool vs Carquest Dexcool
by A_User55555. 01/19/19 11:05 PM
FRAM end cap differences EG and TG vs XG
by wemay. 01/19/19 09:25 PM
Valvoline modern Engine
by Pinoak. 01/19/19 09:02 PM
30 Vintage Photos
by StevieC. 01/19/19 08:23 PM
Low mileage, when to change oil?
by Metfanant. 01/19/19 08:05 PM
Filter with bypass when OEM has built-in bypass
by rubberchicken. 01/19/19 07:43 PM
Barrett Jackson 2019 Pics
by Nick1994. 01/19/19 05:41 PM
What do y'all do with old car parts?
by qdeezie. 01/19/19 05:11 PM
Diagnosing catalytic converters.
by Tlhfirelion. 01/19/19 04:20 PM
Oil recommendations for GM Vortec 8100
by Dudemanmaximus. 01/19/19 04:14 PM
Leaf Spring Questions- Lots of Questions
by George7941. 01/19/19 04:02 PM
Am I being out of line?
by Chris142. 01/19/19 04:00 PM
dougway, Jetsfan421, Fordman420, 72sbc, ejmiller
66982 Registered Users
29 registered members (billt460, claluja, c502cid, Cornershop, carlprop, Black_Thunder, 3 invisible), 844 guests, and 31 spiders.
Topics296,866
Posts4,960,379
Members66,982
Most Online2,688
Jan 19th, 2019
Page 1 of 3 1 2 3
Tips for kicking tires on a fixer-upper #4639863
01/19/18 11:57 AM
01/19/18 11:57 AM
El Oeste
HawkeyeScott Offline OP
El Oeste
I'm probably going to look at an early 2000s 2.0 Jetta this weekend as a possible cheap commuter car. It's advertised as a "mechanics special" because it's had some issues. After paying for some ignition work that didn't fix the issues, the seller says a mechanic has now told them it's an oil pump issue. The people selling it appear to have little or no mechanical know-how or interest in investing anything in it. I've done research and it looks relatively cheap and easy to replace (under $100), IF that's what's actually wrong.
I'd only pay a little money if I were to pull the trigger on this, just because of the potential risk. My worst-case is that the engine has been starved for oil because of a failed pump.
Is there anything I should look for while checking the car out that would give me an idea of 1) if this really is a failed oil pump; and 2) if so, what kind of damage may have been done?
Re: Tips for kicking tires on a fixer-upper [Re: HawkeyeScott] #4639867
01/19/18 12:00 PM
01/19/18 12:00 PM
Houston, Texas
motor_oil_madman Offline
Houston, Texas
It's usually not an oil pump that's worn, but the tolerances in the engine are worn to a point where the pressure is low.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: Tips for kicking tires on a fixer-upper [Re: HawkeyeScott] #4639873
01/19/18 12:07 PM
01/19/18 12:07 PM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
If they are saying oil pump be prepared for needing new engine.
if it just needed a 100$ oil pump they would fix it.
Re: Tips for kicking tires on a fixer-upper [Re: HawkeyeScott] #4639878
01/19/18 12:11 PM
01/19/18 12:11 PM
Storrs, Connecticut
jeepman3071 Offline
jeepman3071  Offline
Storrs, Connecticut
Stay away from these, especially since the previous owners sound like maintenance is not their thing. These were some of the worst cars VW ever made. My sister owned a 2001 2.0 auto Jetta and it was trash by 100k miles. VW makes some good cars but the MK4 Jetta was not one of them.
2000 Jeep Cherokee 4.0L (181k) - Pennzoil 10w30, Napa Gold 1516, Magnefine trans filter
2009 BMW 328i (36k) - Castrol Edge Euro 0w40, MANN HU816X
Re: Tips for kicking tires on a fixer-upper [Re: HawkeyeScott] #4639880
01/19/18 12:12 PM
01/19/18 12:12 PM
NC
ruhroh Offline
ruhroh  Offline
NC
Always expect the worst. And when it comes to 00s VWs, also expect to add in a lot of cursing and anger to replace anything.
Re: Tips for kicking tires on a fixer-upper [Re: HawkeyeScott] #4639887
01/19/18 12:17 PM
01/19/18 12:17 PM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
I hope he's paying you to come pick it up, and not the other way around.
2015 Hyundai Sonata 2.4L 89k Motorcraft Synthetic Blend 5w30 & OEM
2000 Toyota Camry 2.2L 232k Valvoline 5w30 & Fram Ultra
1996 Jeep Cherokee 4.0L 148k Mobil 1 HM 10w40 & Fram Ultra
Re: Tips for kicking tires on a fixer-upper [Re: HawkeyeScott] #4639900
01/19/18 12:27 PM
01/19/18 12:27 PM
DFW
JustN89 Offline
JustN89  Offline
DFW
I'm with the general consensus here, if it was an easy fix, the mechanic would've told them so when he looked it over. Instead, he probably gave them a list of possible causes, they decided that they didn't want to deal with it/spend money on it, and they listed the cheapest and easiest fix as the recommended fix in their Craigslist ad. I'd keep looking.
Re: Tips for kicking tires on a fixer-upper [Re: ruhroh] #4639902
01/19/18 12:30 PM
01/19/18 12:30 PM
Displaced Texan in Mexico City
Gimpy1 Offline
Gimpy1  Offline
This VW has also had a TON of issues with their automatic transmissions. If you do buy the car get an xtool VAG 401 scanner or something similar that reads VW codes, ordinary scanners don't do squat and you will be doing alot of work on the car. VW is a PITA when it comes to fixing them, my wife's 2008 new beetle has been just that, countless issues, [censored] VW has redesigned the brake light switch three time and still hasn't gotten it right. Want a reliable daily commuter buy a honda or toyota. VW suxs, I've had to do more on a 08 new beetle than on my 05 GTO. Also watch out if the car has an Aftermarket radio, improper installation will cause the OBD2 port to fry scanners, that's why most shops don't touch VW with A/M stereos, just Google K-ine issue and you'll see
Re: Tips for kicking tires on a fixer-upper [Re: HawkeyeScott] #4639930
01/19/18 01:07 PM
01/19/18 01:07 PM
North Carolina
rooflessVW Offline
rooflessVW  Offline
North Carolina
What is the actual problem with the car?
Pretty clear to me that their "mechanic" has just been guessing. If the car is mint cosmetically and a 5 speed, buy it - only a few hundred bucks though. I'd cap at $500 without seeing it.
There's little risk. A used 2.0 costs pennies.
"Zed's dead baby, Zed's dead."
Re: Tips for kicking tires on a fixer-upper [Re: HawkeyeScott] #4639934
01/19/18 01:10 PM
01/19/18 01:10 PM
North Carolina
rooflessVW Offline
rooflessVW  Offline
North Carolina
And FWIW, there are a couple TSBs that solve most of the "horrible issues." But dealers don't know what they're doing, right?
Re: Tips for kicking tires on a fixer-upper [Re: HawkeyeScott] #4640078
01/19/18 03:00 PM
01/19/18 03:00 PM
Colorado
Chris B. Offline
Chris B.  Offline
Colorado
Save yourself a lot of trouble and skip the VW. Nothing but junk! Get a used Honda or Toyota, they are much better built and much more trouble free overall.
Re: Tips for kicking tires on a fixer-upper [Re: rooflessVW] #4640243
01/19/18 05:04 PM
01/19/18 05:04 PM
ME
eljefino Offline
eljefino  Offline
ME
If it were a 5 speed though an "enthusiast" could have formerly owned it and screwed it up six ways to sunday vs "Buffy" who bought the automatic b/c she thought it was "cute".
I'm with the others, though, skip this one.
If you already have a same-body style VW and know the foibles, maybe. If you want a project, get a shoddy copy of whatever you're driving now.
Re: Tips for kicking tires on a fixer-upper [Re: HawkeyeScott] #4640248
01/19/18 05:08 PM
01/19/18 05:08 PM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
I would buy it assuming the price is right.
I'm a gearhead and like projects I guess. hide
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 186k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 153k Synpower 5w30 Supertech ST3980 (Ecore)
Re: Tips for kicking tires on a fixer-upper [Re: dlundblad] #4640320
01/19/18 06:19 PM
01/19/18 06:19 PM
VW Fanboy Island
maxdustington Offline
VW Fanboy Island
I'll bet 90% of people bashing VWs in this thread have never owned one. The Mk4 2.0 is one of the hardiest and cheap cars currently available. Even here in Toronto, I see TONS of pre 2003 MK4 2.0s still on the road because their only weakness is the auto trans, rear beam bushings (pre 2003) and the inner fender rust.
Most noobs will fear VWs of that era because of the 1.8T which is why you can pick up 2.0s cheap. 2.0s are a simple SOHC 8v design dating back to the 80s. I am biased because my first car was a 2000 golf 2.0 5spd but they are excellent cars and very fuel efficent.
I currently have a 2003 Jetta 1.8T that went 200000km on original auto trans fluid, suck on that VW haters!
03 Jetta AWP/09A 205k kms
Edge 0W40 + Mann 719/30
Re: Tips for kicking tires on a fixer-upper [Re: HawkeyeScott] #4640350
01/19/18 06:46 PM
01/19/18 06:46 PM
Elizabeth. Colorado
c502cid Online content
c502cid  Online Content
Elizabeth. Colorado
Not sure I'd buy anything on Craigslist that has "easy and cheap fix" in the ad lol.
I get tired of the "buy a used Honda or Toyota" bull sheet that flies on websites like this. They have a ton of issues too, they aren't all easy and cheap to fix either. I know and have owned enough of them. Working on 2 Civics now and about over it. Hopefully they stay together since they are going to be my kids rides.
17 SuperDuty 6.2 4x4
15 Chev Trax AWD
02 GMC 3500 8.1/Allison 4x4
00 Blazer 4x4
97/98 Civic's
84 Chev K30 454EFI 4x4
71 GMC Jimmy 502 RamJet
Page 1 of 3 1 2 3
