Remote Start by Android Auto App ?
by LoneRanger. 04/19/19 04:53 PM
Continental PureContact LS
by The Critic. 04/19/19 03:31 PM
Dark/Black Rear Differential Oil - UOA?
by The Critic. 04/19/19 03:25 PM
Best oil for Honda Rancher?
by jayjr1105. 04/19/19 03:20 PM
Store bought kimchi?
by Quattro Pete. 04/19/19 03:15 PM
2020 KIA Soul Turbo
by Malo83. 04/19/19 03:03 PM
erratic Speedometer
by tookien. 04/19/19 02:59 PM
Another airbag recall
by mclasser. 04/19/19 02:44 PM
Which barb fitting is less likely to leak?
by zorobabel. 04/19/19 02:36 PM
Can these bucket style tappets be reused?
by atikovi. 04/19/19 01:34 PM
Scratched My New Car. Help Me Fix
by GeorgeKaplan. 04/19/19 01:23 PM
Talk about manual labor...
by AZjeff. 04/19/19 12:42 PM
Car didn't burn an ounce of oil... 7K OCI
by jayjr1105. 04/19/19 12:13 PM
Top 6 OEM Passenger Tire Sizes in 2018
by SubLGT. 04/19/19 11:12 AM
CRC intake valve cleaner, safe to use?
by Backstache. 04/19/19 10:06 AM
'94 Grand Am Steering Column Pivot Pins
by benjamming. 04/19/19 10:02 AM
Why the need to replace suspension springs?
by WyrTwister. 04/19/19 09:47 AM
incorrect mileage on reciept
by 1978elcamino. 04/19/19 09:17 AM
Oregon PowerSharp for chainsaw
by Fitter30. 04/19/19 09:16 AM
carve200, Harteeco, fatafox, CurtC, LockCracker
67850 Registered Users
95 registered members (ABerns, 2015_PSD, ArrestMeRedZ, 2009Edge, ammolab, 14 invisible), 2,089 guests, and 32 spiders.
Topics287,750
Posts4,933,819
Members67,850
Most Online2,967
Mar 10th, 2019
New member -- Acura -- oil/filter??? #4639816
01/19/18 12:06 PM
01/19/18 12:06 PM
Chester County/Pa.
Dobbie Offline OP
Dobbie  Offline OP
Chester County/Pa.
Hello all, have been lurking for some time. Just bought my Fathers 2008 Acura TL from him last week with 112 thousand miles on it. He would get the oil/filter changed when the MM would hit 20% at the local garage with 5W20 conventional oil & there budget filter. The car only seen conventional oil its whole life since he bought it new in 08. Would it be ok to use a synthetic oil at this point of its life? I was leaning on using a high mileage oil. What should I use, a conventional high mileage oil or a synthetic high mileage oil? Does not leak or burn any oil since day one. He bought a new 2018 Toyota Avalon. Gave me a good deal & I bit. Been reading that Fram Ultra filters are good also?
Re: New member -- Acura -- oil/filter??? [Re: Dobbie] #4639832
01/19/18 12:21 PM
01/19/18 12:21 PM
Occupied Virginia
Bottom_Feeder Offline
Occupied Virginia
If you're going by the MM then by all means keep going with what's been working. A quality conventional high mileage oil wouldn't be a bad idea but by no means necessary. A synthetic would really only be good for extending your OCIs beyond what the MM tells you.
Fram Ultras are great filters. Be confident using them for two OCIs.
10 years and 100k+ miles might be a good time to pull the valve cover and take a look inside to get a general idea of it's cleanliness, but that's just being anal.
Re: New member -- Acura -- oil/filter??? [Re: Bottom_Feeder] #4639842
01/19/18 12:31 PM
01/19/18 12:31 PM
Ontario, Canada
mightymousetech Offline
Ontario, Canada
At ~100k miles, car is due for timing belt/water pump/valve adjustment/plugs. So, time to take the valve covers off anyways.
Mighty Mouse Tech
BMW Tech, Former Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
Re: New member -- Acura -- oil/filter??? [Re: Dobbie] #4639843
01/19/18 12:35 PM
01/19/18 12:35 PM
Chicago, IL
EdwardC Offline
EdwardC  Offline
Chicago, IL
It wouldn't hurt one bit to switch to a synthetic (high mileage or not, it'll all work fine), and to offset the cost, you can likely run it longer than the MM indicates (at the very least, run it down to 0%). You should be able to run a 0W20 as well, which may make starts on super cold days a little easier, but largely no difference with 5W20.
I believe that's just about time for spark plugs, timing belt, water pump, coolant services. If not done recently, probably doesn't hurt to do the transmission fluid too.
Re: New member -- Acura -- oil/filter??? [Re: Dobbie] #4639884
01/19/18 01:14 PM
01/19/18 01:14 PM
MN
oil_film_movies Offline
MN
Valvoline MaxLife full synthetic version, 0w20 recommended. Keeps older seals flexible to prevent future leaks. It meets higher standards (dexos1 Gen2). Cheap at walmart.
Fram Ultra is indeed the best, on the merits. It holds a lot of dirt, and is good for up to 20,000 miles.
Re: New member -- Acura -- oil/filter??? [Re: Dobbie] #4639886
01/19/18 01:15 PM
01/19/18 01:15 PM
PimTac Offline
PimTac  Offline
I would stick with what has worked for the first 112k. If you really feel strongly about running synthetic but worry about any issues then a synthetic blend will work. Any major brand will do.
Cannot see signatures any longer so it doesn’t matter.
Re: New member -- Acura -- oil/filter??? [Re: Dobbie] #4639891
01/19/18 01:19 PM
01/19/18 01:19 PM
5600 feet elevation, Arizona
double vanos Offline
welcome to the asylum. As you can see, plenty of good advice on this forum!
Sabine Schmitz is the Queen of the 'Ring; Svetlana Kapanina is the Queen of the SKIES...
Re: New member -- Acura -- oil/filter??? [Re: PimTac] #4639978
01/19/18 02:42 PM
01/19/18 02:42 PM
OBX & Central FL
NormanBuntz Offline
NormanBuntz  Offline
OBX & Central FL
+1. I've owned three Acuras with a V-6 through 2008 and all did well on conventional or synthetic blend. You could save some money and messy hands by using a Fram Ultra filter for two of your OLM intervals. Ultra is now rated for 20K miles. Your major vehicle service was due at 105K.
2017 Honda Odyssey SE, 19K
2013 Honda Accord LX, 60K
2007 Honda Ridgeline RTS, 89K
2007 Infiniti M35, 107K
Re: New member -- Acura -- oil/filter??? [Re: mightymousetech] #4639981
01/19/18 02:44 PM
01/19/18 02:44 PM
MN
ZebRuaj Offline
ZebRuaj  Offline
MN
What mightymousetech said. Be read to pay up if father didn't do the service.
~Shade tree mechanic for friends and family.
Re: New member -- Acura -- oil/filter??? [Re: Dobbie] #4640012
01/19/18 03:04 PM
01/19/18 03:04 PM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
These cars last as long running Jiffy lube oil and filters as any other oil and filter. Todays oils are the not same as the oils run in the 1960's. Since you want to learn, the air filters and sealed intake plumbing is the best oil filter.
2015 F150 2.7
2018 F350 6.2
Re: New member -- Acura -- oil/filter??? [Re: Dobbie] #4640056
01/19/18 03:39 PM
01/19/18 03:39 PM
New Jersey
JHZR2 Offline
Global Moderator
JHZR2  Offline
Global Moderator
New Jersey
Id run a low cost syn or syn blend simply because they recommend it in similar, newer engines. But it's really for peace of mind if the manual allows for conventional.
The same filter is used on most Honda cars, and is a common form
factor. Ive run Honeywell OEM filters bought in bulk for around $4 each, as well as a few others like fram Ultra and Napa platinum.
Re: New member -- Acura -- oil/filter??? [Re: mightymousetech] #4640076
01/19/18 03:58 PM
01/19/18 03:58 PM
Chester County/Pa.
Dobbie Offline OP
Dobbie  Offline OP
Chester County/Pa.
My Father said Honda VTEC motors are good motors. What is your opinion on these motors overall. Trying to learn as much as possible & I seen your an Acura Tech.
Re: New member -- Acura -- oil/filter??? [Re: Dobbie] #4640085
01/19/18 04:04 PM
01/19/18 04:04 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
That model year gets the Seal of Awesome from this site:
https://www.carcomplaints.com/Acura/TL/2008/
Other years can be much worse. Check to make sure the recalls were done if applicable.
Re: New member -- Acura -- oil/filter??? [Re: Dobbie] #4640206
01/19/18 05:32 PM
01/19/18 05:32 PM
montreal ,canada
madeej11 Offline
madeej11  Offline
montreal ,canada
PimTac's advice about synblend seems like a good compromise. I'd stick with the 5w20 though. Good luck.
Re: New member -- Acura -- oil/filter??? [Re: madeej11] #4640213
01/19/18 05:37 PM
01/19/18 05:37 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
Valvoline Maxlife syn-blend would be one of my top picks. Red bottle/jug.
