Power Stop Wheel Bearing/Hubs?
by oilpsi2high. 09/23/18 01:37 PM
Dump the 30k ATF in the 17 Kia?
by 3Aone. 09/23/18 01:31 PM
Miata Aisin 6 speed question
by 10ecfarmer. 09/23/18 12:36 PM
Shortest time you owned a car?
by Corollaman. 09/23/18 12:21 PM
Winter tires pinned for studs, but without studs
by Corollaman. 09/23/18 12:12 PM
03 Accord V6 "needs" iridium plugs?
by columnshift. 09/23/18 11:40 AM
03 Accord V6 'brake' light on after brake work...
by columnshift. 09/23/18 11:29 AM
Why does Redline Motor oil quiet lifter noise
by Onetor. 09/23/18 11:11 AM
2017 Hyundai Tucson burning oil (Help!)
by carviewsonic. 09/23/18 11:09 AM
Never waxed ???
by SilverGt. 09/23/18 10:55 AM
Plumbing drain question
by wormwood1978. 09/23/18 10:38 AM
Post your euro cars high mileage
by Serge. 09/23/18 09:08 AM
Post your cars high mileage
by Serge. 09/23/18 09:01 AM
Post your latest mileage achievement
by Snagglefoot. 09/23/18 08:23 AM
Field repair by the Mississippi!
by Number_35. 09/23/18 08:18 AM
F150 5.0 Lost power
by hatt. 09/23/18 08:15 AM
Mobil @ Bomgaars sale
by Duffyjr. 09/23/18 04:45 AM
More California BS!
by dogememe. 09/23/18 04:04 AM
Optimum No Rinse Wash and Wax or Shine?
by anndel. 09/23/18 03:44 AM
The_Money_Light, DALTRON0659, skippermatt, HondaTech250, SandCruzer
66047 Registered Users
94 registered members (01rangerxl, 2015_PSD, 3Aone, -SyN-, 4WD, 9 invisible), 1,813 guests, and 42 spiders.
Topics290,889
Posts4,851,955
Members66,047
Most Online3,590
Jan 24th, 2017
SuperTech 20w50 Dino #4639752
01/19/18 10:54 AM
01/19/18 10:54 AM
CA
cjsiege Offline OP
cjsiege  Offline OP
CA
Anyone run this stuff before or have any knowledge?
My bike (sorry, didn't know what other forum to put this in) is leaking oil and a 20w50 is specified. I need to add some and troubleshoot, but I really hate to spend $10+ a quart on Mobil 1 V-Twin or something similar when it's just gonna leak and get changed in short order as part of trying to fix the leak. At $2.44/qt, my whole sump can be filled for less than the cost of a quart of Mobil 1.
Will it be a problem to use this stuff for a little bit to try and get this leak plugged up?
2013 Honda Civic Si (K24Z7)
Current: M1 AFE 0w20
2017 H-D Street Rod (750)
Current: The cheapest 20w50 I can find because it's a leaky POS
Re: SuperTech 20w50 Dino [Re: cjsiege] #4639756
01/19/18 11:04 AM
01/19/18 11:04 AM
Idaho
CT8 Offline
CT8  Offline
Idaho
Fix the leak. Yeah I sound like my dad !What are the ratings on the oil? I haven't looked at a 20W-50 Since I sold my boat.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: SuperTech 20w50 Dino [Re: cjsiege] #4639773
01/19/18 11:19 AM
01/19/18 11:19 AM
Wet side WA
JohnnyJohnson Offline
Wet side WA
Its winter time a good time to fix a bike. I think the 20w-50 is a poor band aid!
2004 Corolla 124805
Out: VML 5w-30 TG4967 OCI 5007 Miles
In: EDGE EP 5W-30 Bosch 3311 122537 7-18-18
2006 Duramax 74277
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 74705 4-22-18
Re: SuperTech 20w50 Dino [Re: JohnnyJohnson] #4639784
01/19/18 11:29 AM
01/19/18 11:29 AM
CA
cjsiege Offline OP
cjsiege  Offline OP
CA
It's Los Angeles. No such thing as winter! I ride year round.
I don't intend to put any significant mileage on this stuff, I just want to use it long enough to work on the problem and get it solved before I put something better back in.
https://www.walmart.com/ip/Supertech-SAE-20W-50-Conventional-Motor-Oil-1-qt-Bottle/16565377
Re: SuperTech 20w50 Dino [Re: cjsiege] #4639788
01/19/18 11:31 AM
01/19/18 11:31 AM
NEUS
Bandito440 Offline
Bandito440  Offline
NEUS
Itís your 2017 Harley thatís leaking oil? Shouldnít this be a warranty issue?
'14 Grand Cherokee EcoDiesel
Rotella T6 5w-40 & OEM filter
Re: SuperTech 20w50 Dino [Re: cjsiege] #4639796
01/19/18 11:41 AM
01/19/18 11:41 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Your 2017 H-D Street Rod (750) isn't under warranty?
If it's leaking that bad, take it to the dealer and have them fix it.
to answer your question - - - - - - SuperTech 20w50 is just fine. I have run it in Evo engines.
Re: SuperTech 20w50 Dino [Re: cjsiege] #4639798
01/19/18 11:43 AM
01/19/18 11:43 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
If you do not want to fix the leak, I have used this in some lawn mowers and a farm tractor. It's good and it is a band aid.
The "thinking" man's friend.
Re: SuperTech 20w50 Dino [Re: cjsiege] #4639804
01/19/18 11:51 AM
01/19/18 11:51 AM
USA
Reddy45 Offline
Reddy45  Offline
USA
It'll work fine. My uppity Triumph touring bike takes dino Rotella 15W40 and doesn't complain.
Re: SuperTech 20w50 Dino [Re: cjsiege] #4639825
01/19/18 12:13 PM
01/19/18 12:13 PM
Wet side WA
Wet side WA
All the more reason to fix it now but its your bike.
2004 Corolla 124805
2006 Duramax 74277
Re: SuperTech 20w50 Dino [Re: Linctex] #4639826
01/19/18 12:14 PM
01/19/18 12:14 PM
CA
cjsiege Offline OP
cjsiege  Offline OP
CA
Not a warranty issue. I accidentally stripped the oil drain hole (aluminum, entirely too easy to do) during my last change. I tapped it out and installed a helicoil and things seemed okay, but I lost over a quart in 120 miles the other day so I'm trying to figure it out without spending $30 every time I need to fill and check.
I definitely want to fix it but I'm thinking I'm probably gonna have to pull the drain plug out and test things a couple of times.
Re: SuperTech 20w50 Dino [Re: cjsiege] #4639829
01/19/18 12:18 PM
01/19/18 12:18 PM
Europe
SonofJoe Online content
SonofJoe  Online Content
Europe
I can't foresee any problems with using a 20W50 as long as you can see the words 'API SN' on the can's label.
Chances are it will be based on predominantly Group II 500N base oil with a relatively low level of VII polymer. The DI package it uses should be at least as good as what you might find in say a Group II 5W30 (the joys of matrix formulation!) and might very well be better as you often need an AO boost to get 20W50s through the Teost MHT-4 test.
I wouldn't worry too much about friction modifiers impacting on clutch slip as this oil probably won't contain that much Moly or GMO (if any). Even if it does contain some, still don't worry as results on the JASO Friction Test tend to improve, the thicker the oil gets.
In short, you will get an oil that is very resistant to oxidation, have a high HTHS & adequate ZDDP (so will be good on wear) & will shear less than many other oils (and even if it did, so what?). The oil should have an extremely low volatility & a low polymer loading so it should be brilliant regarding piston deposits. And it's dirt cheap so what's not to like (apart from fuel economy)?
Back in the early 60s, my cousin Malcolm gave me my first bike ride on the pillion of his red Royal Enfield. They were affectionately known as Royal 'Oilfields' because they leaked so much!
Re: SuperTech 20w50 Dino [Re: cjsiege] #4639870
01/19/18 01:02 PM
01/19/18 01:02 PM
Rio Rancho, NM
Pajero Offline
Pajero  Offline
Rio Rancho, NM
There is a section of BITOG for MC, FYI....As long as the oil meets the specs it will be fine.
Good luck with your leak!
Respectfully,
Pajero!
Always remember "Planned obsolescence."
1994 Montero SR 3.5 DOHC, 133,xxx
Fram Ultra/ Snorkel with Pre-filter
K-9-Co-pilot
