AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
How a differential works
by StevieC. 03/25/19 07:37 PM
My first!
by BigMoneyGrip. 03/25/19 07:20 PM
Sizing Rims for 17 inch Light Truck Tires
by Snagglefoot. 03/25/19 06:38 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
50 registered members (AlaskaMike, 928, 69Torino, ammolab, Blaze, aaronc7, 4 invisible), 1,144 guests, and 60 spiders.
Topics286,439
Posts4,908,187
Members67,622
Most Online2,967
Mar 10th, 2019
Brightest incandescent tail light bulb? #4639465
01/19/18 01:17 AM
01/19/18 01:17 AM
Orange County CA
MichaelRS Offline OP
Orange County CA
I know I can switch out my incandescent bulbs with LEDs and wire in resistors and all. But I just don't want to.
For my rear turn signals I bought a set of those no resistor LEDs, which I hope will help people notice me better in heavy traffic when I'm singling to move over. And with those you can only use the one pair before you have to wire in resistors.
But I still would like to add a little brighter light to my BRAKE lights when activated.
So, does anybody know a brand of conventional incandescent brake/running light bulbs that is known to be or is supposed to be a little brighter than average?
Thanks.
2002 Toyota Sienna
178k As of May 2017
Re: Brightest incandescent tail light bulb? [Re: MichaelRS] #4639471
01/19/18 01:46 AM
01/19/18 01:46 AM
Northern Kentucky
901Memphis Offline
901Memphis  Offline
Northern Kentucky
The oem bulbs are the best you can do. Leds don't emit the right color for your application and will look pink and be harder to detect. There's some very knowledgeable people at candlepowerforums if you are interested.
2012 Chevy Cruze LT 1.4T - 59k - Edge 0w30 SL + Mahle OX401D
2002 Buick Century 144k - Built 4T65e(Maxlife) - GTX 5w30 + Fram XG3980
Re: Brightest incandescent tail light bulb? [Re: MichaelRS] #4639475
01/19/18 01:49 AM
01/19/18 01:49 AM
Saskatchewan, Canada
Johnny2Bad Offline
Johnny2Bad  Offline
Unlike the aftermarket LED products, which routinely flout and ignore standards, Incandescent lamps follow the national Motor Vehicle Safety Standards (eg US FMVSS). Since the brighness of all lighting on a vehicle is specified (and expressly limited) in ~VSS, you aren't going to get much variation with incandescents.
Not strictly safety related, but a characteristic of incandescents none the less, is the brighter the bulb, the shorter the life. This is inevitable since the voltage is limited to the car's 12V system (or whatever), so only by going to a less physically robust element can it be made brighter, plus of course incandescent brightness is directly related to heat output, which is the enemy of long life.
You might be able to cheat by using 6V bulbs in your 12V circuit, if you have some of the older bayonets or are willing to convert the bulb sockets. See above.
If you want brighter lamps (and especially tail lamps) you need to go to the "wild west" LED market, where illegal lighting is available.
If you're wondering, the limits on tail lamp brightness is there to reduce glare when viewed by other users on the road. Not only light output is regulated, also the viewing angles are limited. Your OEM must pass these restrictions and regulations to be able to sell a new car. Some jurisdictions require all vehicles on public roads to comply with the ~VSS in effect for the MY of the vehicle, others do not, so there is a risk that either you may get a ticket or you may be setting yourself up for a vehicle stop with probable cause.
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
Re: Brightest incandescent tail light bulb? [Re: MichaelRS] #4639504
01/19/18 03:13 AM
01/19/18 03:13 AM
Virginia
mattwithcats Offline
Virginia
Sylvania Silverstar, 7443...
Plug your vehicle in here...
https://www.sylvania-automotive.com/apps/vlrg-us/Vlrg/
2009 Smart Pure
Pennzoil Platinum Euro 0W-40, Purolator Synthetic PSL 14610, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
Re: Brightest incandescent tail light bulb? [Re: MichaelRS] #4639515
01/19/18 03:37 AM
01/19/18 03:37 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I have 3528/5050 red LED tail/brake lights in my Ranger, they are wicked bright (been in for many years now)
I see many new cars now have red LED tail and brake lights from the factory.
Re: Brightest incandescent tail light bulb? [Re: Linctex] #4639604
01/19/18 08:20 AM
01/19/18 08:20 AM
Northern Kentucky
901Memphis Offline
901Memphis  Offline
Northern Kentucky
Yes factory led setups are much different than putting led bulbs into incandescent setups.
Re: Brightest incandescent tail light bulb? [Re: MichaelRS] #4639881
01/19/18 01:13 PM
01/19/18 01:13 PM
NJ
Leo99 Offline
Leo99  Offline
NJ
personally, I wouldn't mess with any safety bulbs in my car. I put brighter LEDs in my reverse lights but the rest is all stock. Brake lights seem plenty bright enough.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles (RIP)
2004 Corolla 125,000 miles
2004 Rav4 370,000 miles
2015 Camry 70,000 miles
Re: Brightest incandescent tail light bulb? [Re: MichaelRS] #4639959
01/19/18 02:26 PM
01/19/18 02:26 PM
Rio Rancho, NM
Pajero Offline
Pajero  Offline
Rio Rancho, NM
I can't speak for Toyota. But, I recently converted my Montero interior/exterior to LED, WOW factor! There are some LED that are too bright.
I love the LED, even in my home. Very very efficient and last a long time. We can thank Roswell for LEDs. Lol
Respectfully,
Pajero!
Always remember "Planned obsolescence."
1994 Montero SR 3.5 DOHC, 133,xxx
Fram Ultra/ Snorkel with Pre-filter
K-9-Co-pilot
Re: Brightest incandescent tail light bulb? [Re: MichaelRS] #4639990
01/19/18 02:49 PM
01/19/18 02:49 PM
Chicago, IL
EdwardC Offline
EdwardC  Offline
Chicago, IL
What are the stock bulb number? If they're 1157 that are common, you can get 2357 bulbs that are a little higher wattage. Try search, might be useful.
In addition, Philips has a LED line that I believe is one of the only street legal LED LED bulbs, their Vision line. Might be an option as well.
Re: Brightest incandescent tail light bulb? [Re: MichaelRS] #4640249
01/19/18 06:08 PM
01/19/18 06:08 PM
Under the hood
Carmudgeon Offline
Carmudgeon  Offline
Under the hood
The only LED retrofits that might work acceptably are the Sylvania Zevo or Philips XtremeVision that use the dual point source emitters, and that's only if the fixture is suitable for it.
If it has multiple emitters and looks like a Xmas tree, it's almost certain to be detrimental junk that ignores the fundamentals of how incandescent fixtures are designed to work, and try, but fail to overcome that using a shotgun approach.
The Philips Vision LEDs with the eight emitters in the white plastic head are somewhere in between, but at least try to utilize the reflector in the manner designed.
But the biggest factor in success or failure in such retrofits comes down to the suitability of the fixture, and the fact is none of the ones sold by the legitimate manufacturers are designed to be any "brighter" than is legal or responsible. Sure, they're not above peddling blue-coated headlights bulbs (which are technically compliant) or even the Xmas tree signaling bulbs as part of their cheaper lines, but they're not pushing the extremely bright junk that will affect the vision of the poor drivers following.
One of the mods over at CPF is Toyota guy and has a Sienna, so he may be able to provide relevant experience.
Re: Brightest incandescent tail light bulb? [Re: MichaelRS] #4640323
01/19/18 07:23 PM
01/19/18 07:23 PM
Orange County CA
Orange County CA
Thank you all for some very knowledgeable replies and advice.
Yeah, I did not have my heart set on Switching out my whole system to LEDs or having super bright overly powerful brake lights. In fact when I found out wiring in resistors are required for most LED lights I was even going to forget doing them on my rear turn signals until I came across those offerings that have the no resistor.
The ones I ordered are the iJDMtoy no resistor turn signal lights offered through Amazon. They are roughly the fith ones down through this link.
https://www.amazon.com/gp/aw/s/ref=is_s?k=no+resistor+turn+signal+lights
Beyond that the only thing I was going to do was geht perhaps the best standard brake running lights that I could for the two outside brake running lights on my van as those are super easy to get to as opposed to having to remove the tailgate panel for the rest of the lights.
but as I said, having to rewire or mess with the lighting electrical system on my older van is not something that im interested in for any reason.
Thank you all once again for your advice I intend to follow up on some of your leads. Any further thoughts please let me know.
Re: Brightest incandescent tail light bulb? [Re: Carmudgeon] #4641158
01/20/18 05:54 PM
01/20/18 05:54 PM
Orange County CA
Orange County CA
Yeah, I'm not interested in being a jerk and blinding people. And going full LED doesn't intrest me anyway. Was just looking for a minor edge I over stock for heavy traffic 90% daylight driving.
Someone mentioned those Sylvania SilverStars and I put a set in my outside brake/running lights.
They SEEM to be fractionally brighter than the Long Life's I had in there and that was really all I needed.
I'm also gonna through one in my high mounted brake light and call it a day as far as those lights go.
Might put a set in my back up ligjts, but that's for later as I dislike deal with that trim panel.
What I am really looking forward to is receiving those no resistor LED turn signals and see how they work.
2002 Toyota Sienna
178k As of May 2017
Re: Brightest incandescent tail light bulb? [Re: MichaelRS] #4641963
01/21/18 02:52 PM
01/21/18 02:52 PM
Cheshire, England
barryh Offline
barryh  Offline
Cheshire, England
Brake light filaments are already overrun in the sense that they put out a lot more lumens per watt and have a shorter life than tail lamps. I would have thought that limits the scope for manufacturers to produce a brighter version.
Barry
1979 BMW R45 (Triple QX 5W40)
2009 Mercedes C180K (Shell Helix Ultra 5W40)
Re: Brightest incandescent tail light bulb? [Re: MichaelRS] #4642670
01/22/18 10:06 AM
01/22/18 10:06 AM
Southeast
meep Offline
meep  Offline
Southeast
you *can* look at the wattage ratings of the filaments on the edge of the carboard. you'll see something like 4.3/15W or something like that denoting the low/high ratings. It gets messy, however, because if you don't have the same ratio of L/H, the difference between running light/brake light might not be enough to be noticed when the brakes come on. Every time I've explored doing what you're looking at, I've ended up staying with stock, as no other favorable combination stands out.
-m
2018 F150
2015 crv (wifey!)
Re: Brightest incandescent tail light bulb? [Re: MichaelRS] #4647500
01/26/18 10:44 PM
01/26/18 10:44 PM
Orange County CA
Orange County CA
I finally just went with those Sylvania SilverStars in my third brake light and my two outside running / brake lights. they seem to be a fraction brighter, and for those that's pretty much all I was looking for.
Although I don't know how worth it is if they only go for a year or 18 months. but at those locations they're super easy to get to and replace.
I'm supposed to get my no resistor LEDs for my rear turn signals this weekend. Looking forward to see how those look.
2002 Toyota Sienna
178k As of May 2017
