Tier III fuel is on the way
by ZZman
44 seconds ago
ACDelco Dexos 0W20 UOA
by DanMiller
Today at 10:44 AM
Mopar window regulator (some assy. rqd.)
by dlundblad
Today at 10:27 AM
5.3L Silverado Water Pump Torque Specs
by Gito
Today at 10:25 AM
Rhino Ramps at Canadian Tire 50% off
by Snagglefoot
Today at 10:18 AM
What to do when your Glock jams
by bigj_16
Today at 10:13 AM
Pennzoil Platinum 5w30 vs 10w30
by Snagglefoot
Today at 09:09 AM
LM MoS2. Honest, if not appropriately tested?
by wemay
Today at 09:03 AM
Brisket flat on charcoal
by 04SE
Today at 08:45 AM
Weird Oil level question
by audia6
Today at 08:27 AM
DNA test and opening a can of worms
by WhyMe
Today at 08:11 AM
Ghetto testing a wheel speed sensor
by Nayov
Today at 06:23 AM
dash cam
by DAC2018
Today at 05:08 AM
WoO driver Jason Johnson injured
by bdcardinal
Today at 01:08 AM
Plastic burning smell when WOT
by Jaha24k
Today at 12:57 AM
Duckham's 15w50 Oil 12 one liter bottles
by Lolvoguy
Today at 12:00 AM
Ruger LCP .380
by PW01
Yesterday at 11:24 PM
Launching boat with stick shift
by troutfisher
Yesterday at 11:22 PM
Free oil
by Spitter
Yesterday at 10:53 PM
Porsche Panamera buying advice
by CharlieBauer
Yesterday at 10:04 PM
bwechols, bowupid, pod423, lemaitrix, azzid0906
65303 Registered Users
70 registered (93cruiser, AdmdeVilleneuve, andyd, AnthemBassMan, 4WD, 10 invisible), 1482 Guests and 61 Spiders online.
65303 Members
67 Forums
285902 Topics
Page 1 of 2 1 2 >
#4639189 - 01/18/18 07:21 PM Preventative Maintenance -
Kung_Faux Offline
Loc: Aus
So I think I need to modify my interpretation of 'Preventative Maintenance' lol..my 2007 BF Ford Falcon (which I plan to keep as a sound no fuss family car) is about to click over 200,000 relatively trouble free Km's...under my own normal maintenance regime this means a new serpentine belt, coolant and hose change.
Now thats all fine... but then I start thinking, while I'm doing the belt change, I probably should change the idler pulley and belt tensioner (both changed with last new belt @ 100,000km's), then I think, well if I'm doing that I should probably do the water pump (never changed)..then if I do the water pump, I'll have to take the radiator out, ok lets get a new radiator..while the raditaor's out, I'll have great access to the alternator...well if I changeout the alternator, it would make sense to do the power steering pump...then I know that everything that spins is new (except for the A/C pump) and then seeing as though I've gone this far...lets do battery (6yrs) and alternator..
Now if I can make all this fit the budget, In my mind I'll end up (in theory) a bullet proof ride for another +200K Km's' for maybe a couple of grand...or should I just calm down, find another hobby and follow the 'if it aint broke don't fix it' camp??
#4639208 - 01/18/18 07:40 PM Re: Preventative Maintenance - [Re: Kung_Faux]
04SE Offline
Loc: IL
Save the time and money. Probably get totaled by some idiot texting if you dump the $$$ into it.
Life's little problems can be solved with a shovel and silence.
#4639210 - 01/18/18 07:43 PM Re: Preventative Maintenance - [Re: Kung_Faux]
Snagglefoot Offline
Loc: Alberta
Whatís the reputation on those water pumps? Itís the most work. Everthing sounds fairly reasonable. So your goal is 400,000 km, which is 240,000 miles. Probably a good time to do it. You could stretch it a few more miles but since you are 1/2 way now why not.
SF
#4639224 - 01/18/18 07:54 PM Re: Preventative Maintenance - [Re: Kung_Faux]
Donald Offline
Loc: Upstate NY
You need to factor in difficulty to replace. If it's 30 min to replace an alternator then I would wait until it breaks.
If you had to pull the engine to replace the alternator, then if I had the engine out and the alternator had a lot of miles, then I might consider replacing it.
2015 Ford F250 w/Powerstroke
#4639225 - 01/18/18 07:56 PM Re: Preventative Maintenance - [Re: Kung_Faux]
BrocLuno Offline
Loc: Kalifornia Kollective
Buy a mechanics stethoscope. Go around to each accessory bearing area and listen. If they just whir and sound smooth, there is no reason to change them. If they sound rough at all, or whine, or rumble, or squeak, it's time.
There is absolutely no need to change quality OEM parts if they are within spec. If they are bad, yeah sure.
I'd do the battery for sure. While you are there, add a new ground wire from the Bat (-) clamp bolt to the radiator support (any handy bolt), to the alternator mounting bracket, and one to the firewall. I use #8 AGW wire minimum. That's like 4mm conductor, or larger - larger is better - all stranded wire. Crimped and soldered terminals that fit the target bolts. The firewall is usually easy if you have access to the hinge bolts ...
The existing ground paths have age and moisture acting over many years. I'll bet the ground point on the engine has never been touched? So you have crevice corrosion making slight semi-conductor bridges out of every crimp-on only OEM connection. The new grounds will do more than the parts list you have been thinking about smile
No need to do a radiator if you have maintained the cooling system? Annual coolant changes(?), and done the hoses every few years ... Water Pump - prolly I'd do it.
I'd for sure do a new thermostat and I'd use a marine SS unit. Quick way to get stuck is to have a thermostat go bad and start engine over-heating. You won't get far ... A pin hole in a radiator can be limped along for days with top-ups.
Gotta think about what will strand you? What kind of ignition? Many Fords over here have an E-core coil that is epoxy potted. Eventually the epoxy breaks down with heat cycles and as the plug gaps grow (age), there is more demand on the coil. They short internally. That'll take out the module. Sometimes that'll take out the distributor pick-up ... Any of this can leave you walking ... frown
New spark plugs with factory gaps. I'd use fine wire platinum, but new is good no matter what. Ohm the plug wires. Replace any the read high. Ohm the coil. If less than 3.2~4 ohms or so on the 12v side, time to replace.
Plug and unplug all your major engine connectors and use Fader-Lube on the pins before you plug them back in - refresh those contacts smile
Edited by BrocLuno (01/18/18 08:02 PM)
#4639238 - 01/18/18 08:09 PM Re: Preventative Maintenance - [Re: Kung_Faux]
clinebarger Offline
Loc: Fort Worth, Texas
I have never done all that as preventive.....
Keep good fresh coolant in the engine & you may never have to change the water pump or radiator.
Change the P/S fluid often & you may never have a P/S pump failure.
So on & so forth.....
My 2006 2500HD diesel has the original Radiator, Hoses, Water Pump, P/S Pump, P/S Hoses, Alternator, U-Joints, Carrier Bearing, Front Wheel bearings (Though they do have a little slack in them), Tie-Rods, Ball Joints, Brake Rotors (Turned once), Calipers (New Hardware)
I change the Drive Belt, Idlers & Tensioner every 100,000 miles because one of original Idlers locked up at 110,000 & left me stranded....This is one of those "Being familiar with your vehicle things)
I've had to change the Transmission cooler lines 3 times (High pressure cooler circuit in the Allison), I change a Glow Plug about once a year Again....Know your vehicles quirks!
I change the Engine Oil @ 8,000 mi, P/S Fluid @ 60,000, Trans Fluid @ 60,000, Brake Fluid every 2 years, Coolant every 4 years & Grease the front end every other oil change. Truck has about 380,000 miles on it now & runs as good as it did when I took delivery on 11/23/06. Been to the dealer once for warranty work (Reprogram of the Glow Plug Control Module).
Another caveat that is true as ever......The part your replacing may be BETTER than the New part, Especially when using aftermarket replacement parts!
2001 Chevy Camaro L92/4L80E
2010 Toyota Corolla 2ZR-FE/Auto
#4639254 - 01/18/18 08:35 PM Re: Preventative Maintenance - [Re: Kung_Faux]
WobblyElvis Offline
Loc: Toronto Canada
I do almost none of this preventative maintenance and it' never bit me. The rad in my 99 van is original.
#4639276 - 01/18/18 08:49 PM Re: Preventative Maintenance - [Re: clinebarger]
andyd Online   content
Loc: Marshfield , MA
Thats a good maintenance regimen. 380K is over 30K a yr. Thas allotta highway.
Thick oil is better grin2
#4639284 - 01/18/18 08:56 PM Re: Preventative Maintenance - [Re: andyd]
bmwjohn Offline
Loc: indianapolis in
what is fader lube?
#4639303 - 01/18/18 09:10 PM Re: Preventative Maintenance - [Re: andyd]
clinebarger Offline
I used to do 115 miles round trip to work 6 days a week, And it been all over the US towing a 5th Wheel.
#4639305 - 01/18/18 09:12 PM Re: Preventative Maintenance - [Re: Kung_Faux]
Linctex Offline
Loc: Waco, TX
Originally Posted By: Kung_Faux
...just calm down, find another hobby and follow the 'if it aint broke don't fix it' camp??
This!
#4639361 - 01/18/18 09:58 PM Re: Preventative Maintenance - [Re: Kung_Faux]
Snagglefoot Offline
Loc: Alberta
Haha, donít listen to these guys Kung-Faux. Theyíve never been stranded in the middle of the Nullarbor Desert. LOL. Buy the way, check to see if your high pressure hoses for the power steering and transmission oil cooler are weeping at the crimps and replace them if they are. Also, do a transmission fluid and filter change and change the rear differential fluid. Should be good to go.
SF
Edited by Snagglefoot (01/18/18 10:10 PM)
#4639364 - 01/18/18 10:00 PM Re: Preventative Maintenance - [Re: Linctex]
Rolla07 Offline
Loc: MTL, CANADA
This!
This. Whats the point in doing all this pre emptively? If you have an engine failure or trans go, you wasted 2k? I just swapped my alternator with 243,000kms 1 month ago. Wait til things fail or are surely in need of replacing.
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
#4639369 - 01/18/18 10:05 PM Re: Preventative Maintenance - [Re: Kung_Faux]
Snagglefoot Offline
Loc: Alberta
Gee Whiz Rolla. This man will be driving long distances in the hot Aussie sun. He needs reliability. beer
Plus he says he wants to take it to 400,000 km.
SF
Edited by Snagglefoot (01/18/18 10:08 PM)
#4639388 - 01/18/18 10:26 PM Re: Preventative Maintenance - [Re: Kung_Faux]
Snagglefoot Offline
Loc: Alberta
Preventive maintenance is a science employed all around the world. Part of it is calculating the odds of failure, the consequences of a failure, and the cost of the maintenance. If your wife is driving down the highway at night and the power steering goes out, what you consider a minor item can turn into a major item for others.
Up to the individual.
Page 1 of 2 1 2 >
