New to me 2018 Grand Caravan 3.6 weight questions.
by racinjason. 07/18/19 07:38 AM
Help With 6L80E Fluid & Pan Replacement
by Sierra048. 07/18/19 06:39 AM
98 Expedition heating system flow diagram
by Fitz98. 07/18/19 12:39 AM
How did I become the constable?
by Chris142. 07/17/19 11:05 PM
Changed oil, Ravenol FullSynth Turbo VST 5W-40
by NotEnoughSpeed. 07/17/19 08:30 PM
Blending TCW3 in diesel
by 32319. 07/17/19 08:27 PM
Leaking Batteries
by ecotourist. 07/17/19 08:22 PM
Shake down tow complete!
by ls1mike. 07/17/19 08:22 PM
Looking for cheap int'l air tix
by daves66nova. 07/17/19 08:05 PM
Not *new* per se, but $3.98 for 5 quarts of M1
by mrdctaylor. 07/17/19 07:45 PM
Winter tires for 2019 Ram
by NissanHauler. 07/17/19 06:16 PM
Is the car hobby/enthusiast a dying breed?
by Redright9. 07/17/19 05:48 PM
Mobil One design change M1C-154A
by piesled. 07/17/19 05:26 PM
crazy granny gear spotted
by Number_35. 07/17/19 04:32 PM
Grease gun suggestions
by rideon. 07/17/19 04:16 PM
17 Imprezza 2.0
by JHogan. 07/17/19 03:42 PM
Grousebeater, RoyD, clonis, golddots, Baronmoye
68698 Registered Users
96 registered members (53' Stude, 64bawagon, 2009Edge, 4WD, 01rangerxl, AndyB, 13 invisible), 1,651 guests, and 19 spiders.
Topics292,013
Posts5,015,305
Members68,698
Most Online2,967
Mar 10th, 2019
'94 Grand Am Blackout No Electrical Power #4638562
01/18/18 10:06 AM
01/18/18 10:06 AM
northern Alabama
benjamming Offline OP
northern Alabama
1994 Pontiac Grand Am 3.1L cranked fine yesterday afternoon. Stopped at the library but when I went to crank it again, all electrical power was lost. As I was turning the key, the instrumental panel started lighting up like normal but ~ halfway through turning the key, everything went off. No power windows, locks, dome light, no clicking, nothing. Battery is good at 12.6V.
What should be my sequence of testing? Voltmeter is ready.
Thanks.
Re: '94 Grand Am Blackout No Electrical Power [Re: benjamming] #4638605
01/18/18 10:49 AM
01/18/18 10:49 AM
Guilford, CT
exranger06 Offline
exranger06  Offline
Guilford, CT
First check the negative battery cable. Follow where it goes (probably the engine block) and see if there's any voltage between that point and the negative battery post. There shouldn't be any. There should be another cable that goes from the engine to the body. See if there's any voltage between the engine and the body. Again, there shouldn't be any. If that's good, then start checking the positive cable. Follow the positive cable to the fuse box and see if there's voltage difference between there and the positive battery post. If that's good, just keep working your way downstream until you find the voltage drop.
2006 Ford Ranger Sport
1992 Honda Accord EX
2013 Toyota Sienna XLE AWD
1994 Ford Bronco XLT (project)
2011 Cadillac Escalade ESV (wife's)
Re: '94 Grand Am Blackout No Electrical Power [Re: benjamming] #4638627
01/18/18 11:06 AM
01/18/18 11:06 AM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
Do as noted above. There's a borderline connection somewhere. Thing about those connections is that starting is always the event that sets them off, especially when dealing with a loose ground.
Start with the simple part: Battery terminals. If they are even a hair loose, they will do exactly what you are experiencing. Turn the key, blanks out.
Re: '94 Grand Am Blackout No Electrical Power [Re: benjamming] #4638681
01/18/18 12:11 PM
01/18/18 12:11 PM
MURICA
maverickfhs Offline
maverickfhs  Offline
MURICA
I have experienced something similar in the past, could be few basic things: 1- As stated above 2- loose ground or a corroded one 3- Worst case, bad battery.
Curious, how old is battery?
2006 Civic EX 205K/AT
2006 Acura TSX 187K/AT
2007 Accord VP 151K/AT
Re: '94 Grand Am Blackout No Electrical Power [Re: benjamming] #4638686
01/18/18 12:13 PM
01/18/18 12:13 PM
USA
mk378 Online content
mk378  Online Content
USA
Turn on the key and measure at the battery again. A bad battery can measure voltage with nothing connected, but then drop to near zero with the slightest load.
Re: '94 Grand Am Blackout No Electrical Power [Re: benjamming] #4638835
01/18/18 02:27 PM
01/18/18 02:27 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Don't measure voltage on the battery.
Measure where the battery cables terminate.
Generally, it's most likely the battery terminals are corroded.
Re: '94 Grand Am Blackout No Electrical Power [Re: benjamming] #4638872
01/18/18 03:10 PM
01/18/18 03:10 PM
USA
USA
I'm guessing it's a GM side terminal battery so not a lot of choice where to measure.
If you have a post terminal battery you want to measure both-- first directly on the posts to confirm that the battery itself is live, then on the terminals.
Re: '94 Grand Am Blackout No Electrical Power [Re: benjamming] #4638986
01/18/18 05:23 PM
01/18/18 05:23 PM
northern Alabama
northern Alabama
Battery is 4.5 years old. I've only put ~40k miles on it in that time. Yes I know that mileage isn't necessarily the issue just stating for completeness.
No corrosion on terminals. I've had that issue on my '02 Accord & learned from it.
It's an Interstate MT-75 side terminal.
Terminals are tight as I checked that yesterday (again previous issue/learning with that).
So no thoughts on it being a fuse of some sort?
Re: '94 Grand Am Blackout No Electrical Power [Re: benjamming] #4640552
01/20/18 12:32 AM
01/20/18 12:32 AM
Marshfield , MA
andyd Online content
andyd  Online Content
Marshfield , MA
You have a bad connection someplace. Not a fan of side terminals. Take them apart and clean them. Don't know about GMs but Ford used fusible links back then. What happens when you turn on the head lights? Check the ground strap jumping around the motor mount. Is there a jumper from the back of the engine and the firewall? Sitting doesn't do good things to cars,especially 24 yr old cars. How are the connections at the starter? AGe of the car, you're gonna get wiring troubles. wires corrode, fray at the ends where the jacket shrinks back and exposes copper.They get brittle and don't like being messed with. BE CAREFUL.
Thick oil is better grin2
Re: '94 Grand Am Blackout No Electrical Power [Re: benjamming] #4641036
01/20/18 03:02 PM
01/20/18 03:02 PM
northern Alabama
northern Alabama
Positive terminal had come loose slightly. Tightened back (spec is 11 ft-lb). Started up well.
BTW, vehicle doesn't sit but rather is my daily driver due to good gas mileage (26-28 mpg).
